Snow Chains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Feb 8, 2010.
  1. Feb 8, 2010 at 8:03 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    My new mountain house is at the end of a 1/5 mile mountain road - paved - with many switchbacks and pretty steeply sloped in areas. My 2nd Gen 4x4 is useless in the snow - I've tried it.
    Can anyone recommend a good set of snow chains I can get? I don't want snow tires as I only need the traction for this specific use. The roads at the base of the mountain are always clear. I've read about "self-tightening" chains but know nothing about them....I have never used chains before.
  2. Feb 8, 2010 at 8:10 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
  3. Feb 8, 2010 at 8:15 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Do you even have better tires at all? Everything ive read say the stock tires are worthless...
  4. Feb 8, 2010 at 8:21 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    My stock tires thus far have performed perfectly fine.
  5. Feb 8, 2010 at 8:27 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Until the snow, I changed my tires out for MT's and they do great wheeling in the snow. As for chains I have never had to use them but thought about picking up a set just in case. When you end up getting some post up how you like them and which ones you went with.
  6. Feb 8, 2010 at 8:36 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I am researching Thule chains......
  7. Feb 8, 2010 at 8:43 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    $200:eek: per set. F that.
  8. Feb 8, 2010 at 8:45 AM
    braggman7
    braggman7 Well-Known Member
    Athens, GA
    '10 Double Cab TRD Sport 4WD
    x2...... in the 4 total days of snow that ive had...
  9. Feb 8, 2010 at 11:14 AM
    valleythunder
    valleythunder Well-Known Member
    Rob
    Dahlgren, VA
    08 DC/LB
    Except when you need to go somewhere :):) in the snow....... ??
  10. Feb 8, 2010 at 11:17 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    True! But in all fairness, they weren't designed for snow. Just order some Thule's on Amazon.....$139.....Autoanything's.com prices are horrible.
  11. Feb 8, 2010 at 11:23 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Yup.
    See, the thing is, where he lives if you go off the road, there is no ditch. It just keeps going until you crash through someone's house, or reach the bottom where there is usually a creek that is probably flooded. I have lived there and driven there, you don't want to go off the road there at all.
  12. Feb 8, 2010 at 11:27 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Correct wise one! I go off my road, I die. Period.
  13. Feb 8, 2010 at 11:54 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Just be aware that with the stock wheels, you cannot put chains on the front. If you get a set of FJ TRD rims, you can run chains in the front without a problem.
    barmour's quote from TN:
    "I fixed my snow chain clearance & bought the FJ cruiser TRD rims and financed em in at the dealer. These FJ TRD rims (they have other FJ type designs that may work but these are TRD) allow medium to large size snow chains to clear the UCA and other items on 265/70/16 tires without rubbing. I also was able to step up my tire size to 265/75/16's and ran my test. I did not drive around with them but I gained appx 3/4 to 1 inch more clearance over the stock trd tacoma rims."
  14. Feb 8, 2010 at 12:08 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Ordered one set for rear tires only.
  15. Feb 8, 2010 at 12:53 PM
    fjhutch
    fjhutch Member
    Hutch
    Snohomish, WA
    2013 Dbl Cab Trd Offroad
    Fold a Cover G4 Elite Tonneau Cover
  16. Feb 8, 2010 at 4:14 PM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    Snowies are where its at. The Dunlops are useless for anything other than lots of efficient miles during the summer.
