So you don't want your truck stolen...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DG92071, Mar 1, 2020.
  1. Mar 1, 2020 at 8:20 AM
    DG92071
    DG92071 [OP] Well-Known Member
    Thieves nowadays don't have a clue on how to hotwire a vehicle. Some "professional thieves" know how to bypass car alarm kill switches and some will actually steal your car alarm. A great way around this is to install a custom kill switch - two kill switches are even better.
    I had a customer that had a motorhome and his motorhome kept getting stolen. The owner of the motorhome knew who was having his motorhome stolen - his drug addicted ex girlfriend and he knew whoever was doing it had a set of his keys to his motorhome. I stopped his motorhome from getting stolen by installing two kill switches hooked up to existing parts of his motorhome. In his motorhome the ash tray had to be closed and the seatbelt plugged in for his motorhome to be able to be started.
    I probably installed over a 100 custom kill switches. You don't want to use an aftermarket switch that can be seen, use existing switches or factory switches. Some examples are: using the existing switch for the seatbelt, installing a hidden switch on the ash tray's track, installing a switch on the seat track, using any factory switch that your truck doesn't have that option for (seat heater, fog light, power rear window, etc etc etc). A cigarette lighter can be used as a switch as well (makes the cigarette lighter inoperative). The options are near endless. The more it looks factory the less likely it will be discovered.
    You want to think about what a thief would do if he's trying to steal your truck. The likelihood of a thief closing the ash tray is extremely unlikely but it's very likely the thief will open the ash tray so you definitely don't want your truck's kill switch having the ash tray open to start the truck. It's very unlikely the thief will notice your truck has a fog light switch but the truck doesn't have fog lights (etc etc etc). It is very unlikely that a thief will move the seat so that the truck will start. Glove box doors are a no go because they will open the glove box and you don't want to leave your glove box open whenever you leave your truck. Thieves don't plug in seatbelts to start a vehicle they're trying to steal.
    Several different aspects of the truck can be "killed". The fuel pump, the ignition circuit, the starter circuit, the clutch switch, the neutral safety switch, are some examples.
    On one vehicle I not only installed a kill switch but I also made it where the horn would continuously honk while trying to start the vehicle if the switch wasn't activated first (it was connected to the seatbelt switch). That is a great idea to get the thief out of your truck and run like hell.
    If a professional thief wants your truck he can take it no matter what you do, it's called a flat bed tow truck. I saw a 911 Porsche Carrera Turbo stolen in San Francisco using a flat bed tow truck. It was gone in less than 15 seconds. The 911's factory horn was honking, air horns were honking, parking lights were flashing, headlights were wig-wagging, all 4 wheels were locked (line lock?) and it was bouncing like crazy while being dragged, and it was still stolen. I've always wondered if it was a repo company that took that 911 Porsche.
    I can assist with designing a kill switch for you but I gotta mention there are quite a few people on TW that know far more about 2nd and 3rd gen Tacomas electrical systems than I do. I retired from the car stereo/car alarm/insurance replacement industry in 2009.
    Dan 77, DGXR, 1Crusader and 18 others like this.
  2. Mar 1, 2020 at 8:28 AM
    su.b.rat
    su.b.rat broken truck
    had a builder friend who installed a pressure switch to the ignition in the passenger side seat bottom. you could only start it ('70 Chevelle SS) while sitting in the passenger seat! or put 60+lbs there. lol.
    i built a '70 LeMans at the same time in the same shop and had a rocker switch hidden up inside the dash connected to the electric fuel pump. you could hot wire the car in 20secs and have enough fuel to go about 50 feet. no way to find that switch, just had to know where it was by feel.
  3. Mar 1, 2020 at 8:32 AM
    Crusher69
    Crusher69 Well-Known Member
    Sean
    Denver
    '05 Built
    How much $$$?
    And ash tray in a car?
    PvilleJohn, Gregw138 and suaveflooder like this.
