So how loud is the Walbro 255 fuel pump?
Discussion in 'Performance and Tuning' started by JL8Jeff, Dec 7, 2020.
  1. Dec 7, 2020 at 7:33 AM
    JL8Jeff
    JL8Jeff [OP] Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I don't listen to the radio or any music when I'm driving so if the Walbro 255 pump is pretty loud, I will probably hear it all the time. Most of my driving is around town 25-45 mph and I'm thinking that would be really annoying after a while. So is it loud enough to really bother you?
  2. Dec 7, 2020 at 8:26 AM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    I have the Walbro in my Miata. It's very whiney, almost like a mosquito buzzing in your ear. But the fuel tank is also right behind your head in that car. I usually have music going and the top down so it's not really an issue for me. I have the extended crank issue too. But I just turn on the car without starting it, put on my seat belt and that usually gives it time to pressurize.
  3. Dec 7, 2020 at 11:09 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    I found a video online where a guy swapped out his Walbro for the Deatschwerks pump and he did a sound comparison. There was a big difference in the noise so I'm sure that the Walbro would drive me crazy.
  4. Dec 7, 2020 at 11:14 AM
    eon_blue
    Azusa, CA
    I have the Walboro 190 in my 04 (came with my URD 7th injector kit), it's quiet *most* of the time except when I've been driving for a long time and it heats up (I guess). Long drives make it noisy, same with offroading. It will hiss/whine like a stuck pig, admittedly it is kind of annoying.
    Walboro claims it's a characteristic of their pump design and nothing to worry about as far as failure goes, mines done it the whole 4+ years I've had it installed and other than the noise, no issues.
  5. Dec 9, 2020 at 11:36 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    I have an Aem, no noise, flows 340, e85 compatibility.
  6. Dec 9, 2020 at 5:10 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I also have the AEM 340 and I only notice it outside the cab at idle. Never noticed it inside while driving windows up.
  7. Dec 12, 2020 at 7:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Aeromotive Stealth pumps, Deastchwerks. Quiet as well..
