Snugtop on 99 Tacoma,do I need to cut bedliner?
Discussion in '1st Gen. Tacomas (1995-2004)' started by baachor, Mar 27, 2010.
  1. Mar 27, 2010 at 10:10 AM
    baachor
    baachor [OP] Member
    Costa Mesa,CA
    99 Tacoma LX
    Hi folks,
    did google and search here,but can't find answer:
    Do I need to cut out top part of bedliner to fit Snugtop shell in?
    I bought it from guy who said I need to cut it in order to fit it right.It is bit tight now with bedliner.Was thinking to cut just back top part bit since can't close door properly.
    Dont want to cut it for possible later use.Maybe I will just remove bedliner,or cut just in the back.
    But when I saw some pix,looks like it is made to fit tight with NO bedliner.
    Any suggestions?
    Thank you,
    Paul
    adding: forgot that i'm using universal clamps,not the shell ones
  2. Mar 27, 2010 at 1:25 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Um, I did cut the original bedliner that I had when I got a cap. I subsequently got another OEM liner that goes under the bed rails though, so it solved the problem.
    Just cut the holes that are already in the liner up higher...
  3. Apr 26, 2010 at 7:34 PM
    baachor
    baachor [OP] Member
    Costa Mesa,CA
    99 Tacoma LX
    thanx for reply,
    I've had to cut it,Here's few pix of how I did:
    I was doing it by myself!
    First I marked it with marker.
    Than I slided the cap on one side of the truck and let it support by ladder.That way I had space to cut other side from outside [without going inside the cap].Also did some of the "behind the cab" side.
    Than moved it on another side and finished the rest.
    Slide it back and tided it. Connected the brake light thanx to this post:
    http://www.tacomaworld.com/forum/1s...-brake-light-my-camper-shell.html#post1627481
    Hope this helps someone.
    P.
  4. Jul 22, 2013 at 4:35 PM
    gnstalodz
    gnstalodz Well-Known Member
    ca, bayarea
    02 PreRunner Doublecab
    how clean does it look? Any tips? Any issues?
  5. Jul 29, 2013 at 8:48 PM
    baachor
    baachor [OP] Member
    Costa Mesa,CA
    99 Tacoma LX
    I think that's the best way to do it (without removing whole bed liner). It looks good. No issues whatsoever. Note thou that I don't open back,just the camper window (too much stuff in). The bed liner still holds on original screws. Cut it just tiny bit more then you need for camper shell.
