Snow Plugged Air Filter Solution?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amadougrand, Sep 8, 2013.
  1. Sep 8, 2013 at 6:04 AM
    amadougrand
    amadougrand [OP] Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    It doesn't happen often, but sometimes you just get caught in drifting or powdery conditions.
    On two occasions now I have had to pull my air filter after barely getting home to thaw the ices from it then dry it.
    Any solutions other than a snorkel? Really don't want one. A CAI seems like it would not help as the snow is typically blowing up over the vehicle when this happened and would get sucked in there just as easily.
  2. Sep 8, 2013 at 6:59 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Good question. I just turn my snorkel head backwards, but I always wondered what others do. You could always carry another filter. I still have the stock filter and I carry an extra even with the snorkel.
    I had some issues with my shocks freezing up two years ago. Parked it for a minute after romping and when I drove off I thought I blew the coil-overs out. Thank got it was only them being frozen solid and nothing a power washer couldn't handle. If I was in the middle of know where that could of gotten interesting trying to melt them.
  3. Sep 8, 2013 at 7:07 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    I wish i had this problem... ^^^
    wait, wut? were you in the south pole?
  4. Sep 8, 2013 at 7:19 AM
    XXXX
    sKiP
    05 Prius
    Southern New Jersey :anonymous:
    Whenever we get it I play in it.
  5. Sep 8, 2013 at 7:23 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I doubt it was frozen shocks then. :confused:
  6. Sep 8, 2013 at 7:28 AM
    B737
    Kevin
    Jersey Shore
    stock
    +1 not in NJ....
    even in the deepest VT winters cold soaking into the negative teens this wont happen.
  7. Sep 8, 2013 at 7:35 AM
    XXXX
    sKiP
    05 Prius
    I know what ice wrapped around coils looks like :cool:
    Its from flying through powder at speed then stopping. Snow builds up quick.
  8. Sep 8, 2013 at 7:40 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    When I had the V6 in the winter I'd pull the tube from the airbox to the fender. Just two bolts and the screw clamp. I did it primarily for fuel mileage reasons because it kept the IAT above freezing. If I had an open grill, it was usually 20-30F above ambient after the motor warmed up while going down the road; with a full block, more like 40-50F. If I had to idle for a while it might get 100F over ambient but in winter air that's no problem.
    It might keep things from icing up but I never had that problem either way.
  9. Sep 8, 2013 at 7:46 AM
    worthywads
    So it wasn't frozen shocks.
  10. Sep 8, 2013 at 7:51 AM
    XXXX
    sKiP
    05 Prius
    :confused:
    They were blocks of ice.
    If your asking were the internals frozen that's doubtful. They are sluggish until they warm up in cold weather but never seized.
  11. Sep 8, 2013 at 8:05 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    This looks familiar
  12. Sep 8, 2013 at 8:09 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Interesting. Never heard of that.
  13. Sep 8, 2013 at 8:10 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've never had snow in my intake on a stock intake. I don't see how pulling air from the wheel well you could get snow up the intake tube unless you cut the plastic fender well. Snow coming up over the hood shouldn't get into the intake unless you've modified something.
  14. Sep 8, 2013 at 8:17 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    This is probably the solution, but I just hate wrenching even a little bit when the conditions are right for my problem to occur. I'm not in the states now, but when I get there I will see if I can install some sort of quick fitting that could even be operated with gloves on.
    Description of one of the occasions:
    I wish I had a video of it, but a plow had made a single 10'pass through drifts up to 5 feet about 3-4 hours earlier and the wind was blowing 20-30 across filling it back up. I was driving 25-35 just to keep from getting stuck in the bit that was drifting back in. At one point there was so much snow going over the taco that I could see anything for 5-10 seconds and just had to guess from that last visual reference I had as to where I was on the road. One slip and into those big drifts on the side and it would have been sit in the car and wait until morning time to even start shoveling.
    Had a mate with me who was in serious driving mode as well at this point, but his girlfriend was screaming at him "I knew we shouldn't have come"! If she had been better prepared for the weather, her walking back the 30 miles to town and civilization would have been more seriously considered.
    Thanks for the advice.
  15. Sep 8, 2013 at 8:20 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Trust me, on three occasions in a 1 month period last January. Fender well not cut. The light fluffy stuff gets in there somehow.
    The first time I barely made it home due to the power loss and drifts I was having a hard time getting through. Next morning I checked the filter and the ice ball in the center was baseball size with almost the entire rest of the filter full of ice to the tops of the ridges.
    I assume it comes up through the well intake location.
  16. Sep 8, 2013 at 8:42 AM
    BamaToy1997
    Bill
    Navarre, FL
    Perhaps some sort of small, portable electric heater, like a camping heater, that runs off a cig lighter plug?Find one that would fit in/around the air filter housing. Just thinking off the top of my head. It has been many years since I had to worry about driving in the powder.
  17. Sep 8, 2013 at 8:55 AM
    ImplicitlyAlberta
    David
    edmonton
    That's crazy. How long is this drive your talking about.
  18. Sep 8, 2013 at 9:17 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Town to my cabin is 20 miles with the last 25 only having 3 ranch houses with 2 miles of the road.
    Driveway is a mile long also so I understand the family and friends that visit when I am working overseas tend to end up walking a fair bit of the time as the driveway doesnt get plowed unless I am home or a nearby rancher is feeling generous.
    Attached is a photo of a light dusting and another with the missus getting lesson from the deck @ 300m target (just to show the contours of the area which are not reflected in the first shot)
    Help is not readily available.
  19. Sep 8, 2013 at 9:28 AM
    B737
    Kevin
    Jersey Shore
    stock
    dude that place is awesome :)
  20. Sep 8, 2013 at 9:34 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X2
    OP, never had this issue myself, that's pretty crazy, I would never think of this happening. I remember asking a guy about his snorkel sucking in snow, but never stock. Where I am, we pretty much only get wet snow, no powder. Very rare that we do, if we do though, I'll have to check things out after a drive in it.
