So TSB's After Warranty
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sloppyjoe, Sep 22, 2010.
  1. Sep 22, 2010 at 3:04 PM
    sloppyjoe
    sloppyjoe [OP] They are more like guide lines.
    All Over
    Silver and simple
    Non
    I was wondering if a TSB carries over after the factory Warranty runs out? I have soft and weak rear springs and I am sure the TSB would rectify the issue, thing is I am not sure they care much about it after it is not warranted? Does anyone know if I can get TSB's done afterthe warranty is out if so what is the best method to get the work done? I would like to have the TSB leafs and if not and the answer to my question is flat NO, then what or who have any of the TW'ers used to get the desired ride and support out of the rear. I have heard good things about allcan leafs springs (anyone using them?) I do not want a lift kit but the extra lift would not hurt as I do plan on adding OME coils in the front. Any help would be awesome, THanks!! JOE>
  2. Sep 22, 2010 at 3:06 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    TSB coverage seems to end at 36,000/3 years. I suppose if you went to a dealer and were really nice you could try, worst they can do is say no. How far out of warrenty are you?
  3. Sep 22, 2010 at 3:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    just get an AAL and call it a day
  4. Sep 22, 2010 at 3:10 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    man im in the same boat, just hit 38k miles but would like the rear suspension tsb.
  5. Sep 22, 2010 at 3:36 PM
    JKD
    JKD Well-Known Member
    TSBs still "apply" after the warranty, you are just probably going to be paying out of pocket unless you call Toyota corporate and they take pity on you.
    A TSB just spells out steps to try to remedy a customer complaint or common problem.
  6. Sep 22, 2010 at 3:54 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    TSB's only apply if the affected part is still under warranty. A TSB is not a recall - just a bulletin to help techs diagnose common problems.
    If a TSB is done after the warranty expires, it's usually due to "good faith" and is very uncommon.
  7. Sep 22, 2010 at 3:57 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Correct.
    Just get a $80 AAL. Toyota will want $1600 to do the TSB out of pocket.
