So who runs an air tank?
Discussion in 'Product Reviews' started by Pdugan6, Dec 5, 2013.
  1. Dec 5, 2013 at 6:38 AM
    Pdugan6
    Pdugan6 [OP] Well-Known Member
    Patrick
    Santa Clara California
    2011 Tacoma 4x4
    31570 R17 procomp mt2 on procomp alloy wheels trimmed fenders 2" out of rear 3" out of front Rear suspension:63"chevy springs mounted with ruff stuff chevy swap kit, 12" bilsteins ,All pro U-bolt flipkit extended brake lines and abs sensor tab Front suspension: pro comp 3" coil over lift Snugtop Snug Pro camper shell ATO high clearance bumper
    I have been looking into an getting a setup for my truck and am curious to see what other people are using? So what do you have and what do you like about it? This is what I'm going to go with...
  2. Dec 8, 2013 at 10:13 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    The 10-lb Powertank is what I have. I did not get the mounting bracket but
    I did get the Speed-bag. I don't wheel as much as I used to, so one charge lasts for a year. Works great.
  3. Dec 8, 2013 at 3:41 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    That would be great to have. Airs tires up so fast and keeps moisture out of them. And air tools can be run of course. That's a big plus. I'm considering it.
  4. Dec 8, 2013 at 9:26 PM
    Pdugan6
    Patrick
    2011 Tacoma 4x4
    Good to hear. This is definitely a pricey setup but man isn't it worth it? ;)
  5. Dec 8, 2013 at 9:27 PM
    Pdugan6
    Patrick
    2011 Tacoma 4x4
    Ask Santa.
  6. Dec 8, 2013 at 9:35 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I got an aluminum 20lb co2 tank off craiglist for like $60. Still working on getting a regulator, hose, and finding a way to mount it so I don't have any experience with it yet lol. I've heard many good things about co2 tank setups from people that run them though.
  7. Dec 9, 2013 at 2:38 AM
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    diy beerstores have the CO2 tanks and can order the lower pressure regulator - 5,10 &20 lb - just an fyi
  8. Dec 9, 2013 at 5:59 AM
    Pdugan6
    Patrick
    2011 Tacoma 4x4
    Yeah I had been toying around with the idea but I hear power tank is the best there is. Their regulators are guaranteed to never freeze up.
  9. Dec 9, 2013 at 6:05 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    You can see my tank and mounting system in my build.
    I bought a 10lb tank locally and used the wheelers adjustable high flow regulator. Stay away from the low pressure regulators made for keg setups. They will freeze up if you try to air tires or run air tools.
  10. Dec 9, 2013 at 8:19 AM
    tan4x4
    Rick
    Folsom, CA
    Be wary of using old CO2 tanks and adding regulators, though. Shops that fill them may have to 'certify' it before they will fill it. I had to have that done (for an additional fee) even with my brand new PowerTank.
    Not sure what they do, to check it.
  11. Dec 9, 2013 at 8:34 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I have a 40lb. Nitrogen in the Jeep. Use it for air shocks, pneumatic tools and airing up. Wheel with guys with power tanks and they are fine, but I'll keep the nitrogen.
  12. Dec 9, 2013 at 10:15 AM
    kmok
    Kyle
    Columbus, Ohio
    I think they have to be hydro tested or something like that. The guy told me about it when I bought it and he said the one he was selling me should be good for a few more years before it needs tested again. There should be a sticker on my tank but I can't remember now. Been a few months since I bought it.
  13. Dec 9, 2013 at 10:17 AM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    I know a few guys who run PowerTank systems. I went with on board air myself, tankless setup. I can air up from 12psi to 45psi in about 2.5 mins. Can do all 4's in less than 15mins. If I remember correctly the PowerTank setup was faster however, I dont have to refill my setup :) I would consider looking at on board air also.
  14. Dec 9, 2013 at 12:59 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I run a 20 lb CO2 tank. It's a standard "beverage" tank with an adjustable regulator. As has been mentioned whether it's a name brand tank or not you will have to get the tank hydrotested if it hasn't been done already. The testing is good for 5 years IIRC and then needs to be redone.
    CO2 is MUCH faster than just about any onboard air system using a compressor. You have to refill a CO2 tank but they last quite a while. I can get a year out of a single fill on my CO2 tank. I can fill my 33x12.50 from 10-30psi is less than a minute. I actually have two tanks and make sure that I always have a full one so in case one tank runs empty, I have a backup if I have a trip happening and don't have time to fill the other tank.
    I prefer CO2 over a compressor/onboard system any day. Besides being faster its portable. If a buddy blows a bead 200 yards down the trail and you can't get your truck to him, you can carry a CO2 tank down there to reset the bead. Can't do that if you can't get the truck to him with a onboard system.
  15. Dec 9, 2013 at 1:00 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Love my c02 tank. I need to get a new regulator and hose though as my welding regulator can't keep up with the temps of c02 very well....
  16. Dec 9, 2013 at 1:05 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
  17. Dec 9, 2013 at 8:12 PM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB
    Have 2 10 pound power tanks in the K5 and a 5# in each of the Tacos and a 20 in the trailer.
    Been using CO2 for about 25 years now and they are great setups, have run air tools, fill all 4 tires at one time with a regulator and splitter system. Easy for seating a bead or just about anything.
  18. Dec 9, 2013 at 9:08 PM
    Pdugan6
    Patrick
    2011 Tacoma 4x4
    Great point^^
  19. Dec 9, 2013 at 9:18 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    This. And I also like the fact that I've kept a component of the truck off of the electrical system.
  20. Dec 9, 2013 at 9:30 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    10 lb powertank on mine. originally wanted a 20 lb, but decided that for redundancy purposes, it would be better to have two 10s. haven't bought the second one yet, but fully intend to.
    great craftsmanship and quality parts. airing up 35s in under a minute a piece is a thing of beauty.
