Snow Chains on 3rd gen...anyone found a way?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chaddnf, Mar 1, 2019.
  1. Mar 21, 2019 at 6:21 AM
    96carboard
    96carboard Well-Known Member
    I don't think you understand chains at all if you suggest "slowing down" as an alternative. If you try to go fast with chains on, you will die.
  2. Mar 21, 2019 at 6:25 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Uggh. Feeble? Whatever.
    02Duck likes this.
  3. Mar 21, 2019 at 6:27 AM
    96carboard
    You might want to consider a narrower tire.
    There are two sizes of tires that come on these things from factory... ones with 265mm tread width, and ones with 245mm. That's a difference of 20mm, which to some degree extends through the tire's body. Naturally, the 245 will yield more clearance.
    So if you go with something like 235's, along with some rims that are also narrower than the factory ones, you could potentially gain an additional 15 mm between the tire and the control arm.
  4. Mar 21, 2019 at 7:41 AM
    nartmot
    nartmot Well-Known Member
    I was suggesting that 1 pair of chains would be enough for most situations if you don't try to drive too fast.
  5. Mar 21, 2019 at 7:50 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    This. It doesn't matter if you think you need them if the chain enforcement thinks you need them.
    Mtn Mike[QUOTED] likes this.
  6. Mar 21, 2019 at 7:52 AM
    96carboard
    You're compounding the problem though. If you try to drive too fast with chains, YOU WILL DIE.
    Chains are for driving EXTREMELY slow in HORRIBLE conditions where you absolutely need maximum traction.
    Further, unless you're carrying around a huge amount of payload, chances are that the front, withOUT chains, will still grip better than the back will WITH chains. Having chains on the front would be an enormous advantage.
    BalutTaco likes this.
  7. Mar 21, 2019 at 11:12 AM
    nartmot
    I kind of get your point, but you are coming across as kind of a dick to me.
    You are correct. Driving fast with chains is a bad idea for multiple reasons. I'm not suggesting anyone drive fast. Further, I agree that two pairs of chains would be beneficial, especially if our truck was designed for it. Unfortunately, our truck is not designed for it so if you want to go through the expense and trouble of putting chains on the front, go for it. Its a free country. For most people, in most conditions, chains on the back will be enough if you don't try to go crazy. Toyota seems to think so too, though I have not verified by checking the user manual.
  8. Nov 7, 2020 at 7:12 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    V Chains and turtle your way out! good luck me, might run into a snowstorm on my next trip hahaha
    I have stock UCA up i barely have 1inch of space between the tires and UCA. but i also have a two inch lift up front.
    bump for winter campers !!
    Kronk21 and Pablo8 like this.
  9. Nov 7, 2020 at 7:28 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I'm that guy.
    As much a people repeat and repeat how terrible K02's are in the snow I do just fine. I put three sand tubes in back, drop it in 4Hi and drive just fine in slush, snow, ice, glop, powder.
    My point: Tires.
    Junkhead likes this.
  10. Nov 7, 2020 at 7:31 AM
    BalutTaco
    This will be my first time driving in snow....sooooo and i'm running KO2. I want to get some cooper sst Max before the trip but that ain't gonnna happen $$$$$
  11. Nov 7, 2020 at 7:39 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Just go easy man, think all your driving skills. If you can practice in a lot or even on some empty road. Put some weight in the back, but nothing crazy, even 100 pounds helps. Too much will make things worse if you get sideways and plan on getting (a little) sideways and knowing how to correct out of it.
    Don't depend on your brakes, stay way back, and this is what I expect of others (never happens!) .
    Just don't go too fast (or too slow!!) and you will gain confidence without getting being cocky.
    I'll never forget the time on a straight downhill I did a complete 180° in my 1985 2WD SR5 pickup.
    PopishMetalFab and Junkhead like this.
  12. Nov 7, 2020 at 7:44 AM
    BalutTaco
    Wait.... so what do i do if i go 180 downhill..... o_O. I know i'll be driving though the mountains. Also will have more than 100lbs due to camping gear.
  13. Nov 7, 2020 at 7:50 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Yeah I spun perfectly so I was facing uphill. Those trucks were so light. Summer tires. No weight in back.
    It happened REALLY quickly. Like THAT. Bam. Luckily it was relatively close to the bottom and no other cars. I got it pointed down hill and off I went. This was in the late 1980's. I've driven just about every vehicle out of and into fun situations since then.
    One thing I HATE is FWD cars UPHILL in snow. Just when you need traction the front end is coming up.......
  14. Dec 30, 2020 at 9:09 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    I decided to pick up some heavy vbar chains for my Pro.
    Test fit on the front for shiiits and giggles. On a stock Pro setup (with Hakka R3 tires) there is about 1 finger width of clearance between the chain and spindle. UCA clearance doesn’t look to be an issue. Could probably get away with running chains that used a cable around the perimeter, or definitely with a full cable set on the front.
    I had to move the last cross link to tension the chains properly. Still need to trim the excess. I did not drive like this, and won’t use this set on the front.
    Seems to be enough UCA clearance assuming proper tension
    Kronk21, tonered and RyanDCLB like this.
  15. Dec 30, 2020 at 9:25 PM
    #35
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    dammm.. thats way too close for my taste...but everyone thanks you for show and tell....
  16. Dec 30, 2020 at 9:36 PM
    #36
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Yeah, no thank you.
    If you need front chains on your 4wd to get somewhere I have two words for you. Beater truck.
  17. Dec 30, 2020 at 9:43 PM
    #37
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    I have a 2020 TRD OR but haven't really taken it too far north yet (the border is closed to get into CA). Great resource here with lots of interesting suggestions. Really appreciate the pic. I had no idea that Toyota doesn't recommend snow tires on the front of the Tacoma.
    I guess I have two options -- either much lower profile chains (there are some good ones on the market now that I have been looking at) or maybe I just get a pair of studded snow tires.
  18. Dec 30, 2020 at 9:52 PM
    #38
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Your chains should be on the rear tires. Says so in the owners manual.
    Are you already running some on the rear and adding more to the front?
  19. Dec 30, 2020 at 10:01 PM
    #39
    averagejp
    Work in progress
    I think that has been established already ... but thanks for confirming it. I am curious why Toyota says chains on the back two only? Most of the folks that I know with chains on trucks, especially off road in the extreme winter, use for. I know it is in the manual that way ... totally get that ... but I wonder why that is the recommendation? Is it because the front two are not needed or they won't fit?
    Of course, I can't wait to do a little off road driving on a few trails but that is just me ... I love a good snowstorm !
  20. Dec 30, 2020 at 10:26 PM
    #40
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I think it’s a clearance issue between the tire and the UCA/spindle.
    Add chains and they end up smacking the UCA and spindle.
    They write the manual for 99.99 percent of drivers out there and those are the ones who do put chains on the front end of their corvettes, mustangs and camaro’s.
