Snow Chains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sabu, Dec 29, 2010.
  1. Dec 29, 2010 at 8:17 AM
    sabu
    sabu [OP] Squirrel Driver
    So. Cal.
    MG 4x4 TRD OR
    XM Radio, Redline hood lifts, X-tra bed tie-downs
    Are there major advantages/ disadvantages between tire chains versus tire cables?
    Which type of traction aid works best (or doesn't work) with airing down to 10 - 12 psi?
    There are so many variants of each. Any particular detail about the chain locking mechanism that works best?
    Thanks.
  2. Dec 29, 2010 at 9:08 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    One disavantage on both is when a cable or link breaks it beats the wheels hsg or fender to death.
  3. Dec 29, 2010 at 9:09 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You're going snow wheeling?
    Or driving on pavement?
  4. Dec 29, 2010 at 9:13 AM
    6spdtaco
    6spdtaco Well-Known Member
    Nate
    East Wallingford, VT
    Taco
    Tom Woods driveshaft. TRD short throw shift kit. TRD exhaust. AFE Stage II intake. CBI Bumpers front and rear. Warn 8000i winch/ synthetic line. OME 3" lift w/ dakar springs and 886 coils. ATO Front skid. ARE MX cap. Trail Team FJ wheels. Cooper Discoverer ST 265/75-16 C tires. Diff breather relocation mod.
    Cables for street. Chains for offroad. I prefer the V-link style for heavy offroad/snow use. Better make sure they are tight or they will destroy wheel well/abs/everything else like mentioned above. I use about 3 bunjee cords (6 connections) per wheel to keep the chains from smacking around.
  5. Dec 29, 2010 at 9:56 AM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    X2:D
  6. Dec 29, 2010 at 10:04 AM
    brp
    brp Well-Known Member
    You can't use chains up front on 2005+. They hit the upper control arm. There are some low clearance cables that MIGHT clear the control arms.
    For road use there is a product called autosock that I think would clear in front and would not cause much/any damage if they failed. The Colorado DOT
    says the autosock is as good as chains and they don't count cables as a susbstitute for chains, so they must be decent?
  7. Dec 30, 2010 at 4:34 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    I have used chains on the front of my 07 it's tight.:D
  8. Dec 30, 2010 at 7:00 PM
    romafern
    romafern Well-Known Member
    Rob
    Olympia, WA
    stock and very pissed about the issues
    Machine gun mount. Would love to blow the shit out of it since it has nothing but issues. QA at Toyota USA is shit. Start making them in Japan for Christ's Sake!
    Buy spare bungees. Be prepared.
  9. Dec 30, 2010 at 7:36 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    Sure Grip Z-Chains
  10. Dec 30, 2010 at 8:12 PM
    Rodallg
    Rodallg Well-Known Member
    CA
    I bought a pair of Rud chains for my 2WD before I went north 2 weeks ago and had to use them on the way back last week. Easy to go on and worked great.
  11. Jan 1, 2011 at 7:38 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Buy a pair of chain link R/R pliers and I always carry some bailing wire incase I need to tie off a broken link till I can replace it.
  12. Jan 1, 2011 at 7:56 AM
    toytacoma22
    toytacoma22 Well-Known Member
    COS
    3" Icon Lift, TC UCA, OME Dakars, Allpro front and rear bumpers.
    No autosock for us guys running around a 33" tire or larger
  13. Jan 1, 2011 at 8:14 AM
    6spdtaco
    Nate
    Taco
    Yes.
  14. Jan 2, 2011 at 7:41 PM
    brp
    MrFastLayne, what brand and model of chain did you use up front on your '07? It would be great to have a chain option up front. Thanks
  15. Jan 2, 2011 at 8:36 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Cables that have the diagonal pattern are great on road , i never broke a set yet , personally wouldnt try em off road. I use them at work if needed on pickups.
    Chains work great on road too but arent as smooth, no choice there on our bigger trucks 16000 gvw weight and up. Used to use them offroad/ on gravel roads back in the 80s (yea im old). like previous posts said , bring pliers , extra bunjees , bailing wire to hold loose chain ends also take 4' and bend it in half till you have many strands and twist with pliers , threaded links help a lot too, 2 sizes have 8 handy
