So factory LSD should have pretension at 200 ft-lb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, Jul 13, 2010.
  1. Jul 13, 2010 at 8:48 AM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    According to that site Factory LSD (05-08 Tacoma's) should have pretension of 200 ft-lb. Damn I am missing 50 ft-lb then :confused: I am going to check again to make sure but I could swear I have only 150 ft-lb oh well still good.
    Sorry forgot the site link
    http://www.proactivate.com/tundra/lsd.html
  2. Jul 13, 2010 at 9:29 AM
    hansonian
    hansonian swims with fishes
    Tampa, FL
    2007 Double Cab PreRunner SR5
    Stock
    I'm still trying to figure out if mine came with the LSD, since I bought it used I don't know for sure.
  3. Jul 13, 2010 at 9:35 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    look at the rear diff from behind the truck. if there is an LSD oil sticker, then you have one
  4. Jul 13, 2010 at 9:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It should have a black and white sticker on the pumpkin that says LSD
  5. Jul 13, 2010 at 8:36 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Did a quick brake stand on some asphalt today, left 2 very small marks (tires are expensive!), I have an 08 with a LSD diff.
  6. Jul 13, 2010 at 8:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its actually RED and WHite. ;)
  7. Jul 13, 2010 at 9:43 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    '09 + Tacomas have AUTO LSD... no special oil since they are normal, 'open' differentials... until there is slippage on one tire (TRAC) or if you press the VSC OFF switch briefly to turn 'TRAC OFF' and then it becomes 'AUTO LSD'... or when you are in 4WD HI, then the AUTO LSD is automatically active on all 4 wheels (but still called 'TRAC' by Toyota). The Yellow Wire Mod will give you the AUTO LSD (TRAC) in 4WD LOW (if you don't have the Off Road TRD with A-TRAC).
    Sensors detect when one tire spins out and forces torque to the opposite tire on each drive axle. Done with the brakes instead of clutches inside the differential... easy, cheaper to replace, and it works!
  8. Jul 13, 2010 at 10:04 PM
    jhodge83
    SC
    ^^:facepalm:
    OP clearly has 2007 listed
  9. Jul 14, 2010 at 6:28 AM
    David K
    Yes, we can see that... but others open and read the thread which does not state the year in the title. Also, the OP may get a new Tacoma someday and they don't have the old style LSD with clutches anymore. ;)
  10. Jul 14, 2010 at 6:45 AM
    BlueT
    NorthEast
    I did put the years at the beginning
    Also OP won't be getting new truck with Auto-LSD unless there is no more of 05-08 trucks for sale :D
    I like my trucks to be easy to fix and modified with out spending arm and a leg at dealership.
  11. Jul 14, 2010 at 7:02 AM
    David K
    It is not stated in the title, so until we open the thread and begin to read it, we don't know what year. Anyway, that doesn't matter... I clearly said I was talking about the '09 and new Tacoma LSD so that YOU and anyone else who wasn't familiar would know how they achieve LSD... no problem.
    I like my trucks to be trouble-free as well... that is why I get Toyota and get new ones every 4-5 years, have them serviced on schedule (or sooner for oil changes). I put over 136,000 miles on my 2001 Tacoma in less than 5 years without any mechanical or other problems. My 2005 had over 102,000 miles when I traded it for my 2010... a couple of problems, but none bad enough I would try another brand.
    Good luck with yours!
  12. Jul 14, 2010 at 7:31 AM
    splitbolt
    splitbolt Well-Known Member
    Arkansas
    2016 TRD OFFROAD DCSB MGM
    ....for a 2004 Tundra?:confused:
  13. Jul 14, 2010 at 7:40 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    BISH!!! *shakes fist*
  14. Jul 14, 2010 at 7:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    So, in leayman terms.... Is that the amount of force that is utilized to keep the clutch paks/wheels in traction (so to speak)?
  15. Jul 14, 2010 at 7:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont be hatin just because we all have a color screen, and you are still rockin the B&W. BISH!!
    *runs away*
  16. Jul 14, 2010 at 7:53 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :eek:
  17. Jul 14, 2010 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  18. Jul 14, 2010 at 8:26 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  19. Jul 14, 2010 at 8:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  20. Jul 14, 2010 at 8:57 AM
    BlueT
    NorthEast
    I think you can say that way but there is probably more to it. I got 150 ft-lb on a wheel with other having 0 ft-lb traction (both in the air)
    So if you end up with one of the wheels in the air the other should be getting 200 ft-lb. Not bad for clutch pack limited slip.
