So im trying to swap trans
Discussion in '1st Gen. Tacomas (1995-2004)' started by Idrivetoys, Nov 8, 2010.
  1. Nov 8, 2010 at 5:05 PM
    Idrivetoys
    Idrivetoys [OP] Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    Changing my DC to Manual if i find the parts soon, i found 96+ model tacoma 4WD, im not looking to change to 4WD but i need the trans for sure, havent researched the driveshaft yet, so it may be the same length/spline count as mine.
    My question is, can i use the 4WD trans on the 2WD Prerunner and not use the transfer case? What will i need to change if anything? Tail section of the trans?
    Thanks in advance!
  2. Nov 9, 2010 at 5:35 AM
    Idrivetoys
    Yuma AZ
    Anyone?
  3. Nov 9, 2010 at 5:45 AM
    Idrivetoys
    Yuma AZ
  4. Nov 9, 2010 at 6:31 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    You might want to check TTORA if you haven't already as well
