So I took height measurements of my stock '19 Sport...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorrinRadd, Jul 19, 2022.
  1. Jul 19, 2022 at 7:16 AM
    NorrinRadd
    NorrinRadd [OP] Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Are these normal heights from the factory? It was done with nothing in the bed but a full tank of gas, so there is that to think about. Measurements taken from center of hubcap to bottom of fender flare so tire inflation is not a thing (I still aired them all to 32lbs first lol):
    LF: 20.25" RF: 20.5"
    LR: 20.5" RR: 21.5"
    That right-rear is a full inch higher? And the left-front is 1/4 inch lower?
    This week I'm having Eibach Pro-Truck Coilover 2.0 Stage 2's (E86-82-007-01-22) installed (I don't have the tools or a lift or the time to do it myself) so will take measurements after installation to compare. At least I can adjust the front heights individually this weekend to level the front...
    TexasTacoLT likes this.
  2. Jul 19, 2022 at 7:19 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Left rear is taking the weight of the tank. You are also more than likely experiencing a phenomenon knows as "taco lean"
    Pretty standard actually.
    Borracho Loco and TexasTacoLT like this.
  3. Jul 19, 2022 at 7:22 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    More discussion can be found here.
    https://www.tacomaworld.com/threads/taco-lean-solution.707400/
  4. Jul 19, 2022 at 7:26 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    Yeah, that's "normal" for a Tacoma. It's said that it is due to the weight of the tank, battery and driver all being on the driver's side of the truck. It's a well known quirk that you would think Toyota would have come up with a solution for by now.
    There are affordable 1/4" spacers available for the front D/S that will level it out. I got mine from Toytech.
    After a lift it will likely be level again for a period. Without a remedy though, once the suspension is broken in/settled, you'll most likely see the lean again.
    EDIT: At one point, I had 700lb springs on my truck mainly to compensate for the added weight of my bumper/winch, but also to mitigate the "Taco lean". I found that the springs made it ride like a dump truck and I'm back to 650lb springs with a 1/4" spacer on the front D/S corner; much more comfortable and no issues after about 20,000 miles with the spacer.
  5. Jul 19, 2022 at 8:35 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I believe thats called “Taco Lean” and it has been a thing since I can remember. Even with 2nd gens.
  6. Jul 19, 2022 at 8:42 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Your rear measurements seem a bit low and I’m surprised your front ones are the same. The passenger side is typically a bit higher. I’ve found is fairly easy to be off 0.25-0.5” when taking hub to fender measurements.
    I neglected to measure my truck pre-lift, but what I’ve been able to gather, typical stock 4x4 V6 DCSB measurements are:
    LF 20.5-21”. RF 21-21.5”
    LR 21.5-22” RR 22-22.5”
  7. Jul 19, 2022 at 11:44 AM
    NorrinRadd
    WA
    So I guess after the replacement struts I can adjust the front to be level but not the rear, will that affect anything or should I even care about the rear left to right not being even?
  8. Jul 19, 2022 at 11:58 AM
    Tacomod
    Tacomod Well-Known Member
    I have the same lean on my built 2021 OR. It wasn't there stock but after the suspension settled it definitely was. Same with aftermarket. Easy to fix the front with adjustable coilovers, but the rear leans 1" driver. I don't really want to put a block on it to level it out. Is there a more secure solution?
  9. Jul 19, 2022 at 12:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    A 1/4" spacer on top of the LF coilover seems to be a common solution for the lean.
    Don't worry about making the truck level F-R. The rake is there so you can actually use it as a truck.
    As far as various measurements go, when a sports car is corner weighted, trying to achieve the illusive perfect balance, it's easy to wind up with no matching measurements. Point is, measurements you're looking at don't impact handling anything like weight balance does.
    blu92in99 likes this.
  10. Jul 19, 2022 at 12:06 PM
    TexasTacoLT
    Killeen, TX
    '14 TRD Offroad
    Most trucks carry more weight over the front axle than the rear, when unloaded of course. That's why the difference in your measurements is more pronounced in the rear. A small change in the front will result in a larger change in the rear. Adjusting the front to make it level (left to right) should result in a level rear end as well, assuming your frame isn't bent/twisted.
  11. Jul 19, 2022 at 1:13 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Here are mine measurements. Don't remember if I have empty tank or full. Your LR seems low.
    FL 20.15 FR 20.35
    RL 21.14 RR 21.33
  12. Jul 19, 2022 at 2:57 PM
    gudujarlson
    Minnesota
    Taco lean is not a problem unless you make it one. It can however be offset with spacers, preload, and/or putting weight on the passenger side.
  13. Jul 19, 2022 at 3:49 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    All 3 of my "pre" Tacoma trucks all had the gas tank on the passenger side. They had a slight lean but it balanced out when I drove them.
  14. Jul 21, 2022 at 3:22 PM
    NorrinRadd
    WA
    So just picked up the truck after installation of the new Eibach's and here are the new measurements (compare to post #1):
    LF: 22.25" RF: 23.0"
    LR: 20.5" RR: 21.75"
    The left rear didn't change at all, right rear only went up 1/4 of an inch. Left front went up 2 inches and right front went up 2.5 inches. Still with a full tank of gas.
    Is this typical of new suspensions? I didn't add blocks to the rear because I'm putting on a new front bumper that weighs around 150 pounds so that will bring the front down a tad.
  15. Jul 21, 2022 at 4:03 PM
    gudujarlson
    Minnesota
    You are the proud owner of a squatted truck.
    https://m.youtube.com/watch?v=kzji7m50ENc
