So let's talk ball joints...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09BlueBeast, May 10, 2016.
  1. May 10, 2016 at 3:10 AM
    09BlueBeast
    09BlueBeast [OP] Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    Ok so I'm in need of ball joints. Who has successfully replaced their lower ball joints ,and would you say that it's worth it or should I just shell out for me LCA's?
  2. May 10, 2016 at 4:15 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    to be helpful here, I will actually reply: replace it with OEM.
  3. May 10, 2016 at 7:34 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Don't know if they're worth it, but it's a service/maintenance thing when they go bad you change them, thats it....
  4. May 10, 2016 at 7:38 AM
    Pigpen
    Dan
    Northwest Montana
    I'm interested too.
    Is the general consensus OEM, or is there a better option? I'm curious, as I'm rebuilding my front suspension due to seized alignment cams/ LCA bushings. While it's apart, should I replace the ball joints? How many miles are they generally good for - I know there are many variables to affect this, but 50K...200Kmiles?
  5. May 10, 2016 at 7:38 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I most def would...
  6. May 10, 2016 at 7:39 AM
    09BlueBeast
    Cody
    Denver
    [ that you know what I meant
    Well my truck has 113,000 and hasn't been off road once in the 70k I've had it, trucks never been abused or missed a maintenance interval since I've owned it and my ball joints boots are broken on both sides....
  7. May 10, 2016 at 8:14 AM
    09BlueBeast
    Cody
    Denver
  8. May 10, 2016 at 8:14 AM
    09BlueBeast
    Cody
    Denver
    Never turned a wrench before
  9. May 10, 2016 at 8:18 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Thread cleaned up since there's a chance for decent info/discussion here. @09BlueBeast and @127.0.0.1 forgive my editing of your posts.
    scottalot likes this.
  10. May 10, 2016 at 8:19 AM
    09BlueBeast
    Cody
    Denver
  11. May 10, 2016 at 8:20 AM
    09BlueBeast
    Cody
    Denver
    That's what I've read, but I have seen where people have completed it with the biggest issue being the removal of originals.
    And did u mean ball joints or bushings?
  12. May 10, 2016 at 8:33 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No such luck for me, when my adjusters seized I swear to Christ it was like 2 parts became 1 & it took about a day to get those nasty fuckers drilled/pried/heated up/sawzalled/ with just a dash of cut off wheel to exorcise those bastards out....
    keyword: ANTI-SEIZE
  13. May 10, 2016 at 8:44 AM
    09BlueBeast
    Cody
    Denver
    Yeah luckily I talked with the local dealership and showed them my mechanics badge from Texas and luckily there going to give me the tech's discount which knocks each LCA to like $220 but still hurts to spend $500 to replace 2 $50 parts
    scottalot[QUOTED] likes this.
  14. May 10, 2016 at 8:59 AM
    09BlueBeast
    Cody
    Denver
    They don't use salt here anymore luckily but I'm sure they'll still be a PITA
  15. May 10, 2016 at 9:51 PM
    09BlueBeast
    Cody
    Denver
    Lmao
  16. May 23, 2016 at 3:02 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    No more salt in Denver? What do they use now? From what I looked up last year, it looks like they usually spray calcium chloride on the road. Looks like this:
  17. May 23, 2016 at 3:56 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    I did a set of lca bushings. It wasn't what I'd call fun, but with good tools it's not too bad. Don't cheap out on the sawzall blade quality. The worst of it was a couple months later I had to do it again because the crappy Moog rear bushings came loose. There's a bunch of us that had the same problem. But the op asked about ball joints. After our moog lca bushing issues, I'd stick with oem ball joints.
  18. Aug 2, 2016 at 11:13 PM
    09BlueBeast
    Cody
    Denver
    Bringing this one back to life... Yeah we got sidetracked on bushings, but moog makes damn good ball joints and tie rod parts
  19. Aug 2, 2016 at 11:15 PM
    09BlueBeast
    Cody
    Denver
    The plan as of now is buy two LCA's from a junk yard, replace the ball joints with moog, and put in polyurethane bushings.
  20. Aug 3, 2016 at 5:52 AM
    CroResident
    CroResident Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    let us know!
