Snow and VSC (or slip indicator light)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudFlap, Feb 17, 2021.
  1. Feb 17, 2021 at 9:10 AM
    MudFlap
    MudFlap [OP] Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    So here in the Memphis area we recently got several inches of good powder like snow. While out driving an untreated road, it got pretty thick and I found myself having to hold the steering wheel to the left (about 10:30 - 11 o'clock position) to maintain my lane of travel for a few hundred feet. I was in 4H by the way. Anyway I get up the road just fine bit I notice a minute later that my traction control light is on. Never seen that before. I tried to do a little fish tail to see if the nanny systems would kick in and keep me straight but I had to swap to 2 H and come to a stop... I wasn't trying to get too wild out there. When I got it to slide out a bit the VSC didn't kick in at all.
    I did some google searches and found the sticky thread of "Resetting VSC" and also found a thread about a steering angle sensor. I'm not sure witch direction I should go here. I posted in one of those threads a couple days ago but it seems it's not getting noticed. Any help at all would be greatly appreciated.
    Oh and by the way. On this same outing. I found out I had a headlight out. I stopped and got some new bulbs and while putting them in yesterday I disconnected the battery... to make more room for me... and I wanted to see if disconnecting the battery would reset my light. It didn't.... light is still on and my traction control button is still useless and doesn't work.
  2. Feb 17, 2021 at 2:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the VSC light will not go off.
    You may need to see if there is a code for the VSC system.
    Most scanners that’s can read ABS will usually read them.
    MudFlap[OP] likes this.
  3. Feb 22, 2021 at 7:26 AM
    MudFlap
    Tim
    2012 TRD Off Road
    Well, the scanner things at Auto Zone are not able to read a code. I guess I have to go get bent over at the dealership.
  4. Feb 22, 2021 at 7:57 AM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    I would try resetting the vsc by the thread's directions. As long as you don't put the wire somewhere silly it won't hurt anything and is free. I don't think it's your steering wheel sensor personally.
  5. Feb 22, 2021 at 5:01 PM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    It was a wild time in Memphis, for sure!
  6. Feb 22, 2021 at 5:51 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I live in snow for 6 months of the year. Twice earlier in my truck's life I had the the traction control light come on, with one other light I think it was. I forget the exact error, but my $12 OBDII bluetooth module and the Torque Pro app showed me the exact code, and reset it. Once reset it went away and did not return. They happened about 1 year apart. Has not happened since.
  7. Feb 24, 2021 at 2:31 PM
    MudFlap
    Tim
    2012 TRD Off Road
    I just did the VSC reset and that seems to have fixed it. Everything is back to normal now.
    JGO, TnShooter and Yukon DoIt[QUOTED] like this.
