So I go to replace my O2 sensors...
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, May 14, 2011.
  1. May 14, 2011 at 8:00 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I got the typical P0136 code from my CEL...per alot of suggestions ordered both upstream and downstream sensors from RockAuto.
    Upstream took me about 10 minutes to replace, great, then O go to do the downstream one and can't figure out why I can't get it unbolted??
    I had the stealership replace both cats about 2yrs ago and it seems they tack welded the downstream O2 sensor in instead of of bolting it back on!!
    What a major PITA!!!
    Anyone else ever seen this??
    Peter
  2. May 14, 2011 at 9:22 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ass-hats... They probably fucked up the studs when trying to install your new sensor (or remove the old one). Thats why I always inspect work (major work) done on my truck/car before paying.
    Random story: My wife took her car to Wal-Mart for an oil change while I was at work. I was able to get there just in time. Turns out they didnt replace the oil filter... I didnt pay them a cent, wouldnt let them install a filter, and went directly to a trusted dealership. Once the dealership assured me they actually changed the oil (and used the correct oil - and installed a new filter with no labor charges) I returned and paid Wal-Mart for the oil but not labor. They told me never to come back and I told them not to worry.
  3. May 14, 2011 at 9:59 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    They welded the nuts to the studs or the sensor right to the bung? Is the heat shield still in place?
  4. May 14, 2011 at 10:15 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    THEY told YOU never come back?? Wow-nothing worse than losers that are arrogant about being losers!
  5. May 14, 2011 at 11:21 AM
    RacerP
    Chicago
    2003 4x4
    They welded the sensor to the studs in place of the nuts. The heat shield is still there.
  6. May 14, 2011 at 11:31 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    time to break out the torch
