snow plow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by G-MAC, Mar 12, 2017.
  1. Mar 12, 2017 at 12:50 PM
    G-MAC
    G-MAC [OP] Member
    Gerard
    2007 toyoya tacoma SR5 4X4 AT ACCESS CAB
    I am going to install a 86 inch blizzard on my 2007 anyone on here plows with their trucks.... ? any tips or watch out for..
    Thanks
  2. Mar 13, 2017 at 5:48 AM
    tgear.shead
    tgear.shead Well-Known Member
    86? So... 720LT?
    Should be ok, bit of a light plow though -- only 1/4" edge.
  3. Mar 13, 2017 at 3:02 PM
    G-MAC
    G-MAC [OP] Member
    Gerard
    720LT.... would not want to go any bigger, doubt that the Tacoma is built for heavy plowing. I just plan on blowing my drive way maybe a neighbors , definitely no commercial work..
  4. Mar 13, 2017 at 3:15 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  5. Mar 13, 2017 at 4:51 PM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Ugggg :annoyed:
    I'll be going home and hooking up the plow and throwing some weight in the bed along with some sand/salt in prep for Mother Nature's furry!
    Get er done!
    markelhof likes this.
  6. Mar 14, 2017 at 5:03 AM
    tgear.shead
    Commercial or not doesn't matter. The plow needs to be strong enough to stand up to the truck, and I've broken much stronger plows than that.
  7. Mar 14, 2017 at 5:09 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    A 720LT should be plenty heavy for a Tacoma. As long as you treat them reasonably, both Tacomas and the plows made for them are plenty strong enough to plow with. Just plow with the storm instead of waiting for it to be done and trying to pound out 2 feet of snow in one go. Plow when there's 5-6 inches on the ground, don't beat on it by trying to shove back frozen banks, and you'll have zero problems with equipment strength. :notsure:
    I opted for buying a dedicated work/plow truck instead, but it was mostly cost-motivated. I was quoted around $4500 to have a plow installed on my Tacoma when I bought it, and I was able to find an older American truck with the plow already installed for less than half of that.
    PzTank, JoefromPTC, KYDeer and 5 others like this.
  8. Mar 14, 2017 at 5:10 AM
    tgear.shead
    It isn't the amount of snow that you need to worry about. Its what is UNDER the snow, like ROCKS or CURBS.
  9. Mar 14, 2017 at 5:39 AM
    Noelie84
    Noel
    Wales, Maine
    Blizzards have a 'trip' feature, though, don't they? I think they're a full-trip setup. So, if he's not abusing the equipment the OP shouldn't have any problems with it. If he hits a rock the plow should just trip and slide over it.
  10. Mar 14, 2017 at 5:44 AM
    tgear.shead
    ALL plows are supposed to trip, but the ability to trip depends on how you strike the obstruction. Hit a low obstruction dead center, and it will probably trip over it. Hit anything with the trailing edge, and it may not be so inclined. Hit a TALL obstruction with the trailing edge (which can include a hardened up snow bank), and it isn't going anywhere.
    I've been plowing for 25 years. Non-commercial, but significant and sometimes brutal. Toy plows BREAK.
  11. Mar 14, 2017 at 5:46 AM
    Noelie84
    Noel
    Wales, Maine
    True, but unless you're plowing at a high speed you're not going to damage anything by bumping up against a snowbank or a curb.
    Edit: You might rash the plow a bit, but you shouldn't bend/kink or break anything. I've been plowing snow for a long time, and the only times I've seen properly maintained equipment get broken it's been because of the operator. :notsure:
  12. Mar 14, 2017 at 5:48 AM
    tgear.shead
    You've got 5000 pounds of truck behind it. It doesn't take much speed. All it takes is the right geometry. In fact, most of the breaks I've had have been at very low speed. Windrowing a road at 30 kph is smooth work. Its dealing with driveways that kills you.
  13. Mar 14, 2017 at 6:02 AM
    smcgill
    Sean
    Have you looked @ Curtis: http://www.snoproplows.com/sno-pro-snow-plows/
  14. Mar 14, 2017 at 6:07 AM
    Noelie84
    Noel
    Wales, Maine
    Yeah, until you hit a pothole that'd swallow a Volkswagen. :rofl:
    Cruising along, rolling snow back off of the moldboard....*BANG!!!* :goingcrazy:
    Better heart-starter than a cup of coffee.
  15. Mar 14, 2017 at 6:10 AM
    tgear.shead
    A pothole won't do anything. A plow will just glide right over it.
    Like I said, I've been plowing for 25 years, and windrowing is the easy part. You need to keep the speed up in order to actually move the snow over/past the bank, there IS no moving the bank once its set, and if you don't clear the bank in subsequent storms, then the road quickly narrows to the point of being unpassable.
    Low speed multi-pass driveways and crap like that is where the danger lies.
  16. Mar 14, 2017 at 6:23 AM
    Noelie84
    Noel
    Wales, Maine
    You haven't seen some of the potholes around here, then. Some of them are pretty damn epic once the frost sets in. And they get worse in the spring when the frost starts coming out. Especially on the back roads in some of the more rural communities.
  17. Mar 14, 2017 at 6:26 AM
    tgear.shead
    Just to be clear, I'm not talking about PUBLIC ROADS. The government handles those. I deal with a private single lane 3 km long gravel road.
    But as far as huge holes go, as long as your plow is long enough to bridge it from one side to the other, you won't fall into it.
  18. Mar 14, 2017 at 6:28 AM
    Noelie84
    Noel
    Wales, Maine
    Association road in a subdivision? Or one homeowner with a long-ass driveway?
  19. Mar 14, 2017 at 6:30 AM
    tgear.shead
    Long-ass driveway.
    smcgill likes this.
  20. Mar 14, 2017 at 6:36 AM
    Noelie84
    Noel
    Wales, Maine
    Lucky bastard. I look forward to the day that I have a driveway long enough that it means I can't see my neighbors.
    Spare Parts and smcgill like this.
