So... is that your final answer? (Greasing the yoke)
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98SR5Red, Jun 26, 2010.
  1. Jun 26, 2010 at 11:53 AM
    98SR5Red
    98SR5Red [OP] Well-Known Member
    Justin
    Maine/New Jersey
    98 SR5
    Sway-Away racerunners up front, Downey leafsprings (5 pack) and Bilstein 5125's in back, 2" body lift, K&N/AEM air intake, Energy Bushings, Nology plug wires, Custom front/rear bumpers and sliders. Downey header and custom exhuast from there back.
    I spent a good part of my friday night researching here and many other sites for correct procedures for greasing the drive shaft of my 98 4x4. Most of its pretty straight forward. I got the straight Lithium Base and the Moly-Fortified stuff for the double cardon and slip yoke.
    Buuut... Still a little grey when it comes to howmuch grease shold be pushed into the yoke.
    2-3 pumps?? Till I JUST start to see it coming out the end?
    I definitely don't want to seize it up.
    Thanks for anyhelp guys/gals.
  2. Jun 26, 2010 at 12:17 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    The fresh grease it pretty gray to start with, IIRC. I have no idea what the "capacity" is, but the yoke can take a lot if it has not been done in a while. I was surprised at how much mine took it after I bought it used and did it for the first time. The nature of the thing is that it pumps out grease by normal driving action. Pump it in until you see some shiny inner shaft appearing. At some point, you will actually see the pressure of the grease pushing the inner shaft out. At least do it that much, then go find some speed bumps to drive over and check it to see if it pumps out a bit of fresh grease along the inner shaft. The goal is to avoid metal on metal contact. Of course, too much, and it spatters all over the underside...but that just protects the truck...
    Some folks (Tacomaman06 comes to mind) have completely dismantled the yoke, cleaned it out, and repacked it. After high miles or prolonged serious offroad action (dust, mud, immersion) this is probabaly not a bad idea to truly extract really old, fouled grease and contaminants that may be packed in at the innermost yoke.
    Did I answer the question?
  3. Jun 26, 2010 at 12:23 PM
    747 function > form
    1st Gen.
    ^x2...I pump it in until it starts coming out (don't know if that's right; it's just what I do)...I think a good part of the grease ends up on my undercarriage when the grease is "flung" out. I re-grease mine every 3-4 mos.
  4. Jun 26, 2010 at 12:27 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    U should have 9 zerks on ur taco...I do :D I also use "Lucas Red N' Tacky #2" all around"...Great Product!!!
  5. Jun 26, 2010 at 12:29 PM
    747 function > form
    1st Gen.
    ^x2 on the Lucas Red N' Tacky #2...one of the mods (tacomaman06, I think) recommended it in another thread also.
  6. Jun 26, 2010 at 12:30 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    My Haynes Manual says...Pump grease into the the slip joint zerk until it comes out of the slip joint seal...
  7. Jun 26, 2010 at 5:54 PM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    QFT
    I use Mystik JT-6 Hi Temp on everything. Works fine.
  8. Jun 26, 2010 at 9:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Very good advice. Worth listening to.
  9. Jun 27, 2010 at 7:36 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The Yoke & the u-joints are two different things.
    With the U-joint, you can pump all you want, it'll just keep coming out.
    The Yoke is different. Too much grease in the yoke, could actually prevent the yoke from functioning properly and you might get some vibrations. The grease doesn't have anywhere to go and the driveshaft can't collapse (grease doesn't compress).
  10. Aug 20, 2010 at 4:31 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I don't want to argue or say you're wrong here, but why does the FSM and the Haynes manual and the online DIY directions all say to pump until you see grease come out? It was my understanding that the slip yoke slips and in the process will pump grease out as it moves? I just did mine today and pumped until the yoke started to move but never did pump enough to push any out, mainly because I ran out of grease and didn't feel like going to buy more.
  11. Aug 20, 2010 at 4:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I just do about 7 pumps and call it good.
  12. Aug 20, 2010 at 8:33 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i disassembled mine this week and cleaned all the old grease out,packed er with new red and tacky #2 and put er back together. the most important part of doing it is marking the orientation of the shafts,they need to be put back together the same way they come apart.
  13. Aug 20, 2010 at 8:53 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    I usually do it til it is hard to squeeze, hear a popping/cracking sound, or until it comes out
  14. Aug 21, 2010 at 4:09 AM
    Janster
    Jandy
    Lancaster, PA
    Do some searching.
    Go to www.google.com and type in "Too much grease in slip yoke"
  15. Aug 21, 2010 at 4:35 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I know I am being very mature, but reading this thread with a dirty mind is hilarious. :D
  16. Aug 21, 2010 at 8:03 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    :rofl:
  17. Aug 21, 2010 at 8:11 AM
    747
    747 function > form
    1st Gen.
    ^ huh huh, PUMP, huh huh.:D
  18. Aug 21, 2010 at 12:24 PM
    StandingCow
    NJ
    LoL, that one and, "I do about 7 pumps and call it good". ROFL
