So my bottle jack won't raise my truck high enough too put a spare tire on. Thanks Toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nobleyota, Mar 3, 2019.
  1. Mar 7, 2019 at 2:40 PM
    #61
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Nope. Just plays ostrich when called to explain his opinion.
  2. Mar 7, 2019 at 3:46 PM
    #62
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Bingo
    loginfailed likes this.
  3. Mar 8, 2019 at 6:42 AM
    #63
    96carboard
    96carboard Well-Known Member
    mynewtoy likes this.
  4. Mar 8, 2019 at 6:51 AM
    #64
    PzTank
    Above the Notches
    Missing the point....jack has a 1 1/4 inch total
    lift after 46 pumps- my question to you was how would you “make it work just fine”?
    TacomaSport86 likes this.
  5. Mar 8, 2019 at 6:52 AM
    #65
    TacomaSport86
    Cmon @96carboard answer the question
  6. Mar 8, 2019 at 6:52 AM
    #66
    96carboard
    And the answer is AN INCH AND A QUARTER AT A TIME. Explain to me how that is such a difficult concept for you to grasp.
    mynewtoy and DirtTaco like this.
  7. Mar 8, 2019 at 6:53 AM
    #67
    TacomaSport86
    TOTAL LIFT IS INCH AND A QUARTER FOOL cmon dummy.
    PzTank likes this.
  8. Mar 8, 2019 at 7:06 AM
    #68
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    jack it up 1.25", put a stand under truck. lower jack, add another block under jack. jack up 1.25". raise stand under truck by 1.25". lower jack. add another block under jack. repeat 10000x. finish changing your tire right around Christmas if you start today.
    mynewtoy, wilcam47, Tacotj and 3 others like this.
  9. Mar 8, 2019 at 7:13 AM
    #69
    PzTank
    Above the Notches
    Working just fine...
    seedy_tea[QUOTED] likes this.
  10. Mar 8, 2019 at 7:25 AM
    #70
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    cardboard_box: "see told you i could be done. never said how long it would take."
  11. Mar 8, 2019 at 7:30 AM
    #71
    PzTank
    Above the Notches
    Not difficult to grasp at all.
    It’s just another mischaracterization.
  12. Mar 8, 2019 at 7:42 AM
    #72
    96carboard
    It only takes a lot of tries if you do something silly, like jack against the frame. If you lift closer to the wheel, you won't need much more than 1.25" total.
    Or another trick with a little bit of imagination, you might even be able to do the job without a jack at all. Everybody who uses a truck as a truck has a bunch of big ratchet straps with them wherever they go, right? So just put a stick, or something under the FRAME, and ratchet strap up the suspension. Did that once years ago stuck with an old truck with a rusted jack that wouldn't budge.
    Ingenuity is what is supposed to separate people from animals.
    mynewtoy, Stryker420 and DirtTaco like this.
  13. Mar 8, 2019 at 7:44 AM
    #73
    DirtTaco
    DirtTaco Well-Known Member
    I had a chainsaw but no jack once. Drop a tree and there’s all kinds of leverage for you to get the truck lifted up. Had a friend to help luckily.
  14. Mar 8, 2019 at 7:54 AM
    #74
    TacomaSport86
    You cant fix @96carboard stupid
    loginfailed and PzTank[QUOTED] like this.
  15. Mar 8, 2019 at 8:02 AM
    #75
    PzTank
    Above the Notches
    Gonna adopt your tagline to stay above the fray, hopefully, from here on in.
  16. Mar 8, 2019 at 8:12 AM
    #76
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Speaking of 1.25 inches. I’m here. :anonymous:
    loginfailed, tcBob, mynewtoy and 4 others like this.
  17. Mar 8, 2019 at 8:19 AM
    #77
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I carry this with my OEM jack to compensate for the needed height. Then when my spare is replaced and truck still off the ground, I get my wife and kids out of the truck to play the jenga game to lower the truck.
  18. Mar 8, 2019 at 8:47 AM
    #78
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Wait a minute jberry, keep your sexual stuff away from here.
    jberry813 likes this.
  19. Mar 8, 2019 at 8:49 AM
    #79
    TacomaSport86
    Jenga!
  20. Mar 8, 2019 at 9:02 AM
    #80
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Learn how to use a jack first.
