So, a few years in, Gladiator thoughts?
Discussion in 'Off-Topic Discussion' started by BuddyS, Aug 5, 2022.
  1. Sep 12, 2022 at 11:39 AM
    #41
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Coondawg07 and Scott W[QUOTED] like this.
  2. Sep 12, 2022 at 9:22 PM
    #42
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The trucks are cool in concept.
    Pros:
    Topless/doorless 4x4 pickup
    Solid axles front and rear
    Available front and rear lockers from the factory
    Amazing 8spd auto
    Ability to run 37s on a stock Mojave trim
    Far more off road oriented than anything Tacoma
    Very utilitarian (pro/con depends on the user)
    Less mods are necessary to build an ultimate off-road monster
    Cons
    Cost, priced higher than a Tacoma
    Lack of storage space, despite the vehicle being larger
    The truck is a fair amount larger than a Tacoma while having little to show for it functionally
    Wheel base is long, the truck is 6" longer than a DCSB Tacoma but the wheel base is 10" longer
    Guts hang below the frame rails giving low ground clearance and making things like the gas tank vulnerable, with long wheel base it has reduced break-over. The Tacoma keeps it tucked above the frame rails.
    The solid front axle makes the steering wander and numb, but you quickly get used to it.
    Quality. FCA/Stellantis is consistently among the absolute worst rated vehicle manufactures in quality, while Toyota has a long standing reign as best.
    Here is my Gladiator 3.6 engine block at 14k miles at less than a year old. It was running a Magnuson Supercharger, same as the OEM Toyota units. Threw a rod through both sides of the block. I am absolutely certain this was poor quality manufacturing on the engine internals. No additional mods were made to the engine or supercharger. I put way smaller pulleys on my Magnuson supercharged Tacoma, intake, fuel pump and abused that thing way beyond the intended design for 65k miles and it never once blinked. Highly modified pushing way beyond intended power and the most reliable vehicle I've ever owned. Stock supercharger on the Gladiator and it grenades. Cool trucks, but I will never again own a FCA/Stellantis product.
    MalinoisDad, Burns and b_r_o like this.
  3. Sep 12, 2022 at 9:55 PM
    #43
    Coondawg07
    Coondawg07 Master of none
    Alabama
    2016 DCLB BBP
    I’ll throw a vote in that’s already been cast multiple times. If they would be build a single cab, I’d be a definite buyer.
    SwollenGoat likes this.
  4. Sep 13, 2022 at 9:38 AM
    #44
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    And the truck currently has 83,520 miles and still going strong like new.
    crashnburn80[QUOTED] likes this.
  5. Sep 13, 2022 at 10:27 AM
    #45
    SwollenGoat
  6. Sep 21, 2022 at 8:05 PM
    #46
    5efvz
    5efvz Well-Known Member
    Looks better than Tacoma. But not as reliable (?).
  7. Sep 21, 2022 at 8:15 PM
    #47
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I briefly considered a 6 speed Wrangler until I read about the manual transmission recall (affects manual Gladiators too) that was “fixed” with software to nerf engine torque down so your effing pressure plate won’t overheat and grenade, possible sending shrapnel wherever it wants to go outside of the transmission. Yeah. Great…
    That’s right. A mechanically inferior part was identified and rather than replace it, neuter the engine so it can still utilize the garbage part. Customer gets it in the shorts with a timebomb of a problem that won’t be cheap. And I’ll bet their advertised torque specs won’t be changed even through the recall is mandatory and definitely changes them. Sad. Lame. No Jeeps in my future unless I find a 99-01 Cherokee. And I ain’t lookin.
  8. Sep 21, 2022 at 8:20 PM
    #48
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Wheeled with a Gladiator on 42 inch tires a few weeks ago.
    He was having a harder time with easier lines than I was... in my 1st Gen Double Cab with 380,000 miles on the clock on 35s.
    That's all I need to know... no thanks.
    And BTW. The guy driving the Gladiator isn't new to wheeling or anything.
  9. Sep 30, 2022 at 10:53 PM
    #49
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I'm over driving vehicles with flat windshields, open fenders, solid axles, and aerodynamics from the 1930s. That was a time and place in automotive history that can belong in the past. I think it creates a higher level of driver fatigue on long trips highway trips. In the past couple of months, I've seen an unusually high number of them on the Honda dealership lot. It's fun to play around with a design from the 1930s for a weekend or short haul -- but gets old in a hurry.
  10. Oct 1, 2022 at 12:09 AM
    #50
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I heard there were issues with the 3.0 ecodiesel when it came out for the ram initially. Now they are on the 3rd gen ecodiesel, and I haven’t been able to find any issues with them besides the egr cooler failing sometimes.
    Funny enough, it was just announced that the diesel wouldn’t be offered in Wrangler after 2023, but will still be an option for the JT.
