So I broke a TPMS
Discussion in 'Wheels & Tires' started by whitedlite, Sep 4, 2018.
  1. Sep 4, 2018 at 8:55 AM
    whitedlite
    whitedlite [OP] Well-Known Member
    USA!
    3RD Gen TRD 4WD
    My question is, are they rebuildable?
    I broke the valve stem off, I'm hoping it's a 3 piece design, sensor, stem, nut.
    Jerneyman likes this.
  2. Sep 4, 2018 at 9:05 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
  3. Sep 4, 2018 at 9:07 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    My aftermarket sensors are two piece: the sensor and the stem.
  4. Sep 4, 2018 at 9:09 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    https://www.amazon.com/Denso-550-0103-TPMS-Sensor/dp/B00NQ05U24/ref=cm_cr_arp_d_product_top?ie=UTF8
    apparently these on several tacomas have been able to pop in and work without even programming.
    that's what I'm hoping, otherwise maybe I can con the local dealer into programming it since I'm still under my 40k free oil change deal.
    any insight?
  5. Sep 4, 2018 at 9:09 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    I tried aftermarkets but they would not program.
    Pretty sure OP is going to need to match his to the 3 remaining sensors .
  6. Sep 4, 2018 at 9:29 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    hm, good point. will the aftermarkets work with the OEMs.
  7. Sep 4, 2018 at 9:30 AM
    doorsidedown
    doorsidedown Well-Known Member
    I haven’t had sensors for so long I don’t even notice the light. I do, however, keep a more careful eye on my air pressure.
  8. Sep 4, 2018 at 9:31 AM
    Tacomamike mike
    Michael
    No
    doorsidedown likes this.
  9. Sep 4, 2018 at 9:34 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Just a note that the 0106 is Denso OE for a 2017 Tacoma. The 0103 is OE for the 4runner.
  10. Sep 4, 2018 at 9:52 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    so 3 oem's and 1 denso won't work together.. damn.. got expensive.
  11. Sep 4, 2018 at 9:54 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    what's the difference?
    Only reason i ask is that the 0106 has zero reviews where the 0103 has over a hundred.
  12. Sep 4, 2018 at 10:36 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    The difference is that Denso lists the 0106 as the proper fitament for the 17 tacoma.
    These aren't programmables, I think Denso makes them for Toyota.
  13. Sep 4, 2018 at 10:41 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    so these are made to pop in rim, air up, and it automatically connects to my ecu?
    i wouldn't have to make the ECU forget the current TPMS that's programmed?
  14. Sep 4, 2018 at 11:04 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    I'm definitely not going to say that because I don't even use stupid sensors, I just deal with the light.
  15. Sep 4, 2018 at 11:08 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Lot of guys sell their OEM TPMS on here, most sets are $100 shipped or less for the entirety of the sensors (4).
    Just bear in mind that second gen and third gen TPMS aren’t compatible. Not sure what year truck you have.
  16. Sep 4, 2018 at 11:12 AM
    Hobbs
    Yep…
    Which brand aftermarket sensors did you try? And which scan tool did you use?
  17. Sep 4, 2018 at 11:34 AM
    Tacomamike mike
    Michael
    Lol America Tires tried two aftermarket types...no go...
    Then they went to OEM no go...
    I then took the spare with sensor in it away from truck and the OEM sensors worked.
    So I’m not sure if the aftermarket sensors didn’t work because of my truck or if they would have worked had I took the OEM away ??
  18. Sep 4, 2018 at 11:39 AM
    Hobbs
    Yep…
    Do you know which brands of sensors America Tires tried? Did they use a scan tool or just the reset procedure on the truck?
    Reason I ask is I have a new set of ITM brand sensors and haven't found much user info on them.
  19. Sep 4, 2018 at 11:42 AM
    Tacomamike mike
    Michael
    I’ll find out for you, on both
  20. Sep 4, 2018 at 11:48 AM
    Hobbs
    Yep…
    Thanks!
