SO what causes that wheel shimmy/bumpsteer after installing bigger tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ferntr33, Dec 29, 2018.
  1. Dec 29, 2018 at 7:55 PM
    ferntr33
    ferntr33 [OP] Well-Known Member
    I was just curious. I have always lifted and put larger tires on vehicles at the same time. Or lifted it first, tires second. Taco is different. I got 285/75 KM2's and it feels like Im driving a lifted truck. What will fix this? Are the stock billies not beefy enough for the heavier tires? Is the alignment off? Changing tires shouldn't mess with alignment . . . I have less than 30k and don't hit curbs.
    I have been told its because the truck needs different alignment specs and I need UCA's to get it within spec. That sounds strange because I am on stock suspension.
  2. Dec 29, 2018 at 8:09 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Bigger, heavier, knobier tires makes the steering shimmy. Probably not balanced 100% right
    BillsSR5 likes this.
  3. Dec 30, 2018 at 9:50 AM
    ferntr33
    My question is what makes it shimmy? Raptor comes with 35's and Im sure it doesn't shimmy. Does the heavier weight overpower the dampening effect of the shocks? Or is it purely the E rating? My work truck has 11R22.5's load range G and weigh over 100 lbs. They don't even balance them when they change the tires. Those don't shimmy on the same streets.
    As I modify this truck I want to make it drive better not worse wherever I can. Girlfriend says it drives rough so I told her I could get some new suspension and it should fix that. I don't want to spend $4k and have it feel the same.
  4. Dec 30, 2018 at 10:01 AM
    SpeySquatch
    2016 TRD OR DCSB
    The wider the tire the worse it gets. 265’s and 255’s don’t do this. 33” comes in more than one width
  5. Dec 30, 2018 at 10:03 AM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    your not alone i been wondering same thing on tacomas have 2 of them both started it when i moved to larger tires been rebalanced checked all suspension parts still does it the one is a 18 tacoma put bigger tires on it next day after i bought it bingo wheel shimmy only had 88 miles on it
  6. Dec 30, 2018 at 10:04 AM
    casey2012
    mark
    yota
    none
    have 265/70/17 and they shimmy
  7. Dec 30, 2018 at 10:05 AM
    SpeySquatch
    2016 TRD OR DCSB
    Sounds like alignment or wheels. I’ve never had shimmy with any of my 265’s or 255’s. Could also be aftermarket wheels if they aren’t Toyota wheels
    Tacomas are picky and not all wheels are created equal.
  8. Dec 30, 2018 at 10:12 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Did you change to rims with more offset or add wheel spacers?
    lynyrd3 and SpeySquatch like this.
  9. Dec 30, 2018 at 10:13 AM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Has to do with leverage. You mention the raptors having 35” tires. The suspension was designed to work with that tire. On the tacos the suspension was designed to work with a much smaller tire. Look at the size difference of the shocks, UCAs, bolts, mounting points, etc. it’s possible to beef up the suspension and make it stable again with over sized tires.
    BillsSR5 and Hank Heel like this.
  10. Dec 30, 2018 at 10:15 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Our trucks are rated for C tires, anything heavier/bigger will cause issues as the truck wasn’t manufactured to handle such. It’s also a midsize truck so any changes like that will affect it one way or another. The raptor comes with 35’s because it was designed to have them from factory, and it also has long travel suspension from factory.
    Any modification you do to your truck you might have to modify something else in order to fix it you’ll find.
  11. Dec 30, 2018 at 10:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Well, you 'kinda' are. You are now lifted the value of the radius increase over the tires you replaced.
    I agree with you. Not sure your source for this info is to be trusted for additional advice.
    Side note. Tires/wheels having nothing to do with the alignment process, they are just the 'beneficiary' of it. The hubs are what's actually being aligned.
  12. Dec 30, 2018 at 10:20 AM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    can’t really compare a super beefy factory designed truck with 35’s to our flimsy factory shit. fuck even the alignment tabs are about fucked after the first alignment on many trucks.
    Rustytaco71 likes this.
  13. Dec 30, 2018 at 9:16 PM
    ferntr33
    ray 10's
  14. Dec 30, 2018 at 9:18 PM
    ferntr33
    that's kind of my point. what gets beefed up to keep wheel shimmy down?
  15. Dec 30, 2018 at 9:19 PM
    ferntr33
    that's what I know to be true as well. but you always hear get an alignment with new tires. Im assuming its just to make more money off you. or if your wheels wore prematurely from misalignment in the first place.
  16. Dec 30, 2018 at 9:23 PM
    ferntr33
    that's what Im looking for. Im wondering if new shocks will eliminate shimmy. my buddy has 275/70 k02s on adjustable billies and he wobbles too. And I am told those are beefier than stock. as far as UCA's Im assuming aftermarket ones are there to allow proper alignment when ride height is lifted.
  17. Dec 30, 2018 at 9:23 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    The heavier the the tire/wheel the more damping it needs to cope
    Tacoma ≠ Raptor
  18. Dec 30, 2018 at 9:24 PM
    blackohio
    Cliche Guevara
    white mudflap
    everything. it weights about 2000lbs more. the tacoma was never intended to have 11-12.50” wide 75lbs tires w/ offsets at or below zero.
  19. Dec 30, 2018 at 9:24 PM
    Trail Limo
    Trail Limo Well-Known Member
    Potholes and the stress of driving can knock the alignment out. The new tire alignment is a precautionary method. It really would suck to spend $$$ on tires only to have them wear out in 5k miles due to a bad alignment caused by the previous 50k miles of potholes you hit.
  20. Dec 30, 2018 at 9:31 PM
    ferntr33
    I guess Ill see if its in spec. Im assuming it is though.
