So I ordered my D-rings but....
Discussion in 'Technical Chat' started by Toyhauler, Aug 20, 2008.
  1. Aug 20, 2008 at 9:44 AM
    Toyhauler
    Toyhauler [OP] Well-Known Member
    SoCal
    08 PreRunner TRD Sport
    I don't think they will be here on time for me to actually use them and I need some tips.
    I did a search before and read that somebody just moved the rear d rings to the front. what size torx socket is the d ring on in the rear? Also, do you just replace the front bolt to the back?
    I've also, noticed that there are 3 unused wholes in the front of the bed, I was assuming that its used to drain out water, but can it be used for another purpose?
  2. Aug 20, 2008 at 10:51 AM
    Toyhauler
    SoCal
    so the rear d rings won't just be a "plug and play" to the front then huh? I ordered the same d rings that were in that "cheap diy" thread, so i am already expecting to take a 1/2" drill bit to increase the diameter of the whole.
    I just need a quick fix on how to get the d-rings out of the rear and into the fronts.
  3. Aug 20, 2008 at 10:53 AM
    Yaberries
    Yaberries Well-Known Member
    SoCal
    Was 08 PreRunner Off-Road, Now 2015 TRD Off-Road Super White
    Front D-Rings, Blacked out grill & surround
    For what its worth I got the kit from Toyota, comes with a template to position the holes, plus the backing plates. I haul dirt bikes around with no problems so far. The rings are 'supposed' to mount on the side of the bed not the floor.
  4. Sep 11, 2008 at 6:35 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
