So changed the spark plugs yesterday, found a prize.
Discussion in 'Technical Chat' started by sytfu510, Mar 14, 2012.
  1. Mar 14, 2012 at 10:14 AM
    sytfu510
    sytfu510 [OP] INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    So yesterday I change my spark plugs as part of my 60k service on my v6 2nd Gen. I recall reading that the driver side will have 3 NGK and the psgr have 3 denso from the factory. I purchased a set from the factory all Denso. As I take the plugs out I notice that they are still 3 NGK and 3 Denso, but when I stuck the magnet down to pull the plug out of one side, there was a metal ring, too small to fit down the plug, just barely goes over the tip... took a picture.. what do you guys think it's from? I checked the other coil packs didn't see anything similar in them.
    Also since the plugs were still mismatched does that mean the previous owner did not do the 30k service?
    Truck seems to run better/smoother now. Time will tell. But finding that ring is concerning.
  2. Mar 14, 2012 at 10:21 AM
    acdronin
    acdronin Well-Known Member
    IDK what the hell that ring is, thank god it didn't get into the engine! Unless the previous owner replaced the plugs with the same set up, it's probably safe to say yeah, those could be the originals :(
  3. Mar 14, 2012 at 11:55 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    No idea.
    Maybe part of inside the spark plug wire :notsure:
  4. Mar 14, 2012 at 11:59 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    the spark plug in the pic all the way to the right.... the bottom looks different but cant really tell.
    but i have no dam idea what that is. almost looks like something that is supposed to stay in the hole and not be removeable... but if it runs better then that doesnt make sence.... sorry kind of rambling on talking to my self lol but thats my thought
  5. Mar 14, 2012 at 12:07 PM
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    That ring looks like a heli coil
  6. Mar 14, 2012 at 12:10 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    If it was a helicoil the lines would be going around the ring horizontally, not vertically.
  7. Mar 14, 2012 at 12:11 PM
    97yota4wd
    Eric
    Mesa, AZ
    not a heli coil..
  8. Mar 14, 2012 at 12:12 PM
    97yota4wd
    Eric
    Mesa, AZ
    can i ever be right or first? just once? lol:cool:
  9. Mar 14, 2012 at 12:13 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I thought you're gf said you're first every time :notsure: :D
  10. Mar 14, 2012 at 12:14 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    thats a negative ghost rider :p
  11. Mar 14, 2012 at 12:15 PM
    97yota4wd
    Eric
    Mesa, AZ
    pshh, in that situation im first and last:)
    HREW?
  12. Mar 14, 2012 at 12:17 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  13. Mar 14, 2012 at 12:19 PM
    sytfu510
    Alex
    Bay Area
    the ring was sitting with/on the spark plug, I pulled out the coil pack, loosened the plug, then stuck a magnet in to pull out the plug and got the plug + that ring.
  14. Mar 14, 2012 at 12:22 PM
    servmgr64
    servmgr64 New Member
    Scott
    Iowa
    2007 4 door TRD
    Those spark plugs are the originals. Previous owner had not replaced them.
    Could the extra ring have come from the socket used?
  15. Mar 14, 2012 at 12:28 PM
    sytfu510
    Alex
    Bay Area
    That's what I was thinking, but I swapped out 4 of the plugs prior to the one I found the ring in. The magnet was clean prior as I just used it on another plug prior, But who knows. At least the truck is running better now with fresh plugs. :cool:
  16. Mar 14, 2012 at 4:19 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Interesting. Definitely not a helicoil... :facepalm: lol. Best guess would be something from the socket like stated earlier. I don't remember the coil packs perfectly, but I don't remember anything like that on them. It would only make sense if it was from the socket used... it just fell off onto the plug.
    Which reminds me, I'm about due to change mine out :) 60k on iridium densos is enough for me, don't want them to seize up. Going back to copper :D
  17. Mar 14, 2012 at 7:40 PM
    MikeluvstheTaco
    MikeluvstheTaco Well-Known Member
    Michael
    Saskatchatoon
    TRD Sport
    Can Someone tell me why there are denso on one side and NGK on the other?!?!?! like wtf?
  18. Mar 14, 2012 at 9:15 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Pink fan shaft now this?!
  19. Mar 15, 2012 at 10:23 AM
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    Some deep spark plug sockets use a pressed-in centering device like this to keep the plug aligned so as not to crack the porcelain if it gets catywampus while torquing. They usually have a rubber-lined interior though. The vertical striations lead me to believe this was a press-fitted item.
    I suspect this just fell out of the socket when removed.
    Look inside your ratchet's deep socket and see if it might have been yours.
    Whit
  20. Mar 17, 2012 at 8:47 PM
    Rmesa1
    Rmesa1 Well-Known Member
    It is part of the contract between Toyota denso and ngk. How do you make sure you use equal amounts from both manufactures? You use three of each. They have been doing this since the 90's
