So really...will the new OME setups settle to less than 3" or not?
Discussion in 'Suspension' started by aggieshooter, Dec 8, 2009.
  1. Dec 8, 2009 at 6:49 PM
    aggieshooter
    aggieshooter [OP] Registered Chet-head
    College Station, TX
    '09 Double Cab V6 SR5 4x4
    OME 3" lift, ToyTec rear AAL, 16" Moto Metal 951's, 285/75R/16 BFGoodrich KM2's, Aries Grill Guard, Hella 500's, Flowmaster 40
    OK, so I've done lots of reading and searching and I realize the sheer number of threads on OME vs. ToyTec, etc...and it seems like the general idea is that OME's newer springs don't settle the way the old ones did. What I'd like is to have real confirmation of this. I sure like the price better than the ToyTec and I understand they're both of similar quality, so it seems simple to go with the OME, but I refuse to shell out 700 bones for a lift that over time will be less than the full 3" I want. Can anybody who has had the OME for a while chime in? Thanks, y'all.
  2. Dec 8, 2009 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    All springs will settle in time. I have the OME 885's and have had them for about 2 years, and they are still at 3" lift.
  3. Dec 8, 2009 at 6:56 PM
    aggieshooter
    College Station, TX
    Yeah, I realized that kinda sounded silly the way I worded it...sure, they all settle. I was just wanting to make sure they didn't have an inherent "settling problem" so to speak. Thanks for the reply bud :cool:
  4. Dec 8, 2009 at 7:07 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Chris, if the new OME springs get a full 3'' does that make the top plate spaces obsolete?
  5. Dec 8, 2009 at 7:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Im not running the top plate spacer, and have 3" over my stock height. I dont think they are a bad thing to have on hand Just in case they sag.
  6. Dec 8, 2009 at 7:16 PM
    aggieshooter
    College Station, TX
    I thought the top plate spacers were what gave the full 3"..?
    So what exactly will I need to do to get a full 3" of lift with the back and front level? I don't want the back higher than the front. Does the AAL only lift it enough in the back to level it with the 3" in front or does it sit just like it does stock, only 3 inches higher?
  7. Dec 8, 2009 at 8:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Usually, you can get a 1.5" or 2" AAL. That used with a 3" lift will get the truck close to level.
  8. Dec 8, 2009 at 8:11 PM
    hunter1111
    hunter1111 Well-Known Member
    Granger Tx
    2010 trd 4wd
    A am getting very close to buying a 3in lift for my truck as well. I have a 2010 trd doublecab..... Ive been finding pics of other tacos on here that i like, the one thing im a little confused with is what the tsb springpack is? Im sure this is a stupid question but im new.....take it easy on me.
  9. Dec 8, 2009 at 8:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The "TSB Leafpack" is a replacement 4 leaf spring pack, that replaces the 3 leaf OEM spring pack. Many people have had their truck bottom out when hauling a small load with the 3 leaf pack.
  10. Dec 9, 2009 at 5:37 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Chris, when I get the kit installed should I have them install the top plate placer?
  11. Dec 9, 2009 at 5:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Install the longer studs, but leave the top spacer off. That way, IF they sag, you can just add them your self. And if they dont, your good.
  12. Dec 10, 2009 at 5:48 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    After about 7 months in helmand, the coils on my buddies gun truck were completley flat. No space between them at all. But those trucks were run ragged
