So, I bought my first travel trailer and...... questions...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roscoe Taco, Aug 11, 2020.
  1. Aug 12, 2020 at 7:47 AM
    #41
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    FWIW, for heavy loads... Should tow in 4th gear. 4th is the only gear that uses only 1 planetary gear set in the trans. All other gears (1,2,3,5,6) transmit power through multiple gear sets to get the gearing. Thus 4th is as close to "direct" drive as possible. Thus less heat created in the trans.
  2. Aug 12, 2020 at 7:48 AM
    #42
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    And is stated as much in the manual.
  3. Aug 12, 2020 at 7:54 AM
    #43
    MischiefBrewing
    MischiefBrewing Member
    Vermont
    2017 Inferno TRD Sport
    I installed my P3 in the same spot, but didn't use the mounting bracket, I just removed the coin cup thing and wedged it in and used some metal fishing leader to lock it down behind the plastic facing using the original mounting screws. It sits a little more back into the dash and is somehow very level (a requirement of the controller).
    I tow a 2020 NuCamp T@B 400 BDL (dry weight 2953, around 3500 when stuffed full for a long weekend) here in Vermont and can say my 2017 DCSB TRD Sport hates any little hill, let alone the mountains I drive through all day every day. Gas mileage is for sh** and I'm usually going about 60 with the engine screaming on the hills. That said, I can get into just about any campsite and am usually averaging about 13mpg towing, which is about what I'd get in a tundra anyway.
    GillyLink and Phich[QUOTED] like this.
  4. Aug 12, 2020 at 7:57 AM
    #44
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    All in all, OP, if you stick with the Mini Lite, I think you'll not look forward to the drives, but the actual camping and functionality of the RV will be very enjoyable all around. Forest Rivers are top notch in the RV world.
    It might be wise to get a Scan gauge 2 to monitor tranny temps, though I have one and even in Texas heat I have never gotten tranny temps over 202 while towing.
    ***I pin the thermostat open from June to September here in South TX, towing or not.
    Congrats on the purchase and enjoy the RV life!
  5. Aug 12, 2020 at 8:10 AM
    #45
    OverlandExpress
    OverlandExpress Well-Known Member
    NE Ohio
    2020 Taco TRD PRO
  6. Aug 12, 2020 at 8:12 AM
    #46
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    My truck struggles to pull a 12 foot U-Haul lightly loaded from Raleigh to Charlotte. As has been said, it will do it , but not well at all.
    Picked the trailer up in Raleigh. 21.3 MPG going, 11.3 comming back with it. 3rd and 4th gear the whole way. ETC on.
    G.
  7. Aug 12, 2020 at 9:11 AM
    #47
    Phich
    San Antonio
    Six Demon Bag
    This is the video that actually sealed the deal in my mind about buying my Geopro. He's perfectly honest about the truck and its capabilities which I really like. Very nice looking Tacoma too!
    I thought if I towed 1000lbs less than the Victory Tacoma, I would sport better drivability and fuel economy than they did - turns out it was exactly the same!
    Same RPM's, same fuel economy, over 1000lbs less. Thats' when I became fully aware that the wind resistance, not the weight, is the main reason why travel trailers are not a good fit with the Tacoma.
    Atomic, AKGSD and GPatriot like this.
  8. Aug 12, 2020 at 9:19 AM
    #48
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    The thing that kills all hope of towing being manageable?
    Passing a semi-trailer on a 2 lane road when he's going 75 no matter how slow you're going. It feels like you're going to get sucked back along with him.
  9. Aug 12, 2020 at 1:02 PM
    #49
    Roscoe Taco
    Roscoe Taco [OP] Sort of old guy
    Ron
    Southern NM
    2017 Tacoma TRD OR 4x4
    Don’t mean to sound dumb, but how did you get the cubby hole box out of the compartment?
  10. Aug 12, 2020 at 1:04 PM
    #50
    Phich
    San Antonio
    Six Demon Bag
  11. Aug 12, 2020 at 1:32 PM
    #51
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    just to touch back on this part of the equation too, I believe the hitch itself is considered part of the vehicle GVWR. As mentioned it’s job is to move weight from the rear of the truck to the front. If sway control isn’t built in to your WDH you’ll want to add that as well. I have a bolt on curt sway control for my pop-up and it really helps.
