Snow chains, needed for info on. 2006 Toyota Tacoma prerunner, 4 dr and 2 WD. 2 set or 4??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vincehutchison, Nov 24, 2020.
  1. Nov 24, 2020 at 8:42 PM
    Vincehutchison
    Vincehutchison [OP] Member
    Vince
    Snow chains information needed. 2006 Toyota Tacoma prerunner, 4 dr and 2 wd, I don’t know if I need 2 snow chains on back or 4 all the way around would would be wise
    thanks
  2. Nov 24, 2020 at 8:47 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I always recommend chaining all four. A lot of people only chain up the drive tires, but if your front end goes astray, it can take the back with it.
    TnShooter likes this.
  3. Nov 24, 2020 at 8:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Chains aid in traction.
    Traction to the front wheels is good, they are what turn the truck.
    tirediron likes this.
  4. Nov 24, 2020 at 8:52 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Good luck fitting chains up front. There isn’t much room between the spindle / UCA and the inner sidewall with OEM wheels.
    Your owners manual recommends rear chains only.
    kbecerra and bhigbee like this.
  5. Nov 24, 2020 at 8:55 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Are you looking to meet chain requirements at a chain check? If so, you only need to chain the drive axle in most instances. I've never seen the CHP/NHP require chains on all tires...they'll close the road before it gets to that.
  6. Nov 25, 2020 at 7:14 AM
    tirediron
    Not at all familiar with the OP's vehicle, but I can't imagine there isn't room to get a set of radial "roller" chains on the steer tires.
  7. Nov 25, 2020 at 9:30 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    The owners manual states no chains up front. You can fit cables up front but they better be on tight enough and you need to keep speeds low because they will contact the UCA if you're not running skinny tires (245s) or aftermarket wheels. Use them to get unstuck....then take them off. Since he's 2wd they'll be of little benefit in that situation.
