So my truck wont start....
Discussion in 'Technical Chat' started by Databox, Oct 26, 2014.
  1. Oct 26, 2014 at 10:01 AM
    Databox
    Databox [OP] Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
    looking for some ideas before I have it towed to the garage.
    Some back story and info:
    2007 Taco Sport 6 cyl with automatic tranny.
    About a week ago I went to move the truck and it would turn over but not start. It seemed like it wasn't getting fuel.
    Something told me to shift the truck from park through the gears and then try again. I did...and it started right up.
    I've been driving it all week. It's started normally all week. This morning I drive it to church and when I go to leave...same thing. Turns over strong but wont ignite. Shifted through the gears multiple times. It just turns and turns but wont start.
    Any thoughts on where to begin looking??
  2. Oct 26, 2014 at 10:17 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    Turns over real strong. Has a full tank of gas.
  3. Oct 26, 2014 at 10:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check fuses.
  4. Oct 26, 2014 at 10:48 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    Headed back over there now. Fuses is on my list of things to check.
    What has me puzzled though is why it is intermittent. It seems like if it was a blown fuse what ever that fuse was protecting would not work and the problem wouldn't go away. But after the initial problem a week ago. It started and has drove completely normal all week. Now it is doing it again...this time however it's not starting.
  5. Oct 26, 2014 at 11:12 AM
    330d
    330d Active Member
    Caleb
    Upstate NY
    Shopping for it....
    Try in neutral instead of park? Might be the interlock...
  6. Oct 26, 2014 at 11:45 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    Tried starting it again with no luck. I couldn't find any blown fuses.
    Also hooked up a code reader. It showed P0102 Mass air flow sensor. Don't know if thats connected or not.
    Not sure if I tried starting in Neutral or not. Saw that post after I got home.
    I'm starting to think its either fuel pump or fuel pump relay...
  7. Oct 27, 2014 at 6:36 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    So, now it gets weird.
    Went back over to the truck before I was going to have it towed to the garage.
    Jumped in it and it fired right up like it was nobody's business.
    Drove it home...now I'm afraid to turn it off.
    It drove completely normal. What now???
  8. Oct 27, 2014 at 6:40 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Hard to check for an intermittant problem... I would start by checking for loose/corroded electrical connectors, and sensors.
  9. Oct 27, 2014 at 6:47 AM
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    My sister's Escape had an issue similar to this, turns out a bug got sucked through the air box somehow and got into either the MAF sensor or IAT sensor. :confused:
    Hope this helps...
  10. Oct 27, 2014 at 7:25 AM
    TylerMorton
    TylerMorton Member
    Tyler
    Mooresville nc
    Could be a ground. Iv ran into that before. And as far as the fuel pump do you hear it running when you turn the key on?
  11. Oct 27, 2014 at 10:04 AM
    TylerMorton
    TylerMorton Member
    Tyler
    Mooresville nc
    Dealers are dumb. Hahaha
  12. Oct 27, 2014 at 12:27 PM
    colbyrainey
    Colby
    KC
    '11 Dbl TRD Sport
    The only other thing I can think of is a weak fuel pump. If you have someone lightly tap on the fuel tank while you crank it over and it decides to start, you need to replace your fuel pump.
  13. Oct 27, 2014 at 12:31 PM
    BamaToy1997
    Bill
    Navarre, FL
    Winner winner, chicken dinner. Your P0102 is preventing your engine from starting. It is probably an intermittent code, but that would cause your problem of cranking but not starting.
  14. Oct 27, 2014 at 12:35 PM
    TylerMorton
    TylerMorton Member
    Tyler
    Mooresville nc
    Idk about that bamatoy. Iv only run across that happening a few times. Not saying it can't happen. But seems like generally all it does it cause an engine light.
  15. Oct 27, 2014 at 1:25 PM
    BamaToy1997
    Bill
    Navarre, FL
    The Toyota vehicle line use MAF to determine engine operation. They no longer use speed density, which is calculated. Therefore when a MAF sensor has a current failure, showing either excessively low voltage, (P0102) or excessively high voltage, (P0103) then the computer has no way of knowing how much air is flowing into the engine. Since the ECU uses this information to calculate fuel timing, and appropriate fuel:air ratio, then the engine will not start and run. Try it. Disconnect your MAF sensor and start your truck. It will either not start, or it will start one time, then will not start after that.
  16. Oct 27, 2014 at 5:06 PM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    So what do I do about that?? Sounds like it's not the MAF sensor itself? Or would replacing that help?
    Problem I have now is I don't have much confidence in the truck...so I'm leery about driving it for fear it not starting up and leaving me stranded again (or worse yet, my wife or kids).
    Is there something I could do, such as if it won't start again...clear the code and see if it fires up?
  17. Oct 27, 2014 at 7:18 PM
    BamaToy1997
    Bill
    Navarre, FL
    You have to get the problem diagnosed, unless you want to throw money at it in the hopes that you get it right. It's not easy, but it can be done. Basically you have to check the continuity of all the wires to the MAF from the ECU. If you verify that all the wiring is good, then the problem would be in the sensor. Now that being said, the MAF sensor is one that is commonly fixed by a good cleaning. You can get a can of MAF cleaner at the parts store, and follow the directions on the can. Simple attempt at a fix with the least cost to get started.
  18. Oct 28, 2014 at 12:44 PM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    Soooo my truck is fixed...
    First off. Thanks everyone for their post's. This is why I love this forum.
    It was the key.
    After we drove it home, I turned it off, then tried to start it again...fired right up
    Several hours later I get in it to drive somewhere, turn the key, cranks...no start.
    Frustrated I just sat there when I noticed the flashing anti-theft light that goes away when the key is in the ignition, was still flashing. I went back in the house...grabbed the other key..put it in the ignition...flashing light goes out...truck fired right up.
    The bad key was a clone I had made at Walmart about two years ago. Always worked in the past. I guess it just died.
  19. Oct 28, 2014 at 1:40 PM
    BamaToy1997
    Bill
    Navarre, FL
    Well interesting there. I had thought that the 2nd gen anti-theft system wouldn't even let the engine crank if it was tripped.
  20. Aug 17, 2015 at 9:08 AM
    mattk_r
    mattk_r Active Member
    Snohomish, WA
    2014 Grey Taco 2.7l 4x4 SR5
    LCE Header, Magnaflow catback exhaust, Hell Bent Steel/AAL 2.5" lift, 265-70-17" BFG AT KO2's, American Outlaw 17x9s, Westin grill guard, 48W Ultra Tow LED grill lights, heated mirrors, and a few other mods from TW.
    Yesterday my truck wouldn't start (first time ever). Cranked it 3 or 4 times before it threw a P0102. Couple more attempts to start and no luck. For kicks I tried shifting to neutral and it started. Not sure to check the MAF or the key!
