So there's no way to check manual transmission oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, Mar 13, 2015.
  1. Mar 13, 2015 at 1:08 PM
    donlogan
    donlogan [OP] Well-Known Member
    I've been searching for where manual tranny oil dipstick is for a 95 Tacoma without any luck. It looks like you just have to open up the fill plug to make sure oil is up to that point...which I assume means if you get it on your hands that's good, if not, fill it up.
  2. Mar 13, 2015 at 1:12 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    if you're concerned about it just replace it.
    Make sure you can open the fill plug otherwise you'll need to know the exact amount you drain and use the shifter area unbolted to refill.
  3. Mar 13, 2015 at 1:19 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    You have ten of them attached to you (11 if its small enough and you can position yourself to get it in there:D). Pop the plug off and if you feel fluid you have enough. You shouldn't be losing any unless its leaking somewhere.
  4. Mar 13, 2015 at 1:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    What he said. Actually have never seen it any other way.
    Just be sure when you pull the fill plug to check that the vehicle is level F/R and S/S.
  5. Mar 13, 2015 at 3:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm not 'forever' old. Yet.
    While I've been around a lot of pre '50's rides/rods/racers, can't recall ever actually working on anything pre '56. And no, it wasn't new when I was working on it :p
    However, '50's antiquities, or 60-ish YO stuff, is probably pretty much 'forever' to lots of folk around here.
  6. Mar 14, 2015 at 3:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Sight glass = receiver/dryer
    No sight glass = accumulator (although it's really the same thing)
    I actually miss the sight glass. It was helpful. Not as good as gauges of course, but at least gave you a hint.
    How's that?
