SO JUST HOW HIGH CAN WATER GO UP THE 2.7 TACOMA ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Aug 29, 2017.
  1. Aug 29, 2017 at 3:51 AM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    Not that I have plans of turning mine into a Uboat or anything. But this fucking storm has us surounded. And Ive been home for 5 days going stir crazy. My 2.7 Base Taco is so not high just a 2.75" lift and 15" 275s. Started to go to the grocery store but instead Took it round the block cause were on a F×××ing Island in our Subdivision. And did not want to risk water damage. Got me thinking I wonder just how high water can go in the engine bay with out boging out. Surely by then there would be water in the cabin. But in a life or death situation....Surely theres some crazys on this forum that have traveled this path both unintentionly and some said screw it.
  2. Aug 29, 2017 at 3:54 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Up to the top of the inner fender liner I'm guessing before it hits the airbox
    hoverlover likes this.
  3. Aug 29, 2017 at 3:55 AM
    tacotruck 2.7
    Katy TX
    Wow thats high.
  4. Aug 29, 2017 at 4:01 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    What about water contaminating the differential fluid via the breather?
    BillsSR5 likes this.
  5. Aug 29, 2017 at 4:09 AM
    tacotruck 2.7
    Katy TX
    My model dont have the diff breather. Guess thats good. Even then a fluid dump and refill would be in order. Otherwise what good would it do to spend thousands raising a truck if its only as high as the diff breather ?
  6. Aug 29, 2017 at 4:13 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You put the diff breather up high around the gas cap.
  7. Sep 1, 2017 at 11:00 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'd be willing to bet that it does. It allows for the expansion of oil when heated by venting air rather than blowing out the seals.
  8. Sep 1, 2017 at 11:30 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I'd be more worried about what's in the water than the depth, I wouldn't go 1/4th up the wheels without a diff breather. I might consider letting my tires be fully submerged with breathers and a snorkel
  9. Sep 1, 2017 at 11:33 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If I was in that situation, I could give 2 shits about contaminated diff fluid. Water in the diff is not going to shut the truck down in the near future.
    Make your emergency run, then worry about fluid changes.
    BillsSR5 and TexasWhiteIce like this.
  10. Sep 1, 2017 at 11:44 PM
    Oreo Cat
    You said you're basically on an island, how far will you have to drive in water?
  11. Sep 2, 2017 at 2:27 AM
    Muddinfun
    Muddinfun Well-Known Member
    If it's a daily driver and worth more than $2K, I open the door and look out. If it up to the rockers, I back up. If it's a beater, hell with it. drive till your butt gets wet.
    Just for info, if the water gets to the bottom of the dash, the insurance companies consider it a total.
  12. Sep 2, 2017 at 5:07 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Exactly. Life or death situation, I'd be confident our tacomas would get us out, worry about the damage on it later. With my prerunner, at stock height, it's 20 inches before it hits the bottom of the cab. 17 inches before it hits the exhaust pipe so if i go in water deeper than that, just don't stop.
    TreyStewart likes this.
  13. Sep 2, 2017 at 5:24 AM
    TreyStewart
    TreyStewart Well-Known Member
    Trey
    Tigerville, South Carolina
    2013 PreRunner
    URD everything, nfab front bumper with 2 LED bars, maxtrax spindle lift, Baja rack
    A couple weeks ago I was at my parents house in a New Orleans. It flooded one weekend because of a ton of rain and the city water pumps were broke. My buddies house was flooding (life or death situation) and I went to go get him. I don't currently have any lift on my Prerunner and the deepest I went was up to the grill. I've been fine ever since
    TexasWhiteIce likes this.
  14. Sep 2, 2017 at 6:01 AM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    I have a 5 lug (which I believe yours is) and I definitely have a breather...changing out that diff fluid should be a top priority. Then extend the breather.
  15. Sep 2, 2017 at 6:39 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There are ROADS around here with river crossings and no bridges where the water is 18-24" deep. People drive through it every day. I've done it countless times in a number of vehicles over the years. I feel pretty good as long as the tire isn't completely underwater, but I've made crossings up to my headlights and had the gas pedal underwater in Jeeps in the past.
    But this is on well marked roads and trails for short distances. The problem in an urban environment is not being able to know exactly where the shoulders of the road is. It is VERY easy to drive off the road into a ditch where the water goes from 2' to 10'. It all looks the same from the top.
  16. Sep 2, 2017 at 1:50 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    One of these pics shows what seems to be just water on the roadway. I would be very wary of any distance in water over 1/2 your wheel/tire diameter. Your air intake is up from that, but splashing water has a way of finding things. If the water is moving, or you can't see clearly defined road edges, no go.
    http://humor.desvariandoando.com/2007/11/y-el-rio-volvi-su-cauce.html
    highriserkaiser likes this.
