So I got this $14 Ribeye Steak in my fridge...
Discussion in 'Food Talk' started by Marc M, Jun 9, 2010.
  1. Jun 9, 2010 at 6:39 PM
    Marc M
    Marc M [OP] Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    What is the best way to grill it? It's only one because my wife doesn't like the taste of steak.
    I do have a propane grill.
    I do have an oven with a broiler.
    I do have a cast iron skillet.
    The only seasoning I will use is salt and or pepper, no rubs or steak seasonings.
    It's about a pound and a half, boneless and an inch and a half thick.
    I like my steaks to be just under medium but not meduim rare.
    Help me...:confused:
    Marc M
  2. Jun 9, 2010 at 6:43 PM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    Personally, I put a crust of fresh black pepper on my steaks along with a little salt for flavor. Heat cast iron skillet to about 350 on the grill, slap it on to sear the outside for a few minutes, flip it over, wait a few more........remove, let rest for 2-3 minutes and tear it up..barehands.
  3. Jun 9, 2010 at 6:46 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Yep, that'll do ya. Just be sure to pre-heat. Nice and hot. You can use a drop of water, when it dances, it's ready.
  4. Jun 9, 2010 at 6:47 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Lightly rub olive oil on it along with crushed pepper & salt and put on grill until you like the way it looks. :)
  5. Jun 9, 2010 at 6:50 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  6. Jun 9, 2010 at 6:50 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
  7. Jun 9, 2010 at 6:53 PM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
    Those sound like good ideas. Nothing but salt and pepper. The only other thing I would recommend is allowing it to get to room temperature before cooking. It will be extremely tender. For those of you that have never tried that, give it a go. It comes out like butta!
  8. Jun 9, 2010 at 6:54 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I just got a "new" 70 year old cast iron skillet that used to be my grandmothers. I've been looking up the best way to cook a steak on it. This is pretty close, but I read heat the skillet to 500, sear it 30 seconds on each side and put it back in the the oven for another 2 minutes at 500. I'll be trying this when I get a nice cut of steak to cook.
  9. Jun 9, 2010 at 6:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a little olive oil....a little butter....salt and pepper. use your skillet.........get it good and hot,and add olive oil and butter,just enough for the steak to sit on. cook it slowly....only turning it once. you'll enjoy.
  10. Jun 9, 2010 at 7:26 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    cast Iron!!!
  11. Jun 9, 2010 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    letting it get room temp is a great idea. i do this for all my steaks....makes a huge difference.
  12. Jun 9, 2010 at 8:20 PM
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    Cast iron is a good method. It will produce a lot of smoke in the house though.
    I'd grill it personally. You want the fire as hot as it can go and plenty of room to work. A ribeye has enough fat that you'll probably be working around flare ups. So you need the room to move the steak as the grill burns off rendered fat.
    2 minutes on the grill, then give a 1/4 turn to make the pretty crosshatch grill marks, for another 2 minutes. Flip, repeat, remove, let rest 10 minutes covered. Serve.
  13. Jun 9, 2010 at 8:37 PM
    Koov
    Koov Well-Known Member
    Seattle
    2019 DCLB TRDOR
    Just like the above, except I would let the meat sit out for 30 minutes room temp before cooking. Put some hawaiian salt and pepper on it, sear it for about 1 minute. Put in oven for about 2 minutes, after that, take out and pour hot melted butter with some parsley in it. I promise you it will melt like butter in your mouth. Happy eating!
  14. Jun 10, 2010 at 3:17 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I'm not a huge Ribeye fan as I feel its just too fatty. I am a fan of Alton Brown though, and since his Sirloin recipe isn't that much different (flavor similar, cooked a little different), it should be good. It also just uses salt/pepper for seasons, so its made to bring out natural flavors instead of cover them up.
    This is Alton Brown's recipe for Rib eye: http://www.foodnetwork.com/recipes/alton-brown/pan-seared-rib-eye-recipe/index.html Kinda a combo of Cast Iron and Oven to get the best of both.
    I do like his method for cooking Sirloin, and end up doing most steaks like this and have never had a bad experience. http://www.foodnetwork.com/recipes/alton-brown/sirloin-steak-recipe/index.html
  15. Jun 10, 2010 at 9:29 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    all three of those methods work great. how thick is the steak?
    here is my latest method. get the steak to room temp. use paper towels and get it dry. salt, fresh ground pepper. have oven to 250 degrees. set it on a rack and slow cook it to 120 degree. finish it on the cast iron by searing it a rocket hot temps. the steak will be med rare all the way thru. no livery grey layer.
    any method you use. key is room temp, and paper towel dry the steak. makes for a good seared crust. and with steaks, crust is flavor.
  16. Jun 10, 2010 at 7:31 PM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    Thanks for all the replies fellas. Top Sirlion is actually my favorite cut, but I have had several really great Ribeye's lately and haven't tried to prepare one myself.
    I start a forced vacation tomorrow after work and will be off for 9 days. I haven't had that many days off in a row for over 5 years.
    I figured I'd cook myself a good steak one afternoon.
    Marc M
  17. Jun 18, 2010 at 8:09 AM
    Rudbwoy7s
    Rudbwoy7s Well-Known Member
    TEXAS
    08 Double cab 4x4 sr5
    3" Revtek suspension lift, 17" Black and silver American Eagle Alloy wheels, 285/70 Nitto Terra Grapplers, Flowmaster 40 series muffler, sockmonkey brake light cover, Maglight mod, Viper alarm, Smith & Wesson hitch receiver cover
    step one: buy a charcoal grill and some mesquite lump charcoal
  18. Jun 28, 2010 at 12:31 PM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    make sure the steak rests to come close to room temperature before cooking...
    get the cast iron as hot as you can...
    oil that bad boy up - add salt (not pepper, it burns - add it afterwards)...
    sear that up... timing is your discretion....
    when done, tent a piece of foil over and let rest for 5 minutes or so to redistribute the juices...
    go to town!!
  19. Jun 28, 2010 at 12:32 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    nothing tops a rib eye... the king of steaks - (since it has the most fat and is the most tender...) mmmm......
  20. Jun 28, 2010 at 1:22 PM
    Rudbwoy7s
    TEXAS
    x2!
