Snorkel W/ Bushwacker Flares How To
Discussion in '1st Gen. Tacomas (1995-2004)' started by sander1036, Mar 15, 2012.
  1. Mar 15, 2012 at 7:52 AM
    sander1036
    sander1036 [OP] Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    Well I decided to do a write up on how to do a Safari Snorkel on a first gen that has Bushwacker Cut Out flares.
    Here is a good write up with instructions on how to install the snorkel. This is what I used to install the snorkel.
    http://www.expeditionswest.com/equipment/tacoma/snorkel.html
    First step is to take off your flares.
    Take off the inner fender. I just pulled mine down and away.
    Take off the antenna and pull it out of the way.
    Then set up the given template on your fender.
    Mark your holes with a fine tip marker or pen
    Pull the template off and start drilling :eek:
    I used a 3 1/4" Holesaw and it worked awesome.
    Im not sure what sized bits I used but i started smaller and worked my way up until the bolts fit throught the fender.
    Now that drilling is done, test fit the snorkel. Have the A pillar support loosely bolted to the snorkel.
    Mark the 3 holes in the support on the A-pillar. Remove the snorkel and drill your holes.
    Refit the snorkel on and make sure the support holes line up. Remove the snorkel and tap the plastic bushings into the 3 holes. Refit the snorkel again, and start bolting everything down.
    Now its time to plumb the snorkel. Unbolt the 2 bolts holding the factory tubing in the fender. Get the new tube piece and place on the snorkel and loosely clamp it. Attach the factory tubing to the new tubing and loosely clamp it down. Bolt the factory tubing back in place and tighten all clamps.
    Replace the antenna back in place. Replace the inner fender.
    The Bushwacker flare will need to be shaped to fit around the snorkel. In the photos below you can see a dirt line on how far the fender is off from where it originally was.
    I used a dremel with a die grinder end to shape it. I did this with the fender off the truck and kept testing it as I went. Do a little at a time and keep trying to fit it.
    You will lose one mounting bolt but it will be fine with out it.
    Use black silicon to fill the gap between the snorkel and the flare.
    Now your Done!!!! :D
    Tonemaz likes this.
  2. Mar 15, 2012 at 10:50 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Nice work. Looks clean. Now someone needs to do that with a snorkel and fiberglass fenders. :)
  3. Mar 15, 2012 at 11:18 AM
    sander1036
  4. Apr 20, 2013 at 6:50 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Saunder, I just ordered up some cut outs but already have a snorkel. May hit you up if I have questions.
  5. Apr 20, 2013 at 7:08 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Nevermind, won't fit with my current rear bumper being made.
  6. Apr 20, 2013 at 7:14 AM
    sander1036
    haha thats cool... im always here if you decide to make them fit
  7. Apr 20, 2013 at 7:19 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Boxrocket bumper that he is making has side tubes that come pretty close to the stock flares. Won't fit without a lot of trimming. Thanks though
  8. Apr 20, 2013 at 8:27 AM
    Box Rocket
    Adam
    Syracuse, Utah
    I can make the side tubes shorter if you want to run Cutout flares. Not a big deal on my end. We can make it work
  9. Apr 20, 2013 at 8:33 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    That's ok. I would rather not change the bumper. I like the way it looks now.
  10. Apr 20, 2013 at 8:35 AM
    sander1036
    I have wraparound plate on my elite and mine still has about 2 inches before it touches the flare... however I am going back and cutting more and widening the flares so they touch and it looks right... in reality you can set the flare wherever you want so I think it could still work
  11. Apr 20, 2013 at 8:40 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    I see. Yeah I'm going to hold off for now and run it with the stock flares. Good to know that you can make it work without trimming the rear. Maybe in the future. Thanks again
  12. May 22, 2017 at 7:20 PM
    Jake23
    Jake23 New Member
    2004 Black Tacoma 4wd Crew Cab
    Hey man, I'm trying to put on the Bushwacker cut out fender flares on my 4 door tacoma and I really need help. I noticed that on the rear, it's not technically for a double cab. And it looks like you shouldn't even cut out anything. How did you do yours? I need help like ASAP if you can:(
  13. May 23, 2017 at 2:48 AM
    sander1036
    It's honestly been so long ago that I'm not sure exactly anymore. However I'm fairly certain with the cutouts that you didn't have to cut the fenders if you didn't want to. It just depended on the size tire you were running
  14. May 23, 2017 at 5:14 AM
    Jake23
    Jake23 New Member
    Thanks man, I think I'm just not going to cut the rear because I don't have any issues with them now. I know it had been a while since you posted it. I'm sorry, but thank you!
    sander1036 [OP] likes this.
  15. May 23, 2017 at 5:20 AM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
  16. May 23, 2017 at 8:20 AM
    sander1036
    No problem. Let me know if you need any other info. I can take a look at my truck on Friday afternoon at the earliest.
  17. May 23, 2017 at 8:21 AM
    HomerTaco
    Craig
    Bucks County Pa.
    Gotta blow off the layer of dust first though, right?
  18. May 23, 2017 at 8:53 AM
    sander1036
    Nah it's been sitting outside.... :rimshot:
    HomerTaco likes this.
  19. Jun 3, 2017 at 9:20 AM
    Wadar
    Wadar Well-Known Member
    Wade
    Colorado
    '02 Tacoma TRD Xcab
    K&N 77 Cold Air Intake, Total Chaos UCA's, Warn M8000s, Factor 55 Fairlead and Flatlink E, Kenwood KDC-X598 Stereo, Bily 5100's W/ 2013 TRD Double Cab Coil Springs, Bily 5100's W/ Toy Tec Adjustable Lift Shackles, Method Race Wheel Grid's and American Racing AR 767 Wheels, Weather Tech Floor Mats, Glasstite Raven Topper, Extra Backup Lighting, Disabled DRL's, E-Locker Mod, All Pro APEX Front Bumper, 4 X Innovations Sliders, 200 amp Alternater and upgraded Charging System, Extra PIAA and Hella lighting, Paranoid Fabrications Switch Plate, Bushwacker Cut-Out Fender Flares, Rhino Rack Towers and Bars, Küat Vagabond Rack...
    Nice write up, it answers my question perfectly. I'm toying with the idea of replacing my cold air intake with a snorkel, and I'm running bushwacker cutouts. Looking at the pictures I figured there would be some clearance issues. When in doubt, cut it out! :sawzall:
