so if i.....help
Discussion in 'Hawaii' started by m0sing808, Feb 28, 2013.
  1. Feb 28, 2013 at 5:04 PM
    m0sing808
    m0sing808 [OP] Well-Known Member
    install anything aftermarket i would void extended warranties....what if i took it out before bringing it in?? does that help.... what about aftermarket rims and tires doea that void anything???
  2. Feb 28, 2013 at 5:10 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    stealership has to prove said aftermarket part caused failure. so technically NO they dont void your warranty, but the dealership will give you a hard time depending on which one you go to.
  3. Feb 28, 2013 at 5:11 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    This has been brought up quite a few times. I can't say that I have the "definitive" answer for you but from what I've read in passing, no, wheels and tires won't void your warranty and neither will new shocks or suspension components UNLESS those parts are what caused whatever failure happens to happen.
    I'm sure someone else could chime in with more solid facts for you, but that is the sum of what I've read.
  4. Feb 28, 2013 at 5:13 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I just went in for my 15K service and wanting them to check out a "clunk" I was having.
    They asked if I had aftermarket suspension components, and gave me the "Yeah, we can't really do anything with that, because you have voided the suspension part of your warranty."
  5. Feb 28, 2013 at 5:13 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    I believe CAI, throttle body spacer, some exhaust and wheels and tires are OK.
    Check with the dealership.
  6. Feb 28, 2013 at 5:14 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    They weren't happy about my oil slicks or flame thrower . . . silly dealership
  7. Feb 28, 2013 at 5:18 PM
    650H1
    Michael
    VA
    yeah, flux capacitor killed it for me :eek:
  8. Feb 28, 2013 at 7:22 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    even that seems a little skiddish...asking a yes or no question does not prove shit.
  9. Feb 28, 2013 at 9:51 PM
    m0sing808
    thanks... nice rims btw!!! aloha
  10. Mar 1, 2013 at 10:02 AM
    urusai808
    urusai808 Member
    honolulu
    08 d-cab LB
    ^ unless the aftermarket part caused the problem, wont void.
  11. Mar 5, 2013 at 11:42 AM
    1uzrnr
    1uzrnr The NotaRC 4runner :D
    Washington
    86 Samurai stockish
    Couple
    There is only one dealership brand here and they will deny anything they can. I went through a huge fiasco with the rear end in my 05 and they wouldn't budge. Even the military lawyers said I had a case, but I had no way of winning because of who they know in the judicial system.
