So my tires rub after my OME lift...... What should I do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trailhunter, Feb 27, 2014.
  1. Feb 27, 2014 at 8:47 PM
    Trailhunter
    Trailhunter [OP] Member
    Grey wire
    I lifted my 01 4rd with a 2.5 OME front and darak PAC in the rear. I bought 255 85 16 toyos but I'm rubbing in all 4 corners.... I bashed in my front fender for more clearance but it still rubs when flexed. The rears rub too on the front of the rear fender..... I was thinking about a long shackle for the rear and a 2inch coil spacer ..... Will I have issues with a spacer up front with my OME coils?
  2. Feb 27, 2014 at 8:56 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Alignment can make a difference....caster setting
  3. Feb 27, 2014 at 9:18 PM
    DarkShark
    DarkShark Well-Known Member
    Clark
    Medford/Southern Oregon
    03 DCab 4wd
    Icons, Camburg and custom stuff......
    Don't do anything like that!
    1 Get and alignment and push the caster forward. Caster being out doesn't affect your tires.
    2 Replace the fender flare bolts with washers and flat screws.
    3 Trim the front lower part of your rear flare with a dermal tool.
    If you need pictures let me know. I run 255's and OME as well
  4. Feb 27, 2014 at 9:21 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Cutting tools
  5. Feb 27, 2014 at 10:27 PM
    Motorep
    Motorep Active Member
    Kevin
    San Diego, CA
    '03 Xtra Cab V-6
    OME 883's, Dakar leafs, and OME shocks, All Pro Apex sliders w/fill plates, 10lb Powertank, generic pre-runner style front bumper with PIAA 520's, Kenwood 6.1 touch screen head unit, JBL 3 channel 760 watt amp, Kicker 6X8 component speakers w/tweeters mounted in the stock location, 10" Pioneer sub, Dynamat installed in the doors and the rest of the cab, custom dog "bench" installed behind the seats, etc...
    ^This^! I had issues rubbing on the front of the rear wheel wells when flexed out too. I just trimmed the lower flare and the inner liner where I was having issues. I'm on 255 Cooper's with OME too.
  6. Feb 28, 2014 at 5:27 AM
    Trailhunter
    Grey wire
    I did an allinment the day after I put the lift in.....then I bashed and trimmed my fenders and flares as much as I could.
  7. Feb 28, 2014 at 5:40 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    I had to do many sessions of trimming after my lift and with my 10" wide wheels (12 1/2" wide tires).
    Can you post pictures of the rubbing spots? Is this when wheels turned at max or even when straight?
  8. Feb 28, 2014 at 7:52 AM
    Spoonman
    Jamie
    Alberta
    Guys here run 37s and don't rub. If you're on 33s and rub, you definitely haven't bashed them as much as you can!
  9. Feb 28, 2014 at 8:42 PM
    Trailhunter
    Grey wire
    Guys are running 37's with 2.5 inches of lift? That's impressive !!! Its more effort to post pics than fixing the issue for me lol. I'd like the extra lift anyhow ..... I still haven't built my bumpers and rocketet yet...... The front is gonna sag once I put 200lbs ( winch and bumper ) up front..... I went with the beefy coils cause of this. Now for the rear I think I might go with a slightly longer shackle .....and plug weld my spring perch and redrill the hole and 1/2 -3/4inch further back than stock....... No matter what the tires will rub in the rear when the rear end is fully stuffed........believe me I'm not new to this kidda stuff..... I'm new to keepin stuff stock... Well some what lol....I'll take your suggestions and see who had the best idea........now for the front will a 1.5 spacer + my lift act like crap off and on road? My whole idea of this build was minimal work for a good bush/ street truck. I don't want a shopping cart. Anyhow I'm 10 deep into a case so I'm rambling
  10. Feb 28, 2014 at 8:48 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
  11. Feb 28, 2014 at 9:07 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Stock wheels or aftermarket? Wheel specs?
    For the rear I was thinking axle relocation plates like TomTom said. They will center your axle/ center the wheels in the wheel well.
    Do you rub with normal driving or are you referring to rubbing when the suspension is flexed?
  12. Mar 1, 2014 at 9:44 AM
    Trailhunter
    Grey wire
    Flexing or hitting a big bump
  13. Mar 1, 2014 at 10:43 AM
    Mainmoe02
    Moe
    Austin, Texas
    Flexing and rubbing is a given with our trucks on 33's. I run 33x10.5 and for daily driving I'm fine, but when I flex and turn the wheel I get all kinds of rubbing. Trim what you can and if it's still too much then do a cab mount chop
  14. Mar 1, 2014 at 11:43 AM
    tomtom
    The Desert SW
    2012 FJ
    Shouldn't have to chop the cab mounts with 33s. Beat back the pinch weld. Push the caster forward if that doesn't work. I'm running 285/75r16s on 16x8 w/ 4" BS and only rub spot is on the frame. That's at whatever full stuff and full lock I can manage with the IFS.
  15. Mar 1, 2014 at 2:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    do
    NOT!!!!
    Put a spacer on top of you coil overs.
    Unless you want to bind your CVs all the time as well as UBJs and LBJs and basically destroy the whole front suspension of the truck and have it ride like complete and utter crap...then go ahead.
    Trust me when i tell you..you can trim more...believe me. haha i have 35s and tubbed the fire wall..but for 33s you have to get extreeeeemmmmllllyyy friendly with it. Beat the fucking shit out of it man. I know you love your truck, i love mine more then a human being should. But, its for the better :) haha
  16. Mar 2, 2014 at 6:41 AM
    Trailhunter
    Grey wire
    Ok....... I guess I need a bigger hammer lol..... Thx your the help
