So I've been thinking.... Tacoma with a V8 option.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hail-bop Command, Jun 10, 2008.
  1. Jun 10, 2008 at 4:06 PM
    #61
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    DAMM! There you have it Hailbop! Chris is the bottom line here. At this point in time with fuel and economy woes-those OTHER car makers will probably suspend production and Toyota won't touch a V8. Sad.
  2. Jun 10, 2008 at 4:07 PM
    #62
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dodge has a horrible reputation at the dyno shops. That 305 h.p. at the crank is probably close to 220 at the wheels.
    I had a supercharged motor for 90,000 miles. Never burned oil, ran like new. Still ran like new when I sold it. How is it affect reliability?
    On the newer trucks, there is no headache. Toyota got the AFR's right on the money (if not a little on the rich side). And the SC only adds about 60 lbs. to the vehicle weight. Much less than a V8 swap. :)
  3. Jun 10, 2008 at 4:18 PM
    #63
    hail-bop Command
    hail-bop Command [OP] Well-Known Member
    I Don't Crawl I Haul A$$!
    Great points....:)
    But I still would rather have a FACTORY Tacoma V8 than a V6 with an after market SC. I'm really impressed with the 90K you put on your supercharged vehicle but you and I both know that type of scenario is a rare instance... More moving parts heightens the odds of failure.
    Also how does supercharged equipped vehicles do offroad against stuff like dust and vibration?
  4. Jun 10, 2008 at 4:24 PM
    #64
    hail-bop Command
    SC Kit will run you $5,000.00 plus you still need to buy more things to go with the kit that would easily be another $2,000.00....
  5. Jun 10, 2008 at 4:41 PM
    #65
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What things are needed with the newer Gen Tacomas?
  6. Jun 10, 2008 at 4:50 PM
    #66
    hail-bop Command
    >AFR Sensor Calibrator $228.00
    >Mass Air Flow Fuel & Timing Calibrator $500.00
    >SuperGrip Supercharger Pulley for 4.0L Toyota Trucks $129.99
    >MAF Sensor Calibrator $228.00
    >DB Gauge (Blue LED) with LC-1 Kit, O2 Sensor $289.00
    >OBDII BR-3 Scan Tool $99.99
    Total=$1474.98
    I'm sure I missed a few things
  7. Jun 10, 2008 at 4:51 PM
    #67
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
  8. Jun 10, 2008 at 4:52 PM
    #68
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No, its not. I have been around forced induction for a long time. If you run high boost and high compression, then yes, you will run into problems. The TRD SC is running 6 psi. max. boost. As long as the AFR is not leaning out, there will be no problems. The SC it self, is not much more than a small gear box and 2 twisted impellers. It also has a bypass system, which allows running in vaccume when no load ( or little) is applied, and if the engine goes into limp mode, the SC will be in bypass so as to not burn the motor up do to lean out.
    Like this?
    I beat this truck like it owed me money. Never had a problem with it. Oil samples all came back good. At 100,000 miles, I pulled the head thinking it needed some maintenance. It didnt and I put it back on. It looked like new, No measurable wear on the cam lobes, just a nice golden oily inside. :D
  9. Jun 10, 2008 at 4:53 PM
    #69
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    None of these are "needed" with the install of the SC on a 2nd gen. Tacoma.
  10. Jun 10, 2008 at 4:55 PM
    #70
    hail-bop Command
    Wow interesting... So TRD or URD Supercharger?
  11. Jun 10, 2008 at 4:57 PM
    #71
    hail-bop Command
    It makes the SC run better right? Doing important thinks like keeping the AF ratios and Timing in Check?
  12. Jun 10, 2008 at 5:03 PM
    #72
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Neither. Alpine. :)
  13. Jun 10, 2008 at 5:07 PM
    #73
    hail-bop Command
    I think you changed my mind...:)
  14. Jun 10, 2008 at 5:10 PM
    #74
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The ECU already does that on the newer trucks. Under full power, the new SC's AFR's are 12.0-12.2. Part of the install includes new injectors, and a reprogram of the ECU. Something that wasnt offered on the 1st gen SC'ed trucks, which is why it took alot to get them to run right. Also, If forced induction was soo bad/unreliable, dont you think that the trucking industry would have figured a way to avoid using it? Or the light aircraft industry, boats, etc. :)
  15. Jun 10, 2008 at 5:10 PM
    #75
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Bore and/or stroke the 4.0 to 4.4 for 10% more displacement, work with the VVT and cam profiles, smooth large tube exhaust manifolds, with free flow cats, muffler, etc for about a total of 20-25% increase in power. Lighter than the V8, but even better; there is much more room remaining in the engine compartment so the cooling fan is not right up against the radiator, the exhaust manifolds are not almost touching the firewall and the inner fenders at the same time. That is just me; I have always hated an engine compartment that is crammed full to the point that many services require partial vehicle disassembly.
  16. Jun 10, 2008 at 5:14 PM
    #76
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ME TOO!!!! :D
  17. Jun 10, 2008 at 5:15 PM
    #77
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not trying to change your mind. Im just trying to debunk some myths that exist about SC's and the like. :)
  18. Jun 10, 2008 at 5:15 PM
    #78
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    This has turned into a most excellent thread. :thumbsup:
  19. Jun 10, 2008 at 5:18 PM
    #79
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Psst.....if you like any of the stuff I said, can ya throw me some rep.? Im only 3 points away from geting the double green rep thing...............Ahem.......yes, it is a most excelent thread. :)
  20. Jun 10, 2008 at 7:27 PM
    #80
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    i like the idea personally, unfortunately i don't think my wallet could afford the price of the fuel with prices looming on $5 per gallon for gas and crude oil at $131 per barrel today
