So... after airing down to 15 psi, you knock a bead loose and go flat
Discussion in 'Off-Roading & Trails' started by pearing, Jan 8, 2021.
  1. Jan 8, 2021 at 6:25 PM
    pearing
    pearing [OP] Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    How does one extricate themselves from that situation (assuming you have a jack and a compressor...)?
  2. Jan 8, 2021 at 6:32 PM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    If you bust a bead starter spray and a lighter )
    US Marine, whatstcp, wilcam47 and 3 others like this.
  3. Jan 8, 2021 at 6:34 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Ratchet strap around the tire to compress it. Then fill it up with air. If you blow a bead at 15 PSI something is way wrong though. I go down to 8 psi all the time and hardly ever loose beads.
    C41n, SLeeper512, POSTacoMike and 8 others like this.
  4. Jan 8, 2021 at 6:35 PM
    jandrews
    '09 FourDubDee TRD OR
    The most straightforward option is your *spare tire*.
    If you absolutely must re-seat the one off the bead, you'll need some flammable spray and something to ignite it with. Having a fire extinguisher on hand for this is a good idea just in case, but it does work.
  5. Jan 8, 2021 at 6:35 PM
    jandrews
    Bad judgment can be surprisingly effective at hard-to-obtain results.
  6. Jan 8, 2021 at 6:37 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  7. Jan 9, 2021 at 5:08 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Story of my life...
    C41n, POSTacoMike and Juice Weasel like this.
  8. Jan 9, 2021 at 5:10 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Thank you-I am going to practice the procedure. Yes I have a spare...
  9. Jan 9, 2021 at 11:37 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    A lot depends on tire/wheel size/type.
    Naveronski likes this.
  10. Jan 9, 2021 at 11:49 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I use the ratchet strap trick with CO2 first.
    If that doesn’t work, starter fluid and lighter to seat the bead. This method is especially helpful for those bigger tires with stubborn inner beads.
  11. Jan 9, 2021 at 5:04 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Take the tire off the truck, clean sand/crap out of the seating area, put the wheel (not tire) on something broken bead side down to elevate the tire, press down on the tire while airing it back up. A ratchet strap can help as can lubricating the bead with whatever you have banging around in someone's tool box. Its also easier with the highest volume compressor your group is carrying.
    SLeeper512 likes this.
  12. Jan 11, 2021 at 5:28 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I did that trick once, using gasoline... worked like a charm! Only wish someone recorded it!
    whatstcp likes this.
  13. Jan 11, 2021 at 5:45 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    A spare tire?
    The fire method works, but is also really dangerous.
    I carry a portable air tank (and a compressor) for this reason, although I haven’t tried rebeading with the tank, but it’s gotta be better than just a compressor.
  14. Jan 26, 2021 at 9:45 PM
    ArtP
    ArtP Well-Known Member
    Art
    Lake County, CA
    2003 Tacoma 4x4 Manual TRD
    Interesting idea to blow up the inner part of the wheel/tire. I have a question though.
    My off road playground takes me 18 miles of dirt road to get to and has its share of washboards. I like to air down for better traction and a softer ride. How much is too much? I like to go 16 pounds but would like to go down further. It's not just the bead I worry about, but the health of my tires. Can it be good to run your tires at up to 45mph for 18 miles (average 20)? Or should I wait until I realy need it?
  15. Jan 27, 2021 at 5:21 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Every single tire, and truck setup is different.
    You need to make this call. You need to get out and check your tires, are they to hot? How do you check and know? Easy as put your wrist on the sidewall, just like a baby bottle. If it's to hot to touch, you are doing it very very wrong!
    I know how I check.
    I dont tend to go below 15 PSI in the summer often its 20 or so. In the winter 5 PSI can be the trick that we run at all day. Every single day and adventure is different.
    MR5X5 and SLeeper512 like this.
  16. Jan 27, 2021 at 7:39 AM
    David K
    Speed is your enemy when deflated IF you turn suddenly, brake suddenly, or hit a rock fast. 4WD allows you to go slow, save the parts, keeps the tires on the rim. I have gone as low as 6 psi (once) in sand when the tide was rising and the sand was super fluffy. That was long ago, in my 2001 Tacoma... now, 15 psi is the lowest I have gone using the tires I do (Hankook DynaPro ATm) with my 2010 Tacoma.
    SLeeper512 and doublethebass like this.
  17. Jan 27, 2021 at 10:51 AM
    jbrandt
    Justin
    As @llamasmurf said, that depends. Everyone is different, with different equipment and skill levels.
    Why do you think you want to go lower? I highly doubt you'll find a significant improvement in ride "softness" on gravel roads going any lower than 16. For that, you'll need nicer shocks. I don't really see a need to go lower for non-technical dirt roads. The lower you go, not only do you run the risk of blowing a bead if you turn or brake suddenly, it also negatively affects your handling. It's like driving on sponges, lol. Also the heat, as mentioned.
    I typically air down to ~18psi the minute I hit dirt. I pretty much leave it there unless I get to a technical section and I need more traction. I've never gone lower than 10, I spend the vast majority of my time at 15-18psi.
    SLeeper512 and llamasmurf like this.
  18. Jan 27, 2021 at 1:39 PM
    David K
    The type of tire and the vehicle weight will dictate the pressure. Most all terrain tires do fine at 15-20 psi off road for floatation in sand or smooth riding on the rough stuff. However mud terrain, aggressive tires and 3-ply sidewall tires need to have more air removed. Cooper Discoverer STT tires and BFG All Terrain TA tires (for example) need to be dropped to 10 psi to equal what 18 psi does with my Hankook DynaPro ATm tires.
  19. Feb 27, 2021 at 10:35 PM
    jbrandt
    Justin
    What ever you do, I would highly suggest practicing at home, you know when you can just walk inside if it doesnt work. Or get another beer.
    Use an old spare tire, or even head to the local tire shop and they’d more than likely give you an old tire they were going to toss anyway. A 6 pack never hurts to help grease those wheels, as it were...
    sbb and whatstcp like this.
  20. Mar 23, 2021 at 11:28 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I re-seated the bead on all 4 of my tires after removing the TPMS in each of them. This was done in my driveway with minimal tools
    These were KO2's and the bead was just begging to go back to its home, I had to fight to get it to compress to the point where I could comfortably ( and safely ) fit my hand in to remove them. This made it easy to re-seat. I just had to inflate them. I did remove the core out to remove any possible air flow restrictions. Did it help? IDK, but it worked. 4x in a row. ( oh and I used dish soap to lube up the bead, not so much for it being lube, but more to help the initial seal )
    I've had great luck with ratchet straps on smaller tires ( snow blower ) and I've used the fire trick on smaller tires ( snow blower ) but I've never had to use either one for a large vehicle tire. If the bead is not catching to the point where its holding air I usually just stand on the rim ( keep them toes out of the way! safety sandals can only protect you so much... ) with some 2x4's under the tire to "lift" it off the ground giving the rim room for my fat @$$ to push it down. One time I think I bounced the tire on the ground while inflating to get the bead to catch the rim.
    all it takes is a little bit of a seal and your in business.
