so this happened as I pulled into the driveway
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, Jun 3, 2017.
  1. Jun 4, 2017 at 12:39 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I bet the ball is dry and started to lock up in the socket from rust. Causing the metal to fatigue.
  2. Jun 4, 2017 at 9:18 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah just look at it, that ball joint has probably been on the truck since 95!
  3. Jun 4, 2017 at 9:29 AM
    donlogan
    donlogan [OP] Well-Known Member
    So if the ball joints haven't been replaced as part of the recall, I am entitled to the repairs being done on the Toyota?
    I am the third owner so I'm not sure where the Tacoma was purchased from. I assume I can take it to the local Toyota dealer and see what they will do for me. Hopefully it can save me costs out of pocket to get this fixed.
  4. Jun 4, 2017 at 9:31 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  5. Jun 4, 2017 at 11:04 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Probably WHY he held it together :cool:
  6. Jun 4, 2017 at 11:08 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Been there done that, as others have mentioned, you may want to consider replacing critical suspension parts.
    Judging by the failure, ill guess there would of been some play in that particular ball joint, and eventually it was enough of a bump to shear it off to failure. Alot of the issues had by others were bolt failures on the 6 lug trucks, but yours is 5 lug. Slightly different components but still the same safety concerns.
  7. Jun 4, 2017 at 11:12 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Id rather pay $500 to have it done once than pay $500 a month for a turd gen with more problems
    E30325, KevinTaco98, conroe and 6 others like this.
  8. Jun 4, 2017 at 11:20 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    You had a wear part wear out and fail. It will continue to happen on other things. Fix it & continue driving it. $500 for parts/labor is cheaper than a $500/month payment for 6 years.
  9. Jun 4, 2017 at 2:37 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I must be reading too many LBJ threads. I decided to check my service records at the Toyota Owners site, and what do you know, I see my 2003 truck has a service record for LBJ R&R from 2005 under the LBJ recall. At the time, the truck had 40K miles, now 170K. So there are few less miles on this set than I thought (say 130K not 170K). I'm a little less paranoid now, but they probably should still be replaced. At 12 years, 130K, it wouldn't be a ridiculous thing to do.
    It is quite likely that the recall does not go back to the 1995.5 model year, but I don't know that for a fact. Check the owner's/recall site or with your dealer.
  10. Jun 4, 2017 at 3:07 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Not to hijack, but I'm gonna hijack. How many miles should people go on UPPER ball joints? Mine I don't think have ever been done.
  11. Jun 4, 2017 at 3:59 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Lots has to do with driving conditions and road/weather. If you are in a state that uses lots of deicer and or salts stuff will wear out quicker, if you live in AZ stuff will last longer. Lots of variables to answer that.
  12. Jun 4, 2017 at 5:27 PM
    Blackat
    Blackat Well-Known Member
    Bryan
    Colorado
    99 Tacoma SR5
    TRD Stat, TRD Supercharger, TRD Headers, TRD Cat-back, slight lift.
    Changed mine a while back..........at 300,000 miles!
  13. Jun 4, 2017 at 7:17 PM
    Glamisman
    Glamisman Well-Known Member
    just did both lowers on my 2002... I dont think it took more than a hour... about $240 for both lbj from my local dealer.
    cruxofthebisquit likes this.
  14. Jun 4, 2017 at 8:12 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Upper or lower?
  15. Jun 4, 2017 at 8:15 PM
    #35
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    This is why I will be replacing my LBJs in a week or two.
  16. Jun 5, 2017 at 6:38 AM
    #36
    Blackat
    Bryan
    Colorado
    99 Tacoma SR5
    Lowers.
    Uppers still tight.
  17. Jun 5, 2017 at 6:43 AM
    #37
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    My buddy had a new oem ball joint fail the same way. We guessed it was over torqued.
  18. Jun 5, 2017 at 6:47 AM
    #38
    JayRolla
    Colorado Springs
    If you don't wheel much and they are tight I would not replace the uppers. Lowers I would do every 80k miles.
  19. Jun 5, 2017 at 10:17 AM
    #39
    Slickster
    Slickster greentaco
    2002 pre
    i had mine replaced by the dealer under the safety recall back in April. should have them check your vin #.
    Dalandser likes this.
  20. Jun 5, 2017 at 11:31 AM
    #40
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I don't think rust played as much a part of this as just plain ol' metal to metal contact right at the contact point causing extreme fatigue. that joint looks like grease dried out a lonnng time ago. The factory joints are designed to have life long grease AS LONG AS THE RUBBER SEAL IS INTACT.
    I changed mine @ 180k just as I noticed the seal disintegrating and the metal (joint) was still great. No play at all.
    Thought I was doing the right thing using those Japanese 555s (Sankos?) from (Wheelers?) that were a few bucks cheaper.....nah. Rubber is already (not many miles just a few years time parked on hot driveway) failing again.
    just buy factorys......and man, they're easy to change, grab a bud who knows what he's looking at and do it at home. Even w/o an impact, the bolts aren't bad and you can just just bang out the old ones and slip in the new.
    Look at your spindle socket (where the joint contacts) closely for pitting....a shop isn't going to do that for you anyway. In/out is their way of working.
    You can do better even if it's your first time.
    cruiserguy likes this.