  4. Mar 1, 2020 at 8:55 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would like a burglar alarm that fires the steering wheel air bag.
  5. Mar 1, 2020 at 9:09 AM
    DG92071
    Cost depended on what the customer wanted and the salesman's mood.
    All vehicles used to come with ash trays not too long ago.
    That sounds extremely expensive. An insurance company definitely wouldn't cover it.
    PvilleJohn, Biscuits and maverick4x2 like this.
  6. Mar 1, 2020 at 9:15 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Biscuits likes this.
  7. Mar 1, 2020 at 9:35 AM
    DG92071
    Yes those used to be popular. I am not a fan of them at all though. Magnetic switches aren't the most reliable switches and magnets can be damaged by dropping/hitting them. But it is opinion.
    06Tacooo and Biscuits like this.
  8. Mar 1, 2020 at 9:36 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    For reference in 2nd gens the V6 uses an engine immobilizer with a chipped key while the I4 does not. Immobilizers are quite effective but of course not perfect. A kill switch not a bad idea for either but probably even more important on an I4.
    Love the idea of using existing OEM switches and such as a condition for starting.
    06Tacooo and DG92071[OP] like this.
  9. Mar 1, 2020 at 9:58 AM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    for those of us without lockers, a locker switch seems like a good choice...?
    PvilleJohn and DG92071[OP] like this.
  10. Mar 1, 2020 at 9:59 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    How about hiding a button under the headliner? o.o or under a patch LOL
  11. Mar 1, 2020 at 10:07 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    My old 1993 civic (heavily stolen car) needed the lights in the parking light position in order to start. I think to this day I will still occasionally reach for the lights on my Tacoma on instinct.
    PvilleJohn, Skyway, Biscuits and 4 others like this.
  12. Mar 1, 2020 at 10:10 AM
    DG92071
    It will eventually show as being touched often. Will a thief pick up on that? Doubtful.
  13. Mar 1, 2020 at 10:11 AM
    DG92071
    A competing shop did this too, the exact same thing. IF the thief lives close by they'll see the lights turn on every time the vehicle is started. Not good IMO.
    06Tacooo likes this.
  14. Mar 1, 2020 at 10:13 AM
    DG92071
    Often it's also possible to use an existing factory switch that can still be used for its original function plus as a kill switch. As an example turning on fan speed #2 to allow it to start. The options are damn near endless.
    Naveronski and Wixo like this.
  15. Mar 1, 2020 at 10:20 AM
    DG92071
    One other thing, if you piss off the thief they might get "even" with you. In the early 90's I bought my first new top of the line stereo, an Alpine. I installed 5 different back straps on it so it wouldn't get stolen. The thief tried to steal it and he couldn't so he proceeded to slice every single piece of upholstery in the truck and smashed the windshield from the inside. I actually caught the mo fo and chased him into an alley where he pulled a knife on me. It ain't worth it to me so I walked away and called the cops. Not that the cops would do anything about it, but it allowed me to get a police report number to file an insurance claim on the damage - which made my insurance premiums go up. Yeah yeah yeah it's illegal for insurance companies to do that...
  16. Mar 1, 2020 at 2:37 PM
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    Makes me think of this haha https://www.youtube.com/watch?v=VNdygguAMQA
    DGXR, JimIowa, BassAckwards and 2 others like this.
  17. Mar 1, 2020 at 2:51 PM
    TreeFortRichard
    Brian
    JimIowa likes this.
  18. Mar 1, 2020 at 3:01 PM
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    How about a biometric switch? If it ain’t you it fires 3 .45 caliber rounds into your ass
  19. Mar 1, 2020 at 3:16 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Should have brought a gun to the knife fight ;)
  20. Mar 1, 2020 at 5:46 PM
    maverick4x2
    maverick4x2 Well-Known Member
    2013 Tacoma 5 lug
    I never would've thought of most of this, love it
    Naveronski, Biscuits and suaveflooder like this.
