So I Cant Use Auto LSD in 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, Mar 5, 2015.
  1. Mar 5, 2015 at 11:59 AM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    So what's the point?
    I actually picked up the owners manual and that's what it says.
    Why bother even including it on 4WD vehicles????
  2. Mar 5, 2015 at 12:02 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    IMHO because when you turn off the VSC in 2WD it's handy on snowy roads. The auto LSD still works technically in 4HI because the VSC will limit wheel spin. At the end of the day the question really should be "why can't we have a real LSD like the Colorado?"
  3. Mar 5, 2015 at 12:05 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    cause sometimes your 4WD vehicle is in 2WD ?
  4. Mar 5, 2015 at 12:11 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You can do the "yellow wire" mod and have TRAC in 4lo. I did it in my truck and it does work. Not as good as ATRAC but it works none the less.
  5. Mar 5, 2015 at 12:22 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    because at least 1 wheel in the front and one wheel in the back will be turning at the same speed. If the ALSD tries to limit slip on the slipping wheel in the back, the wheel in front will be slowed down as well. All 4 wheels are mechanically connected thru diffy and transfercase.
    As stated above, its for when in 2wd.
  6. Mar 5, 2015 at 12:30 PM
    MikeDeason
    2015 model. Says only works in 2wd. So why would it turn auto LSD on instead of 4hi
    Stupid.
  7. Mar 5, 2015 at 12:33 PM
    Pigpen
    Dan
    Northwest Montana
    Not aware of this in the 2015. For the rest of us, the electronic LSD works in 2H and 4H from the factory. By taking 10 seconds and cutting a wire that is easy to access, we can have LSD in 4Lo also
  8. Mar 5, 2015 at 12:36 PM
    OZ-T
    Peter North
    British Columbia
    wha
  9. Mar 5, 2015 at 12:39 PM
    Pigpen
    Dan
    Northwest Montana
    Mine works fine. Both fronts spin, both rears spin. Works in reverse too. First I've heard of this issue...but I'm 2012.
  10. Mar 5, 2015 at 12:46 PM
    MikeDeason
    Quote from manual
    "This system can be used on 2WD vehicles and in 2WD mode on 4WD vehicles"
  11. Mar 5, 2015 at 12:53 PM
    Pigpen
    Dan
    Northwest Montana
    I don't think that statement is limiting the feature to 2WD only on 4WD models. Go get your truck dirty and give us a full report.
  12. Mar 5, 2015 at 12:57 PM
    beeesmitty
    beeesmitty Well-Known Member
    NC
    11' SR5 DC BSP 4X4
    265/75/16 Cooper ATP, TRD FJ Trails, 5100's @ 2.75, ReadyLift 2" Blocks
    I'm pretty sure the ALSD you speak of in 4WD is TRAC
  13. Mar 5, 2015 at 1:01 PM
    Pigpen
    Dan
    Northwest Montana
    LSD works with TRAC off
  14. Mar 5, 2015 at 1:24 PM
    OZ-T
    Peter North
    British Columbia
    K , so I thought I might be losing my mind so I just went and did it
    2WD , push the VSC button , AUTO LSD and VSC OFF light come on
    Switch into 4HI , both lights go out
    Push the button nothing happens
    Hold the button for the 3-5 turns on the VSC OFF light
    Like I thought
  15. Mar 5, 2015 at 1:56 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Don't know what you talking about, my truck has factory installed Hino limited Slipp.
    :D
  16. Mar 5, 2015 at 2:41 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yup, those of us past 09 get to suck limes though :goingcrazy:.
    I'd throw in a Detroit TruTrac, which is better than the Hino limited anyways, but there's a lot of people that think it would mess with the VSC at high speeds. I like my VSC due to a previous close call which leaves me without access to a true LSD.
  17. Mar 5, 2015 at 3:02 PM
    BlueT
    NorthEast
    Debatable....
    Does Truetrac work with one wheel in the air ? Answer is NO.
    But Hino LSD does ....
    Therefore
    Hino LSD > Truetrac.
    :D
  18. Mar 5, 2015 at 3:09 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Lol, I was looking at it maintenance wise. The TrueTrac will last as long as the truck. That Hino will wear out and need servicing. If I have a rear wheel up in the air offroad I'm past what my truck and my skill are capable of :p.
  19. Mar 5, 2015 at 3:19 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    My 2011 SR5 will run ALSD in 4H but not 4L.
  20. Mar 5, 2015 at 3:25 PM
    MikeDeason
    They changed it. In my 09 the auto LSD indicator would come in in 4wd on my '15, nothing.
