So far! not enough lift in the front
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eddieEndo, Nov 20, 2009.
  1. Nov 20, 2009 at 5:19 PM
    eddieEndo
    eddieEndo [OP] Well-Known Member
    Eddie
    Fullerton, CA
    Scion FRS
    I got the billstein 5100s set them @ .85 and used the 1.65 eibach spacers
    however i feel like my truck is not high enough in the front it could use another 1/2 to 1 inch
    What are my options to get this 1/2 to 1 inch in the front can i use spacers?
  2. Nov 20, 2009 at 5:20 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Why don't you jack your Billys up to 2.50"??
  3. Nov 20, 2009 at 5:51 PM
    eddieEndo
    Eddie
    Fullerton, CA
    Scion FRS
    I guess you shouldn't run those springs at anything higher then .85 :( it was a bitch to compress it @ .85 sounds like a nightmare at 2.5
  4. Nov 20, 2009 at 5:51 PM
    eddieEndo
    Eddie
    Fullerton, CA
    Scion FRS
    Could the billies and coils go hand in hand with aftermarket spindles?
  5. Nov 20, 2009 at 7:02 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Yup you can run spindles
  6. Nov 20, 2009 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    NO!! Not with the Eibach coils.
  7. Nov 20, 2009 at 7:15 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    How much lift did it give you?
  8. Nov 20, 2009 at 7:29 PM
    eddieEndo
    Eddie
    Fullerton, CA
    Scion FRS
    like 2.5 inches but the leaf springs in my back end haven't settled yet so the back is still higher, the front shocks/springs are settling much quicker then the back ones :(
  9. Nov 20, 2009 at 8:00 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    What is in the back for a lift?
  10. Nov 20, 2009 at 8:17 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    spindles