    And yes, with the WDH, people, dogs, and tongue weight you’ll definitely be pushing the Tacoma’s GVWR. It’s one of the things that concerns me towing with my Tacoma and honestly has me looking at a Rangers or a 1/2 ton. I’m right at the GVWR limit with my family loaded up and ready to go; a single AAL and new shocks helped the load handling tremendously.
  12. Aug 12, 2020 at 1:39 PM
    #52
    Pinballwizard_king
    Pinballwizard_king Well-Known Member
    2020 blue Tacoma TRD off road
    Pop-ups are best route to go. They have collapsible roof, you can get ac in it, toilet and even a 3 way fridge. Small enough to maneuver around, light weight, less air drag, you can get an outside shower hook-up ,weight is low enough to get around and keep up with traffic .had 1 in the past with my 99 and was great. You can use your slide outs and enjoy the outdoors instead of being cooped up with no real air circulation. I think I would have asked them if i could hook it up and run down the road to test it out before i put my signature in the box. In any event it's your decision and you will have to live with it and that means either good or bad.good luck
    Skydvrr and Chew like this.
  13. Aug 12, 2020 at 1:50 PM
    #53
    Roscoe Taco
    Ron
    Southern NM
    Thanks for the link, Phich. Looks easy enough for a semi do it all kinda guy like me.
    thanks Skierd, I’ll keep s in mind
    Phich likes this.
  14. Aug 12, 2020 at 2:03 PM
    #54
    Roscoe Taco
    Ron
    Southern NM
    If I was still a young man, probably single, I agree. I would have a pop up. But we’re in our 70’s now so a full bed, couch, bathroom.... you get the idea. Especially easier on my wife, who has some hip issues.
  15. Aug 12, 2020 at 2:07 PM
    #55
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    The biggest reason for the low GVWR is the soft springs. If you add a leaf or two you can put a lot more weight in your truck. It adds more lateral rigidity as well which makes towing more stable. I have two extra leafs per side on mine and it has made a huge difference in towing. Mind you, my tacoma is a work truck and the stiff ride when empty is accepted. I have been towing with this truck for years with loads well exceeding the max and tongue loads as much as 1200 lbs without squatting. You aren't going to convince me my truck is going to break in half... I've been doing it for too long.
  16. Aug 12, 2020 at 2:08 PM
    #56
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    You'll be fine, you are aware of the numbers, you sound like you will be cautious while driving it, truck will do it with ECT and 4th.
    Would it be easier and more comfy in a 5.7 Tundra? Sure! Could you pass cars on your way and pack another 1000lbs worth of beer and stuff into a 40ft trailer? Probably..
    But this is TW - load up, get out there, and see you at the lake..
  17. Aug 12, 2020 at 2:22 PM
    #57
    skierd
    David
    Fairbanks, AK
    I’m right there with you on the soft rear springs. With the single AAL I have and 5100’s bumps that used to threaten to shake the truck apart are handled with much more composure. I’ve had 1000+ pounds in the bed numerous times before and after and it’s a night and day difference.
    geoyota760 likes this.
  18. Aug 12, 2020 at 2:38 PM
    #58
    Roscoe Taco
    Ron
    Southern NM
    We’re leaving Monday to pick up the trailer. The drive (no trailer) could be done in a long day of driving, but coming home, we plan to take 3 days, thus 2 nights in the new trailer and not pushing the drive too far. Our longest day will be about 320 miles.
    I’ll see how she handles on this trip and gives some consideration to adding additional springs.
    thanks for the heads up.
  19. Aug 12, 2020 at 3:17 PM
    #59
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Already bought the trailer so yo can go new truck shopping. Anything more than a short haul you’re not going to be happy. Start looking at Tundras.
  20. Aug 12, 2020 at 3:18 PM
    #60
    Roscoe Taco
    Ron
    Southern NM
    So if I only add one leaf per side, would I still benefit from additional carrying capacity without stiffening the ride too much? I don’t carry much in the truck on a daily basis other than maybe a stock up trip to Costco now and then or the occasional trip to the dump so we don’t want to change the ride too drastically.
