Snow tires question
Discussion in 'Wheels & Tires' started by allisonguru, Jul 31, 2010.
  1. Jul 31, 2010 at 1:50 PM
    allisonguru
    allisonguru [OP] Member
    Dave
    California for now, Indiana here we come!!
    2007 TRD Prerunner 4x2
    Im moving and am new to snow conditions, so my question is do i have to get snow tires for the front and rear, or just rear? Its an 07 TRD 4x2
  2. Jul 31, 2010 at 1:53 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're going studded, I'd get all 4. You always want good tires on the front because thats what stops and steers the truck. When I drove a 4x2, I had aggressive M+S rated tires on the rear, and decent all seasons on the front. The drawback is having different tires for tire rotation.
  3. Jul 31, 2010 at 2:56 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    What state do you live in? That will greatly determine the kind of tire that will meet your needs.
  4. Jul 31, 2010 at 3:25 PM
    allisonguru
    Dave
    Well for now, we live in Southern California. But i am being relocated to Southern Indiana.
  5. Jul 31, 2010 at 6:10 PM
    Pugga
    Massachusetts
    Putting more aggressive tires on the rear only helps you accelerate. You really need good tires on the front to turn/stop. At the least, a good set of all seasons all around will work just fine with some weight at the front of the bed. I use 3 - 90lb tractor weights at the front of the bed but you can use sand bags also. That way you have some sand if you need to put it under the tires if you get stuck. Just drive with a very light foot to keep from fish-tailing and go easy on the brakes so you don't slide off the road.
  6. Jul 31, 2010 at 6:54 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Same 4 tires all around. Get a set of decent ats or cheap snow tire and you should be good.
  7. Aug 1, 2010 at 7:47 AM
    Voodoo Rufus
    Bakersfield, CA
    I'd go with what Lusetaco said above.
    Maybe a good "performance snow" tire would be a good choice for you.
  8. Aug 1, 2010 at 8:01 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    If you get snow tires, get 4. Mixing tires is a bad idea for slick conditions. Since you're moving to southern Indiana as opposed to Buffalo, NY, you could get away with using a good A/T tire year round (Revos, Nokian Vatiiva) rather than a dedicated snow tire as long as you don't run the tread depth below ~ 6/32" in the winter.
    Tires with dedicated winter compounds (e.g., Blizzaks) are really intended to be used where it's cold and stays cold for months at a time. Southern Indiana is on the edge of that area. It could snow 18 inches one day and be 55 degrees the next.
