so whats the word 17 or 18's for 6" lift?
Discussion in 'Suspension' started by allrsdup, May 22, 2010.
  1. May 22, 2010 at 7:36 AM
    allrsdup
    allrsdup [OP] Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    it seems a little unclear if u can use 17's with a 6" procomp lift anyone know for sure ?
  2. May 23, 2010 at 8:04 AM
    allrsdup
    Sahuarita AZ.
    ? wow nobody?
  3. May 23, 2010 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Everyone I have seen for the second gens has had 18's...
  4. May 23, 2010 at 8:09 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    18 and up are what most people roll on their 6" lift. It gives a bigger tires for them and I think the 18/20 are perfect sizes. Not too big; not too small.
  5. May 23, 2010 at 8:09 AM
    Lentsnh
    Gah! beat me
  6. May 23, 2010 at 8:10 AM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    I say 17's because the more side wall the better, and the more rubber the more it looks like a truck and not a pretty street queen.
  7. May 23, 2010 at 8:10 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    22's...go BIG or go home...lol
  8. May 23, 2010 at 8:10 AM
    comicnut25
    comicnut25 Well-Known Member
    Rob
    Stanwood Wa
    09 TRD 4X4
    I read on the procomp site they reccommend at least an 18 inch wheel for the 6 inch lift
  9. May 23, 2010 at 8:12 AM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    I would go with what they reccomend then 18's on 35's look killer anyways
  10. May 23, 2010 at 8:12 AM
    allrsdup
    Sahuarita AZ.
    i have heard some people say 17's are little tight on procomp kits so i just wanna be safe then sorry considering a lot of people here have that lift.
  11. May 23, 2010 at 8:13 AM
    Lentsnh
  12. May 23, 2010 at 8:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  13. May 23, 2010 at 9:39 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    17's will fit but you have to have at the most 4.65" back spacing...
    18's is the minimum requirement for the FJ Cruiser lift...
    but I have also heard that procomp redesigned the drop bracket for the strut bar and also redesigned the steering knuckled...on procomp's website it still says 4.65" max backspacing but I have heard that some guys are running 17x9" wheels with 5" backspacing without the rim touching the steering knuckle...is this true?
  14. May 23, 2010 at 1:31 PM
    diggerbuzz
    diggerbuzz Active Member
    buzz
    ohio
    10 Tacoma TRD OFFROAD SR5
    TRD exhaust tip , toyota bed mat , uws low pro tool box , wet oke seat covers front & rear
    It all depends on the truck . Procomp says if u have a 09 or 10 with vsc u need at least 18inch wheels. Although Black beauty is running 17s on her 2010. She had told me there was very little clearance so she would also go 18 if she had to do it again. Fabtech says 17s will work on 09 or 10 .
  15. May 24, 2010 at 9:32 AM
    allrsdup
    Sahuarita AZ.
    sounds like an 18 would be best to play it safe.
  16. May 25, 2010 at 7:01 PM
    customz
    customz Well-Known Member
    09 prerunner access 2wd 4cyl 5sp
    +1 and cheaper tires
