Snowplow on a Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xewkija631, Dec 13, 2011.
  1. Dec 10, 2017 at 10:46 AM
    #81
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Great thread & info. guys! Anybody got some pics of weight boxes? I'm not quite sure about placement & capacity with the composite boxes Toyota uses.
  2. Dec 10, 2017 at 11:45 AM
    #82
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    I ended up going to Home Depot and buying four large concrete blocks. They're about 18" x 10 " and about 4" thick.
    I also bought a large heavy duty outdoor storage box.
    Originally I thought of putting the blocs on their side, four across the bottom of the box, which they fit well and it was heavy enough.
    However, as I was prepping for the upcoming storm. I realized that the box would be better filled with sand from the DPW.
    The issue is that the sand also has salt in it and would eat away the blocks.
    So, right now the blocks are sitting flat in the bed of the truck over the rear axle and the box is in front of the bed to stop the blocks from sliding forward.
    It worked in that I also left the snow in the back, but I'm going to have to get down to the DPW and get some sand for the box, then tie it down with the blocks on the bed behind it.
    Others use sand bags, but Home Depot didn't have any. Well at least according to the clerk who helped me.
    Interested in what others say.
    Jim
    FastEddy59 likes this.
  3. Dec 12, 2017 at 5:31 AM
    #83
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I think people will say the problem with using cinder blocks in the bed is in the event of an accident they could become dangerous projectiles. Several tubes of sand might be a little safer I guess.
  4. Dec 12, 2017 at 5:38 AM
    #84
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Tubesand frozen solid will come through a back window just as fast as cinder blocks if you're in an accident. That's why I've switched almost exclusively to snow as ballast for my plow truck. I used to do tube sand in a box, but didn't trust it to hold still if I went off the road so I stopped.
    Coolerman and FastEddy59 like this.
  5. Dec 12, 2017 at 5:42 AM
    #85
    Coolerman
    Dan
    Rochester, NY
    When I was younger I had a car that needed weight in the rear. We used to keep a large plastic container with chicken grit in it. The chicken grit could double and be used for traction for someone who was stuck. I guess it wont melt and freeze if you put it down for traction? Anyhow, just another option.
  6. Dec 12, 2017 at 5:49 AM
    #86
    Noelie84
    Noel
    Wales, Maine
    I keep a 5 gallon bucket of salted sand in the driver's front corner of the bed; if I'm in an accident it won't go anywhere because it's already at the front of the bed. The snow keeps it from moving around while I drive.
  7. Dec 12, 2017 at 5:53 AM
    #87
    FastEddy59
    Eddie
    I melted a bucket of old tire weights once & before it cooled, I stabbed a piece of half in. pipe through it. Once cooled I just bolted it to the box slightly back from the rear axle centre. Worked great, but that was an old steel boxed truck. With composite boxes, there's no way I'm doing that but I agree. It better be well secured or you could be wearing it. Cops check for this all the time here.
    Manfred likes this.
  8. Dec 12, 2017 at 3:32 PM
    #88
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Snow works ok until...
    Back in the late 80's, I had a black 82 K10 and used to leave the snow in the bed mainly out of being young and lazy. Well, the sun melted the snow a bit and then refroze into a solid block of ice. It broke free of the bed and slid forward bending the front of the bed pretty darn good. I'd imagine if I was in an accident where the ice was launched up it would have come through the back window.
  9. Dec 13, 2017 at 4:43 AM
    #89
    Noelie84
    Noel
    Wales, Maine
    My plow truck's white, so the melting is less of a problem :notsure:
    It does melt and refreeze, but I keep the bed loaded up in good shape so there's really nowhere for it to slide to.
  10. Dec 14, 2017 at 3:23 PM
    #90
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    OK, I hit a problem today. My battery was dead.
    After I jump started it, I disconnected it from the plow and then checked to be sure the alternator was working. It was.
    I got the battery charge back to 12.6 Volts and I'll check tomorrow to see if it held the charge. We're having really cold weather here and it might be the battery, but it's only 2.5 years old.
    I started to wonder if using my flashers and headlights while plowing, put an drain on the battery which the alternator couldn't keep up with?
    I'm hoping that the plow isn't putting a drain on the batter even though it was off.
    Jim
  11. Dec 15, 2017 at 5:19 AM
    #91
    Noelie84
    Noel
    Wales, Maine
    If you've got an electric or electric over hydraulic plow setup just moving and positioning the plow can take a toll on the battery's charge (most of the professional plow guys that I know run a dual battery setup because of the draw of the plow, sander, and additional lights they've got mounted), but it's odd that it'd be that flat if you're just doing your own driveway.
  12. Dec 15, 2017 at 5:52 AM
    #92
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    How old is your battery?
    Some batteries don't like the cold.. Might be time for a new Battery..
  13. Dec 15, 2017 at 8:56 AM
    #93
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    The Battery is only 2.5 years old and I checked it and the alternator, both are working fine.
    I'm starting to think that having the emergency flashers on while plowing, I may have shut off the engine to clear the other
    cars off.
    Either Way, it's working fine now, but I'm going to not use the emergency flashers.
    Thanks for the help
    Jim
  14. Dec 15, 2017 at 9:07 AM
    #94
    Noelie84
    Noel
    Wales, Maine
    Is your plow electric over hydraulic? Because I've never run a battery dry plowing with the Dodge, even with the headlights on, the spotlights on, the flashers on, and the whirly light going on the roof. And my alternator only puts out 60 amps or something like that. But, my plow is all hydraulic, so there's no electrical draw to adjust/lift/lower it.
  15. Dec 15, 2017 at 9:07 AM
    #95
    smcgill
    Sean
    upload_2017-12-15_12-7-10.jpg Magnetic....
    JimROCDS likes this.
  16. Dec 15, 2017 at 3:28 PM
    #96
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    It's hydraulic, but of course the hydraulics are driven by electric.
    Anyway, I'm gonna get a battery operated magnet mount light for the roof. :D
    Jim
  17. Dec 16, 2017 at 12:10 PM
    #97
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    Well, I'm 99% sure it's the battery.
    We've had really cold nights here.
    I checked the voltage without a load. 12.5 and it turned over slow, but I managed to get it started. Checked the alternator and was getting 14-15.5 volts with lights and radio on.
    Waited a couple of hours and went back out. Checked the battery before starting, only 11.3 volts.
    Then shut it off.
    Had my wife start while I had the volt meter on and the battery dropped to 4 volts. It should not drop below 10 volts. Looks like the starter isn't getting the amps needed to kick the engine over.
    Anyway, I checked again and I bought the battery in May of 2015, but it could've been older, I can't see the mfgrs date on it, so it's possible that it's 3 years old and where I bought it, it may be a rebuilt.
    So, off to get a new battery tomorrow.
    Jim
    Noelie84 likes this.
  18. Dec 16, 2017 at 2:09 PM
    #98
    Noelie84
    Noel
    Wales, Maine
    Yeah, that sounds like at least one bad cell.
  19. Dec 24, 2017 at 9:47 AM
    #99
    JimROCDS
    Jim
    Massachusetts
    Tacoma
    Yep, got a new battery which puts out 700amps of cranking power. Starter requires at least 600amps
    Kicks over like new.
    Also, bought a magnet mount amber flashing light for the roof.
    Plow works great !
    Jim
  20. Dec 25, 2017 at 3:24 AM
    #100
    smcgill
    Sean
    :worthless:
