Snow tires in a 2wd MT taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sfish2002, Nov 16, 2022.
  1. Nov 16, 2022 at 3:43 AM
    Sfish2002
    Sfish2002 [OP] Well-Known Member
    Stanley
    2003 2wd M/T regular cab Tacoma
    Topper w/racks, bug/rock shield, hood thermal mat, bed liner, hitch
    I live in NJ and was considering putting snow tires on my old 04 2WD taco steel wheels and buying newer alloy rims for the street in summer. The plan was then just to swap the wheels according to the season. I was curious if anyone here has done this and if so, have you noticed any improvement in your winter handling or was it just not worth it? Thanks.
    SilverBulletII likes this.
  2. Nov 16, 2022 at 5:53 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would just start with weight in the bed, makes a big difference on my 2wd Nissan. Other than that I’ve heard good things about snow tires.
  3. Nov 16, 2022 at 5:57 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I'm in Maine everything gets winter tires! Good 3" on the ground/roads this morning.
  4. Nov 16, 2022 at 5:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Absoulutely worth it IF you have enough weather, not just occasional days. Doing all 4 is important because the tires will help with steering too. Couple hundred # over the rear axle will help some, just make sure it can't shift around.
    The biggest thing folks forget who have 4wd is that that's helpful to go. Not to stop. And those winter tires help the stopping a lot.
    SilverBulletII and Gen3TacomaOBX like this.
  5. Nov 16, 2022 at 6:50 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have at least 4 extra wheels if I plan on a long Interstate drive 300 miles plus.
    Snow tires and weight over the axle for the win. If studs are legal in NJ they are great for ice.
    If you really must venture out before the snow plows you can not beat chains .
  6. Nov 16, 2022 at 6:59 AM
    Sfish2002
    Stanley
    The thing is I have driven this truck in NJ since new and never really needed snow tires although it certainly has been dicey at times. I don’t use any bed weight either but I also don’t have many hills to go up and over either. I am wondering if it is worth the cost to most similar drivers as I guess I got used to this truck handling like crap in snow.
    We probably don’t get enough snow in NJ to make them worth it but was wondering if anybody else thought similarly or if I am the only crazy person who drives all seasons in the snow with 2wd.
    I wholeheartedly agree about 4wd only helping you to start not to stop. Almost all the cars I see spun out on the side of the road in winter are 4wd vehicles driven by folks who don’t know enough not to overdrive them based on the conditions. Studded tires is a good option I had not considered.
  7. Nov 16, 2022 at 7:08 AM
    Bivouac
    Myself I live in the hills with my Celica RWD I needed the weight just to get out of my 500' up hill drive way.
    You know what your dealing with if you don`t feel the need for snow tires only you know.
    I have chained up on the rear axle and taken extra mounted tires and swapped once out to plowed roads out of the hills.
    It comes down to what will work for you.
    Yes Snow tires and weight do improve winter driving but the best will be experience .
    Good luck.
  8. Nov 16, 2022 at 7:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    You live down here in South Jersey don't you.
  9. Nov 16, 2022 at 7:22 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    From a guy who's had several small 2wd trucks in Ohio. Studs & weight & done.
    Bivouac likes this.
  10. Nov 16, 2022 at 7:32 AM
    Bishop84
    Bishop84 Well-Known Member
    It makes a massive difference, make sure to get directional tires to push the wet and slush out better.
    I imagine NJ winters to be very wet and sloppy.
    Studs are a good idea with the cheaper tires (westlake, uniroyal etc), otherwise the top tier tires (blizzak, xice etc) don't need them and typically out perform studs.
  11. Nov 16, 2022 at 8:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    Once upon a time, not so very long ago, that's what 99.42% of folks had to drive with. Not to mention that 'all seasons' didn't exist. And in reality, they still don't. They are more of a 3 season, flake ratings or not.
    Bivouac likes this.
