snorkel
Discussion in '4 Cylinder' started by yota2000, Jun 30, 2014.
  1. Jun 30, 2014 at 6:11 PM
    yota2000
    yota2000 [OP] Member
    Emilee
    VA
    2000 toyota tacoma SR5
    3" tuff country suspension lift
    i am thinking about getting a snorkel for my 2000 Tacoma and it is a 4 cyl. Wondering if this makes a difference and if its difficult to put on?
  2. Jul 3, 2014 at 8:40 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    Difference?
    Difference in what?
    A snorkel (I thought) was made to make it possible to go in deep water.
    I wouldn't think the routing and connection would hard at all with basic tools.
    I dunno.
    Maybe someone else will chime in.
    :thumbsup:
  3. Jul 3, 2014 at 8:44 AM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    It depends. My Snorkel was made for my truck and wasn't very difficult. It came with a template for my hood to mark the holes, it took some nerve to drill 5 holes into my perfectly good fender. Take your time and it will come out nice.
    Edit:
    The purpose of a snorkel is to help with dust. The secondary function is to protect your motor against water. The thing is once you have a snorkel you can't just drive through 4' deep water. There are still many other components that shouldn't get wet. The benefit is you aren't going to fly through a puddle and accidentally hydro-lock yourself. Also if you do install a snorkel you will want to seal off the drain holes in your intake otherwise water will still be able to get in. I used silicone to seal those holes.
  4. Jul 4, 2014 at 5:22 AM
    yota2000
    Emilee
    VA
    so it helps with dust - i did not realize this. I live on a dirt road so it would be better for my truck in the long run to have it to protect under my hood from the dust?
    Edit:
    The purpose of a snorkel is to help with dust. The secondary function is to protect your motor against water. The thing is once you have a snorkel you can't just drive through 4' deep water. There are still many other components that shouldn't get wet. The benefit is you aren't going to fly through a puddle and accidentally hydro-lock yourself. Also if you do install a snorkel you will want to seal off the drain holes in your intake otherwise water will still be able to get in. I used silicone to seal those holes.[/QUOTE]
  5. Jul 4, 2014 at 5:38 PM
    wgreenlee1021
    I learn't sumpin new...cool....Dust also?Thanks.:thumbsup:
  6. Jul 4, 2014 at 5:59 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    My snorkel will pay for itself in no time. 1 air filter/ month gets adds up. Installed snorkel about a month ago, and filter still looks new. I drive on a ton of farm roads
