Snow tips
Discussion in 'Off-Roading & Trails' started by NumNutz, Sep 29, 2009.
  1. Sep 29, 2009 at 8:31 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    At school in upstate NY and the taco is going to see a lot of snow this winter. I have BFG A/T KOs with less tread than I would like on them but I can't afford new tires right now.
    I run the tires at 44 psi (thats just what it says on the tire).
    Should I air down for normal driving say closer to 35 maybe if I know snow is coming?
    What other tips do you have snow specific? I am not completely incompetent when it comes to driving off-road and adverse conditions.
  2. Sep 30, 2009 at 10:38 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    You run your tires at 44psi on the street?
  3. Sep 30, 2009 at 11:02 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Yea. It's what the tire and the inside sticker on the door says... If I had known different I would but that's what I knew.
  4. Sep 30, 2009 at 11:17 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Best advise I can give ya: slow down and do the chalk test on the tires for the best psi,
    And when you think your going too slow, slow down some more...
  5. Sep 30, 2009 at 11:20 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    To your original question, add some weight (300+ lbs.) in the back. That and your 4WD should do you just fine in snow. Just keep in mind that stopping is no better than anyone else so take it easy.
  6. Sep 30, 2009 at 11:23 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Well it's good to know now. 32-35. I'll change that.
  7. Sep 30, 2009 at 11:38 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Should I fill it with sand or salt (doesn't salt only work at certain temps?) for use if I do get stuck?
    What are your suggestions?
  8. Sep 30, 2009 at 4:50 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I used sand in my 2wd ford. Sand bags worked really well. Salt is great to take as well. If you get stuck on ice just pour the salt down. If you have 4wd it will be a bonus. Added weight does affect mileage and stopping distances, so don't over load your truck too much. Like mentioned above 350lbs should be great
  9. Sep 30, 2009 at 4:57 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I just put cinder blocks in the back of my truck during the winter, and that worked fine.
  10. Sep 30, 2009 at 5:10 PM
    ChocoTaco08
    ChocoTaco08 Can't Fix Broke!
    Shooter
    MD
    08 DC 4X4 BSP
    [Tinted Windows]-[Clean Shaven Emblems]-[Husky Floor Liners]-[AVS Vent Visors]-[TRD Seat Covers]-[Tacoma Bed Mat]-[6000K H.I.D.'s]-[Coverking Backseat Covers]-[BHLM]-[Altezza Taillights]-[Scanguage II]-[Eyelids]-[Tinted Third Brake Light]-[Grillcraft Upper]-[Toytec Ultimate Lift Kit]-[BFG KM2's (285-70-17)]-[XD Revolvers (17X9)]-[PIAA 510's]-[All Pro Front Bumper]-[Cobra Cb]-[Wilson 4' Cb Antenna]-[BudBuilt Skids]-[Devil Horns Symbol]-[FLM]-[Demello Hybrid Sliders]
    stop burining tires for cool videos, that might help too. and no more drifting into driveways even though the snow makes it easier :D
  11. Sep 30, 2009 at 5:13 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    brake drums off transport trucks work too ;)
    just make sure you have them secured ...or they will be going through your back window in an accident
  12. Sep 30, 2009 at 5:19 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I run my BFG at 32 PSI. When the winter comes around, you can lower the PSI, so your tires have more contact with the ground = more friction. Take your time, don't speed, through some weight in the back of the truck.
  13. Sep 30, 2009 at 7:39 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Thanks for the advise danny!!! :D
    So 350lbs in the bed with sand. I can do that. I'll also drop my tires to 32-35lbs for normal driving and even lower for bad conditions as well. Sweet thanks everyone.
  14. Sep 30, 2009 at 8:02 PM
    C_Teachout
    C_Teachout Active Member
    Herkimer, NY
    09 Tacoma TRD Sport
    Im not far from you, about 1.5hrs in utica, I know how the lake effect can be in the area. I built a jig the keeps sand tubes that you get at the local home depot right ontop of the wheel wells. works great for traction. Sand will also absorb the humidity in the air and turn rock hard in the real cold fronts. Although they say were not supposed to get a bad one this winter always good to be prepared. Oh and enjoy CORTICA, sorry im a cortland fan haha
  15. Sep 30, 2009 at 8:12 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Oh no can't talk to you anymore lol. You gotta see our shirts for cortica. It's awsome.
    Front
    Back
  16. Sep 30, 2009 at 9:18 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Anther good thing to do: once it does snow, load up your ssandbags and head to an open parkinglot. Do some fast turns, braking, etc. and get a feel for how the taco handles the snow. The first time I drove mine on snow it scarred the S out of me because of all the traction control warnings beeping and stuff whenever I slid, took some getting use to.
