So is this something common?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Tom, Mar 15, 2009.
  1. Mar 15, 2009 at 7:50 PM
    Tacoma Tom
    Tacoma Tom [OP] Well-Known Member
    Sunny Arizona
    07 DBL TRD
    Hey guys,
    I'm Tom, the new to me owner of a 07 Tacoma Dbl Cab. Here is the story, so I test drive this vehicle at the dealership. No problems, drives nice (only 16k miles) and everything seems fine. Come back a few days later after working numbers with them and purchase the vehicle. They wash it while I'm doing paperwork. When I get in, I notice a very slight musty odor, but it went away quickly and figured it was wet shoes on the carpet or something. Come out the next day and the truck is nasty, sour water smell inside the cab. I Pull up the carpet and see standing water on both the drivers and passengers floorboard. Called up the dealership and I'm bringing it in tomorrow. I'm assuming the water came in while they were washing it. I looked in all the usual spots and didnt see anything. Anyone experience this before? I did a serach but didn't turn up much. Hopefully they didn't get rid of my trade in, because if they dont get this and replace the carpet, they are getting it back!!!!.
    Anyways, thanks for listening to my rant. If anyone knows where a common leak is, please let me know. I'm not familiar with this stealership and figured I would give them a head start.
    New Tacoma owner
    Tom
  2. Mar 15, 2009 at 11:18 PM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    first welcome to TW!
    as for your problem, I'm not aware of issues but I had a leak in my roof liner this winter. Like you, a very nasty smell. I still haven't traced it down either, but I suspect the 3rd brake light.
    One thing to check is your cowl vent. On my old Jeep, leaves would get in there and block the drainage hole and thus the only place the water could come was into the cab through the HVAC.
    good luck!
  3. Mar 15, 2009 at 11:18 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    I would be livid, how can they get that much water in there washing it. Sounds like there is something seriously wrong with your truck.
  4. Mar 16, 2009 at 12:35 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    The same thing happened on my brother chevy colorado, the water came in from the 3rd brake light and water got everywhere.
  5. Mar 16, 2009 at 3:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take it back to the dealer you bought it from and tell them about it.
    And complain until they do something to fix it!!!
  6. Mar 16, 2009 at 6:26 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    I would be VERY concerned that the previous owner sank your truck or flooded it. Did you get the CarFax report? Does it still have the warranty?
    I sank my 2005 Dodge Dakota in water and had 3 inches of H20 in the cab. Once it dried up on the surface, it looked fine. The dealership that fixed it pulled up the upholstery 1 week later and found water still under the padding. They had to replace everything...including the engine :eek: (hydro-locked). I loved that truck too :(
    Anyway, after the engine and upholstery were replaced, they fired it up. Water shot out of the exhaust system like a canon. It had been in there now for 3 weeks! They returned it that same day and I sold it the next day to an unsuspecting dealership. The truck was sure to have issues (electrical, rust in the exhaust, etc).
    Bottom line...even if they fix a vehicle like that, you are going to have more issues down the road (literally). And most problems will occur after the existing warranty runs out. Get some answers and don't stop until you do. It can get VERY expensive if you don't!
  7. Mar 16, 2009 at 6:39 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Welcome to TW. If you do a search on here, there have been a few people that have reported issues with leaking around the windshield seal I believe. I think there may even be a TSB about it.
    Here's the link to the TSB: http://www.divshare.com/download/4099365-aca
  8. Mar 16, 2009 at 7:13 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    Welcome to TW Tom from Arizona :wave:
    Sounds like you got some good suggestions & hope you are at the dealership today getting a solution to this. Its not normal at all & that stinks (literally) happening on your new to you truck with low miles? Wish the best on a fix & post up what the outcome is.
  9. Mar 16, 2009 at 7:13 AM
    redlight
    redlight fresh taco
    Aaron
    Thornton, CO
    08 TRD Off Road
    TRD Cold Air Intake & Cat Back Exhaust 3" Toytec ULK, Kings in the back Dual Battery Lights, electronics, etc...
    I would assume if it was actually wet when you picked it up (not prior damage) then I'd guess some idiot left a window open or something similarly stupid. A small leak in a windshield wouldn't cause that much water... but you could always run through a carwash to test it yourself, with the manager there.
    My 08 has about 15k miles and I've gone through a number of carwashes with zero problems of leakage.
  10. Mar 16, 2009 at 7:20 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Coolant, leaking heater core? When you run the A/C is it leaving a nice puddle on the ground under the truck, if not may be a pulgged A/C drain.
  11. Mar 16, 2009 at 10:28 AM
    JWWPHOTO
    JWWPHOTO Well-Known Member
    Westlake, Louisiana
    2008 Tacoma Pre-Runner w/ TRD packag
    Try changing your Cabin Air Filter !!! I had the same problem and you gotta change it from time to time. It is in-behind the glove box. I ususally get mine from Autozone or O-Reilly's and they sometimes need 1 day to get one in for me. $18-20. My wife has a 2004 Camry and it has one too. It started to smell like wet carpet. Changing the "Cabin" air filter, problem went away!
    Jeff W. Waldrop
  12. Mar 16, 2009 at 10:47 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    i'm willing to bet that it was something dumb that the dealership did while washing it, not a previous problem...about 7 months ago we had tropical storm Fey drop over 2 feet of rain on us in a couple days. all of the roads here were severely flooded (melbourne florida). i decided to go exploring after the rain stopped to see the dammage. i ended up driving across a lowlying road, and drove through water for abotu 100 yards that was just below my door handles, and stayed completely dry inside...moral of the story is that from my experience, other than the leaky windshield, our trucks are very watertight...so most likely it's the dealer's fault.
  13. Mar 16, 2009 at 10:52 AM
    TacoCo
    Colorado
    You'd be surprised. I remember someone posting that their truck floor was damp every time that it rained.
  14. Mar 16, 2009 at 6:29 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    Thanks for the responses guys. Under the carpeting in the rear seems fine. Carfax shows 0 reports. The truck is an 07 but only has 16k miles. Heading to the dealership tomorrow....... I'm thinking leaking windshield seal or floor board plug missing?
    Anyways, thanks for the welcome, looking forward to enjoying my Tacoma (hopefully start soon) hahaha
  15. Mar 16, 2009 at 6:39 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    What about a/c condensation leaking?
  16. Mar 16, 2009 at 7:10 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    A/C is a good possibility. I need to take a look at the drain and put something down to check for leaking. It was on both sides of the floorboard, I think A/C would only shop up on one side?
  17. Sep 11, 2009 at 4:31 AM
    tacobale
    tacobale Well-Known Member
    Any fix for this truck?
