So-Cal wheelin trip September 12th-14th
Discussion in 'Northern California' started by SpeedwayBlueAlex, Aug 11, 2014.
  1. Sep 4, 2014 at 8:57 AM
    #301
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Oh yeah, I remember that mag mount now. So it fell off and pulled the coax with it?! :confused: I figured the coax would've kept it at least in-tow.
  2. Sep 4, 2014 at 10:32 AM
    #302
    MonteroBoss
    MonteroBoss Member
    Jonny
    Fresno
    1990 Mitsubishi Montero RS
    Aussie Locker (F), Limited-Slip (R), cranked torsion bars (F), OME coil springs (R)
    The antenna just slipped off the base, the base was attached with coax but no actual antenna was left.
  3. Sep 4, 2014 at 2:10 PM
    #303
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Aw that's lame!
  4. Sep 4, 2014 at 9:11 PM
    #304
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    apparently I forgot or didn't check the tightness of the screw at the base of the antenna...probably wasn't tightened for over 30 years :eek:
  5. Sep 4, 2014 at 9:12 PM
    #305
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    no firestick is lame. I like the magnetic mount. I just bought a replacement antenna but the base is too big and doesn't fit in the mount. I gotta go to the store and look for a new whip.
  6. Sep 4, 2014 at 9:14 PM
    #306
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    What do you guys think I should check? I checked the truck stops up north but I don't know if there are like Flying J's or Love's down here??? Maybe 4 wheel parts or something. They can't rip me off too bad for just a whip ?!
  7. Sep 4, 2014 at 9:15 PM
    #307
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Ah that makes sense.
    I'm a fan of my wilson 1000. Great reception. I think my tx is limited by my radio, 'cause it's not very good, but I don't think it's a problem with my antenna. The magnet is great, too. User Lusetaco has a dcsb 2nd gen and has or at least had a wilson 1000 and got great performance from it. He recommended it to me.
    :cheers:
  8. Sep 4, 2014 at 9:16 PM
    #308
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    There's a truck stop (Love's or flying J or both) in Castaic before you head up the grapevine. You could check there!
  9. Sep 4, 2014 at 9:19 PM
    #309
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Yes sir I remember now...I was just thinking san diego...So Cal haha who needs a truck stop here? There's a McDonalds or In n Out every exit pretty much.
  10. Sep 4, 2014 at 9:20 PM
    #310
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Yeah I was eyeballing the Wilson 1000 but I already have a base and it works...all i need is an antenna whip. i Ordered a 62.5" replacement Wilson whip but it doesn't fit into the base on the mount. If I can't get anything to work at the truck stop or 4 wheel parts then I'll prob go the Wilson 1000 route.
  11. Sep 4, 2014 at 9:30 PM
    #311
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    I thought the base was kinda weak, which is why it fell over?
    Either way, did a quick search and found this: http://www.findfuelstops.com/truck-stop-in-CA
    Might be able to check some of those! A little far from Escondido (Miramar seems to be the closest) but that's about it for San Diego.
  12. Sep 4, 2014 at 9:34 PM
    #312
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Good find Kevin! Yeah the base may be a little weak...how much does a wilson 1000 go for? I'm assuming the coax is the same from the one I have to the wilson 1000?
  13. Sep 4, 2014 at 9:50 PM
    #313
    SpeedwayBlueAlex
    SpeedwayBlueAlex [OP] Well-Known Member
    Alex
    Modesto
    SWB 4x4 TRD OFF-ROAD 6-SPEED
    Hahahaha dont even get me started on that
  14. Sep 4, 2014 at 9:50 PM
    #314
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    http://www.rightchannelradios.com/wilson-1000-magnet-cb-antenna-62.html <--Amazon has it for $10 cheaper, btw
    The antenna comes with the coax already wired in, so you basically just route the coax to your radio, tune it, and go. Mine didn't need any adjustment after I put the antenna in about half way, so it was basically just a plug and play, super easy.
    You might as well try a truck stop and look for a whip since you already have the magnet, but I wouldn't trust the magnet too much with a whip in the rocks. I've had my antenna really whipping around and I could hear the magnet lift off a little bit or pop out the roof a little. It sounded just like the antenna hit a tree hard but there wasn't anything for it to hit, unless it bent back and hit the roof of the camper shell.
  15. Sep 4, 2014 at 9:54 PM
    #315
    SpeedwayBlueAlex
    Alex
    Modesto
    Im sure john and I will caravan down to socal since we are both going down 99. Dont worry john I wont be late;) anyone else goin 99 south thats wants to meet up ??
  16. Sep 4, 2014 at 11:22 PM
    #316
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    I'm down
  17. Sep 4, 2014 at 11:49 PM
    #317
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Decked Drawer system, aFe CAI, Borla Cat-back exhaust, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts, Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights... It has more stuff done to it now.
    So I might not be able to go any more. All though I'm sure I can't be officially notified via voice-mail 4 days after it was left only a day before I return from leave, but if that is so it sounds like it will cut into these dates. I will still try and make it if something changes though.
  18. Sep 5, 2014 at 8:31 AM
    #318
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I wanna caravan. When are you leaving and from where?
  19. Sep 5, 2014 at 9:37 AM
    #319
    Basikbiker
    Trav
    If guys are taking 99 down, I can meet ya near fresno, 99 goes right by there, and time is whatever works for you
  20. Sep 5, 2014 at 9:54 AM
    #320
    SpeedwayBlueAlex
    Alex
    Modesto
    Sounds good to me. Just need to talk to john and see what time he can leave so we can all schedule a meetup time.
