so i bought hid's and they dont work?
Discussion in 'Lighting' started by cortez_55, Mar 24, 2011.
  1. Mar 24, 2011 at 8:34 PM
    cortez_55
    cortez_55 [OP] Member
    Ray
    Yuma az
    Silver 05 TRD Sport prerunner
    40 series flowmaster,2.5 inch level lift up front,black badges,alpine deck and type r speackers with a dual cvr kickers behind the rear seat with a hifonics amp,5% tint,17x8.5 fuel octanes with 285/70/17bfg all terrain,painted bumper
    ok well i hooked up evrything the way the instructions directed to do they were doing good for about one day the second day my left front headlight would come one when i would turn the headlight switch a couple of times and one night they decided just to shut off so i redid everything all over again but the fuse on the relay harness was burn i replace it reconnected evrything a agian a couple nore times and i went through about 6 fuses idk whats causing this? anyone no what happening?
  2. Mar 24, 2011 at 8:36 PM
    curtis
    curtis Member
    Curtis
    Tracy
    2000 prerunner
    8k hid straight pipe
    IT could e that you are getting more than 12v. trying using a voltage stabalizer. about 15$
  3. Mar 24, 2011 at 8:39 PM
    cortez_55
    Ray
    Yuma az
    notto se..... and where could i get a voltage stabalizer?
  4. Mar 25, 2011 at 7:48 AM
    cortez_55
    Ray
    Yuma az
    is a cancellar the same thing?
  5. Mar 25, 2011 at 9:45 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Don't buy a voltage stabilizer, they are snake oil. Anything automotive is designed to run to much higher voltages than just 12v. Regulations require that they survive a 24V double battery jump start from a tow truck. You have a bad ballast or bulb. Switch the bulbs from one side to the other and see what happens. If the bulb is bad then the bad side will switch if the ballast is bad it will still be on the same side. then contact the seller of the HID kit and tell them you have a bad bulb/ballast.
  6. Mar 25, 2011 at 9:55 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i disagree with everyone........shocked i know
    if you keep blowing fuses you have a short someplace.....either in the wiring
    or in the ballast box itself.......
    just my .02
  7. Mar 25, 2011 at 10:14 AM
    PreRunnerSeth
    Apex, NC
    HA! teach me to read more.. Yeah.. blown fuses means short...
  8. Mar 25, 2011 at 11:33 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    short.
