So what gear should I shift to at 6mph?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WPDAWG11, Feb 11, 2015.
  1. Feb 13, 2015 at 1:59 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
  2. Feb 13, 2015 at 2:34 PM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    First murfreesboro is in Tennessee. If there is a murfreesboro in Canada I feel terrible for its commie residents.
    Secondly I was slightly drunk when I posted so let me clarify;
    So I am coasting in neutral on the road b/c I am in traffic at around 8mph. If I decide to go to first it takes a decent bit of force to push it in and my truck will instantly slow down in a jerk motion. If I go to second and do not hold the clutch it will shake a bit till it gets up to speed. If I go to second and hold on the clutch till I get up to speed all is well but this doesnt seem healthy for the truck. Im guessing this may be just my vehicle but all the gear ratios are stock as I have checked.
  3. Feb 13, 2015 at 2:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So you're asking how to drive a manual tranny
  4. Feb 13, 2015 at 2:43 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Ive driven many manuals hot rod. None were like this truck iirc
    I do this to no avail. Rev matching is the intuitive first conclusion but it doesnt work on my truck. A good friend of mines 2011 v6 6spd is like butter when I drive it. Im guessing the lack of power in 2.7 is what causes the gear box to be so finicky. Thnx
    I love all these haters in here. If I were to flip in troll mode that little canadian fellow would have me banned quick again tbh
  5. Feb 13, 2015 at 3:05 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Cause: poor rpm matching. RPMs too low for selected gear and current vehicle speed. Even with a synchronized transmission, you want your upshifts to have the engine RPM matched to roughly where they'll be in the new gear - erring on the high RPM side rather than the low RPM side.
    Cause: RPMs too low for amount of acceleration desired. Truck is lugging. Either accelerate more slowly, or select the lower gear - in this case first.
  6. Feb 13, 2015 at 3:32 PM
    sacha7905
    sacha7905 Active Member
    Hey OP does your truck have stock tires on it? If you have a 2.7 5 speed and bigger tires, you might need a re-gear.
  7. Feb 13, 2015 at 7:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    slightly drunk = shithoused [​IMG]
    Stay in second gear and take it easy on the gas.
  8. Feb 13, 2015 at 7:58 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  9. Feb 14, 2015 at 7:20 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    This is a common complaint with the 5 speeds, and a source of frustration for me too. Wont go into 1st until almost dead stopped, even with rev matching and/or double clutching. Anything below 10 mph is too slow for 2nd gear and the truck will shudder like crazy even with very light throttle application. So if you're not in gear between 1-10 mph, your only option is to come to a stop and shift into 1st, then get on it before the person behind you starts honking. I've put 60,000 miles over 4 years on this truck, I'd still buy it again though :)
  10. Feb 14, 2015 at 7:40 AM
    Bucc5207
    Bucc5207 Well-Known Member
    Yrisarri, NM
    2014 V6 SR5 4x4
    Again? :drevil:
    :popcorn:
  11. Feb 14, 2015 at 7:53 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Yep I have larger alt tires. Just purposefully attempted perfect rev matching and still does it. I rev a little higher then necessary and still nothing.
    I was talking about Oz. I got him super butt hurt on here and he got me banned so that is why I tread lightly. I just have superior wit and hale from a superior land none of which I can help.
  12. Feb 14, 2015 at 7:57 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Yep, still love the truck. Thnx for the post and letting me know Im not the only one.
  13. Feb 14, 2015 at 9:56 AM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Fixed that for you. Trod along with your superior wit like the southern gentleman you are.
  14. Feb 14, 2015 at 10:22 AM
    OZ-T
    Peter North
    British Columbia
    :rolleyes:
    Not butthurt , you got yourself banned , no , and no
  15. Feb 14, 2015 at 10:22 AM
    #35
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    First off you should NEVER be coasting in neutral. In many states that is illegal.
    If 8MPH is lugging the truck in 2nd, and shifting into 1st while moving is a problem, stop the truck and shift into 1st. That little bit of time to stop and downshift will not hold up traffic that much. :)
  16. Feb 14, 2015 at 11:30 AM
    #36
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    As a 6speed owner, the ratio's are horrible.
    Yes first is extremely low. I only use it to start from a stop. If I am rolling I keep the truck in 2nd gear.
    For people saying don't coast in neutral, they are obviously not driving a standard. I do this often, and in no way is it unsafe.
    As for the USELESS 6th gear (more like a gear 5.2). I can easily drive at 35mph in 6th on a flat road without lugging the truck. This is probably the best for MPG, but normally I use 5th around town.
    I shift into 6th any time I am over 45mph and driving on a grade that doesn't require a lower gear.
    That being said, if you know how to drive standard properly, the gear selects itself.
    If you are bogging down, you are in to high of a gear. If you hear the engine excessively revving and you are gaining speed you are in to low of a gear. Practice makes perfect for selecting the gear you are in.
  17. Feb 14, 2015 at 11:38 AM
    #37
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    You really do give the south a bad name. Please stop, or apply for the one way ticket to Mars, or both.
  18. Feb 14, 2015 at 12:57 PM
    #38
    tacoma4
    tacoma4 Well-Known Member
    This is a perfect description of the 5 speed. I usually go for the 2nd gear bog with a little clutch slip over forcing it into 1st. Replacing the clutch is easy, synchronizers not so much.
  19. Feb 14, 2015 at 1:35 PM
    #39
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Lol@ not coasting in a manual or it being unsafe?? I am confused as to why it is unsafe tbh. How would a cop site you on it regardless?
    right, scooter
  20. Feb 14, 2015 at 1:40 PM
    #40
    OZ-T
    Peter North
    British Columbia
    Glad we agree
