So I just bought an 08 tundra with the 6 speed trans. But it will not go into reverse or into 4 low.
Discussion in 'New Members' started by olmule, Nov 21, 2021.
  1. Nov 21, 2021 at 1:08 PM
    olmule
    olmule [OP] New Member
    08 tundra
    Any help would be great. New to Toyota. 08 270000 miles 5.7 6 speed automatic.will not go into 4 low or reverse, or neutral.
    Black DOG Lila likes this.
  2. Nov 21, 2021 at 1:10 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Not to make you feel unwelcome but I think you will find more help if you head over to the tundra forum: Tundras.com
    tacomakid96, ColoradoTJ and Mark77 like this.
  3. Nov 21, 2021 at 1:12 PM
    tcjacado
    tcjacado Well-Known Member
    @Empty_Lord may be able to help the op.
    Welcome to TW
  4. Nov 21, 2021 at 1:13 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Definitely recommend checking the fluid level. AT's run off of the fluid
  5. Nov 21, 2021 at 1:25 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    Throw a trans in it and be done
  6. Nov 21, 2021 at 2:30 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    It won’t go into reverse? Or it won’t go into 4x4 in reverse?
  7. Nov 21, 2021 at 2:51 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You can't shift into the ranges or it just won't move?
  8. Nov 21, 2021 at 2:52 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    yea, go catch buddy
  9. Nov 21, 2021 at 2:56 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    @olmule
    Please clarify the issue a little bit. Do you mean it will not shift out of park, and wont go into 4 low?
    Needs to be at a stop and in neutral to shift into 4 low. If it won't shift out of park, check that your brake lights are working (confirm brake switch works).
  10. Nov 21, 2021 at 3:01 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    nictarine and tcjacado like this.
  11. Nov 21, 2021 at 4:16 PM
    olmule
    08 tundra
    Ok the shifter moves back up lights come on. But will not go into gear. Are there solenoids that could be stuck or something like that. And when in neutral it goes forward also. Even in park it wants to go forward.
  12. Nov 21, 2021 at 4:21 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    It could be the shift cable bushing, which would cause the trans to not go back into park or gears properly.
    tcjacado likes this.
  13. Nov 21, 2021 at 4:26 PM
    gearcruncher
    Canadain bumper technician
    I agree with the boys .
    Shift linkage is most common with the 5 speed A750 series transmission in the Tacoma as well AB60 series 6 speed transmission found in the Tundra .
    Loss of reverse in the AB60 series transmission is always mechanical . No solenoids or computer controls are used for the shift into reverse .
    Will the truck start in Neutral ?
    Do you by chance know if the previous owner got the truck stuck in deep mud or snow ? When this happens and the driver spins the tires for a long period of time , he / she can overheat the forward clutch . The forward clutch gets soooo hot it welds itself to the forward ring gear . This is one explanation why the truck drives forward in Neutral as well as reverse .
    Transmission would need a pressure test , but with that many miles , have a peek at the link below
    https://www.sonnax.com/parts/1771-boost-valve-kit
  14. Nov 21, 2021 at 4:42 PM
    olmule
    08 tundra
    The previous owner was driving down the road. Stopped at the store went to back out and no reverse
    nictarine likes this.
  15. Nov 21, 2021 at 4:45 PM
    Empty_Lord
    Dan
    Sounds like she let go internally personally.
  16. Nov 21, 2021 at 4:46 PM
    olmule
    08 tundra
    Yes it will start In neutral but it wants to go forward.
  17. Nov 21, 2021 at 4:53 PM
    gearcruncher
    OK
    Linkage is good then .
    Mechanical failure at this point unfortunately . Very unusual for these transmissions to drop reverse gear all at once . Hope you got the truck for a good deal .
  18. Nov 21, 2021 at 5:10 PM
    olmule
    08 tundra
    Ok thanks a bunch what years of ab60 will go into an 08 tundra. And if I were to rebuild this one would a master kit be enough to fix this or should I worry about valve body and gear wear.
  19. Nov 21, 2021 at 5:23 PM
    gearcruncher
    Call your local wrecking yard for years that will work . They get these questions every day . These transmissions should be a dime a dozen as they are very reliable .
    Would be nice to see your truck pop by the shop . I wouldn't mind tackling this job as this is very unusual for a Tundra
    I would plan for some hard parts failure , a master kit with bushings , torque converter , and a valve body recalibration kit if I was rebuilding your trans
    https://www.sonnax.com/parts/3477-zip-kit
  20. Nov 21, 2021 at 5:52 PM
    olmule
    08 tundra
    Ok I've rebuilt a couple I'm no expert by any means but I'm short on time so think I'll just throw a low mileage trans in it. Thanks again for all the info. Still strange how all forward gears shift so nicely but no reverse and neutral goes forward. Guess I'm going to have to pull this one apart
    gearcruncher likes this.
