Snow Traction Ideas
Discussion in '4 Cylinder' started by bozotaco, Nov 13, 2010.
  1. Nov 13, 2010 at 1:54 PM
    bozotaco
    bozotaco [OP] Well-Known Member
    Montana
    04 Tacoma
    Bought my first Tacoma in September of this year, and love it so far. I had a 4Runner before as well as a bunch of crappy cars so this tacoma will be my longterm baby. Bought her with 75,000 miles on her and a topper. It also came with some American Racing rims, which I actually like. I added a custom sleeping platform in the back that lets me put skis underneath and sleep on top. Anyways here are a couple pictures. I don't have enough cash for new tires, so I'm wondering about getting my current tires studded. Hopefully then in the spring ill have some tax return monies for new tires. Has anyone gotten there tires studded? Also I was driving in our first real snow storm and slid out going 55, it was a bit scary. So I added a 150pound trailer weight to my bed. Any ideas on where to position it in the bed? Thanks alot, this site is awesome.
  2. Nov 13, 2010 at 2:02 PM
    dlthunder
    dlthunder Well-Known Member
    Dan
    Reno, NV
    Sold my Taco
    TRD Skid Plate Rear Seat 11inch DVD Toyota Bed Mat Pace Edwards Full Metal Jackrabbit Nerf Bars Tailgate Electric Dynolock D-ring Bedbolts
    I use studded tires and normally there is no way to stud tires once they are driven on. You would have to buy new tires that are pinned for studs and have them studded before driving on them.
  3. Nov 13, 2010 at 2:08 PM
    Pat 13
    Pat 13 Hillbilly 4X4
    Harpers Ferry, WV
    11 Tacoma V6 DC 4X4 TX Pro
    Get chains and put the weight as far back as possible. Also you can use sand and ice melt for weight and if you get stuck.
  4. Nov 13, 2010 at 2:12 PM
    bozotaco
    Montana
    04 Tacoma
    Ive had two friends with Subarus get the tires they had been driving on studded. So I think it's possible, and cheaper than buying new tires.
  5. Nov 13, 2010 at 2:26 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    wrong. weight will do you the most good if you put it directly over the axle - too far back and you're taking wieght off of the front end.
    I keep about 120lbs of sand in the back and a light foot on the pedals. occasionally I have to kick it into 4x4 to get going from a dead stop but otherwise I have had no trouble driving in the winter around here. You might want to look into syping the tires as well. Still won't do what a good, deep tread will in snow but it helps.
    oh and howdy neighbor :wave:
  6. Nov 15, 2010 at 11:03 PM
    bigskytacoma
    bigskytacoma Active Member
    kevin
    montana
    06 4x4
    Arb front bumper Cbi Rear bumper Ome suspension Shockworks sliders Firestone desination M/T
    hey man. i live in bozeman too. i have a 2006 silver tacoma that is locked, lifted and armored all the way around and i run copper discoverys M/S with studs in the winter. I commute to big sky 5 days a week in the winter to work and ski and my truck does great. I think the tire has to have the holes for them to be able to be studded. usually costs around 15 bucks per tire. Keep you eye out on craigslist you can probably pick up a set pretty cheep.
  7. Nov 15, 2010 at 11:06 PM
    bigskytacoma
    kevin
    montana
    06 4x4
    x2 for the weight over the axle
  8. Nov 15, 2010 at 11:25 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yup ^^^^^ ;)
  9. Nov 15, 2010 at 11:37 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Some tips for you:
    1. Weight over the rear axle is helpful. I like sand bags, about 150lbs seems perfect in my extra-cab with cap. Really makes a difference.
    2. Check out tire siping. It is cheap and helps somewhat. And does not effect drivability year round.
    3. You can get ANY tire studded, even used ones. No problem. But then you have to get unstuded tires (and probably another set of rims too) for the summer season.
    4. Chains are a good option. Go for low profile Type S chains made from alloy. You'll be limited to 40mph or lower speeds.
  10. Nov 16, 2010 at 6:12 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Studs help on the ice , not really any in the snow (thats more the tread and compound),....unless the snow has been packed down hard.
    Speed of 40 mph on chains , u may have had a typo , the max speed on chains is 20 mph if i recall. Faster and the centrifugal force (spelled right??) and balancing get real rough or break the chains. Also consider a lower tire psi , nothing drastic , perhaps 2-4 lower.
  11. Nov 16, 2010 at 6:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  12. Nov 16, 2010 at 9:03 PM
    bozotaco
    Montana
    04 Tacoma
    Lots of good advice, I appreciate it. My 150 pound trailer weight works well, and I definitely agree that over the axle is best. Chains are an option, but being limited to 40 mph doesn't do much for me. In 4 wheel the truck is a beast, but my concern is 50+ driving. So I was hoping to some studded tires would allow me to go 50+ in 2 wheel. Would be possible(and cheaper) to only buy studded tires for the rear? Its snowing out so I dont want to run out to the truck with a flashlight but my tires have some good treads, maybe a bit less than Geolander AT's(on my old 4runner) so with if I did get those studded would that be a good setup? Thanks for the advice
  13. Nov 16, 2010 at 9:07 PM
    bozotaco
    Montana
    04 Tacoma
    Also I don't agree that studs don't help on snow. Here in Montana a good portion of winter driving is on packed snow(our city has an strange plow ideology). Ive had a subaru with studs and compared to other friends subis without studs the difference is definitely noticeable. I have to admit an AWD Subaru with studs has its advantages, but it doesn't beat a Tacoma
  14. Nov 16, 2010 at 9:10 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Why do you need to drive that fast on snow...that's how accidents happen. Alot of the trucks and suv's around here make that mistake and are usually the ones flipped over on the side of the road.
  15. Nov 16, 2010 at 9:18 PM
    bozotaco
    Montana
    04 Tacoma
    I'm not sure where the land of lava is, but here 50mph is an every day event. I drive 45 miles a 3+ days a week to Big Sky, on the road the speed limit is 65 (HWY 191) with slednecks with F550's going 70 and passing. Being able to go at least 55 mph is a bit safer.
  16. Nov 16, 2010 at 9:18 PM
    bozotaco
    Montana
    04 Tacoma
    And its snowing about half the time
  17. Nov 16, 2010 at 11:39 PM
    bigskytacoma
    kevin
    montana
    06 4x4
    hahaha. he is not kidding in the slighest
  18. Nov 16, 2010 at 11:47 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    With a rear wheel drive vehicle, you really only need studs in the rear though studs all around might make you feel safer. However, as others mentioned, given the dry snow you have up there, studs won't really help on snowpack much at all. Their benefit is on hardpack and ice. As for driving in 4hi, you should be able to do 50+ ... that is as long as the road is snow packed (i.e. not dry pavement). Then again people doing 50+ on snowpack need to slow the hell down! LOL.
  19. Nov 17, 2010 at 5:11 AM
    Pugga
    Massachusetts
    I couldn't disagree with you more on only studding the rear wheels... what's more important, acceleration or being able to steer and stop?
  20. Nov 17, 2010 at 6:09 AM
    Tacoyota
    08 4wd
    Oregon requires purchasing 4 studded tires , cant buy just 2 . This is mostly based on the non studded tire on a 2wd sliding. Ususally a front whl drive would buy 2 only to have the rear whip around on them causing an accident , steering loss on a rear wd too.
    Check out "severe weather" rated tires....a mountain symbol with a snow flake in it , most states consider them equal to studded(studded tire alternative) , easier on the roads too, i love em , most manufacturers have 2-4 models available.
